Like Tree22Likes
Old 09-27-2011, 05:48 PM
  #7501
ASH93A's Avatar
Originally Posted by Randy_Pike
Doubtful since they still have their "pre order" note up.
Yeah I know, but it also says 3 in stock
http://www.losipartshouse.com/servle...-cln-10/Detail
But I am guessing it is a mistake in the system??
ASH93A is offline
Old 09-27-2011, 06:12 PM
  #7502
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
I may pick up a V3 at my LHS tomorrow, we'll see!
Slash and Burn is offline
Old 09-27-2011, 06:19 PM
  #7503
Default part number
If they are out...are there part numbers for the adjustable anti-squat suspension hangers, wheel hexes and HD ball ends?
Seeds is offline
Old 09-27-2011, 07:03 PM
  #7504
Default V3 Setups
Hey to all you TD team drivers. Do you have any V3 setups for high traction, small/tight indoor tracks?
Old 09-28-2011, 01:56 AM
  #7505
TeamDurango's Avatar
Part No: TD330307 RR SUSPENSION HANGER (INSERT VERSION)
Part No: TD330309 RR SUSPENSION HANGER INSERTS
Part No: TD330293 HD BALL END SET (Black)
Part No: TD330312 PLASTIC SHOCK COLLARS,14mm HEXES & SHOCK STAND OFF SET
There's also the alloy 14mm hexes coming:
Part No: TD310226 ALLOY WHEEL HEX (14mm) 2pcs
TeamDurango is offline
Old 09-28-2011, 06:28 AM
  #7506
TAMAK's Avatar
Trader Rating: 28 (100%+)
Okay, so this may have been discussed but was going through my car last night and noticed that the bearing are VERY notchy in the drive line. When I originally built them they felt dry and put a dab of bearing lube on them it they felt fine, but now they feel like crap again. Any suggestions? Ceramic seems soo expensive for the whole car. I would do them for the drive line though.
Also Team Durango: Did you change bearing on the V3? To rubber sealed?
TAMAK is offline
Old 09-28-2011, 06:33 AM
  #7507
Briguy's Avatar
Trader Rating: 125 (100%+)
The stock bearing in the previous cars suck . I replaced mine with Avid Revolutions and been great .
I do hope the V3 has better quality bearings .
Briguy is offline
Old 09-28-2011, 05:04 PM
  #7508
Thank you for the quick response. Will be adding to my order.
Seeds is offline
Old 09-28-2011, 06:40 PM
  #7509
Default V3
Got my V3! Happy to report some of the past sins have been taken care of. The diff out drives fit into the gear without sanding, the X-rings have been replaced with o-rings.
Second request for V3 setups, someone has had to have had this car before me, factory drivers? Help a brotha out! There is nothing on the website for V3 setups. HELP! Looking for something specific to a small, indoor, high traction, clay track.
Old 09-28-2011, 06:46 PM
  #7510
TAMAK's Avatar
Machine cutt gears? And Also better bearings?
TAMAK is offline
Old 09-28-2011, 06:54 PM
  #7511
mdl060374's Avatar
I plan on ordering this soon. If anyone can give some advice it would be much appreciated.
I had a Cat SXII, and sold it just recently. Was going to get a CatSXIII, but wanted to hold out until I heard more about the V3, and have decided to with the V3.
I plan to be racing on a technical track, packed clay, with alot of jumps.
I guess my main questions are:
1) Is there anything (besides electronics and tires) that doesnt come with the kit, that is recommended? (recommended size pinion (I am running a Ballistic 7.5)?, diff grease, etc?)
2) If anyone has had a cat, the out of the box setup (part wise, and setup wise), is much different than what is recommended for US style tracks. Same for Durango?
3) Can anyone reccomend a good lipo saddle that fits well?
4) General overall build tips that arent in the instructions for smooth drivetrain, etc? (I know some cars require extra shims, etc in certain areas? or have certain problem areas that expereinced users can offer advice on.
I know I can look up specific setups for tracks, but kinda wanted some general advice for a newbie owner on this brand.
thanks
mdl060374 is offline
Old 09-28-2011, 07:04 PM
  #7512
The gears look the same as my DESC and the bearings are blue rubber sealed.
Old 09-28-2011, 09:08 PM
  #7513
t8rtot's Avatar
Trader Rating: 14 (94%+)
Check out the durango website for additional build tips and setup info
t8rtot is offline
Old 09-28-2011, 09:27 PM
  #7514
R/C Tech Elite Member
DavidR's Avatar
Trader Rating: 97 (100%+)
Hey Shannon,
Where'd you pick up a V3 already?
-David
DavidR is offline
Old 09-29-2011, 03:13 AM
  #7515
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I plan to be racing on a technical track, packed clay, with alot of jumps.What track?
1) Is there anything (besides electronics and tires) that doesnt come with the kit, that is recommended? (recommended size pinion (I am running a Ballistic 7.5)?, diff grease, etc?)20T and 10/5K to start
3) Can anyone reccomend a good lipo saddle that fits well? Orion 4600
thanks
I'm located in Ct. as well. Just wondering where you will be running?
Bman's 3XNT is offline
