Like Tree22Likes
Old 01-06-2012, 10:43 AM
  #8971
dangerwr's Avatar
Words. I have been changing diff fluids at the same frequency. Lately I have beeen changing shock fluids every race but every other race should be fine. The shock fluid is not that dirty but air can (and does) get introduced.
I like to have the best performing shocks as possible and takes little effort between practice runs on race day.
dangerwr is offline
Old 01-06-2012, 02:42 PM
  #8972
J-Fraz203's Avatar
Originally Posted by Bman's 3XNT
Did Larry run into you? That is wierd, try this. Pop all four inner ballstuds, so the cvds pop out of the outdrives. Then spin the whole tire,axle, cvd assembly by hand to see if there is any binding. LMK. If not I should be there next Weds. Good luck.
lol.....no its been doing this since new.
J-Fraz203 is offline
Old 01-06-2012, 02:45 PM
  #8973
J-Fraz203's Avatar
How often you guys changing your shock/ diff fluid? Seems to me after about four race days the diff fluid (losi) starts to break down. Really makes a difference when it's fresh. Thanks
i like to use the team associated diff fluid because they use Lucas oil witch is designed for automotive use and we could never abuse out diffs the way they get abused in a real car...so the lucas shouldn't breakdown but it may collect air or leak out. thats my concern....
Old 01-06-2012, 02:54 PM
  #8974
i use AE or Mugen diff oils. the losi diff fluids always gave me issues with not lasting a full race weekend before they broke down and needed redone.
cm.stites is offline
Old 01-06-2012, 03:19 PM
  #8975
dangerwr's Avatar
Default 1 degree rear hubs
Guys,
I have a question that am sure has been answered here before. I have some rear 1 degree hubs from the V3 kit. Which side is which? I a read Durango did something backwards.
Both are marked so ther is a L/R but from which way do you view the car? I was thinking from the rear. Thanks!
dangerwr is offline
Old 01-06-2012, 03:26 PM
  #8976
Is the new V3 kit much better than the old?
andjoh is offline
Old 01-06-2012, 03:46 PM
  #8977
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by dangerwr
Guys,
Looking down from the top of the car with the front away from you is how I do it. The left would go on the driver side and the right would go on the passenger side as if you were sitting in the vehicle. This will give you 4 degrees of rear toe in. I was having problems with rear traction and I remembered on my SCT they were marked backwards. I assumed the buggy was the same. It is not. When I measured I found out with them swapped was only 2 degrees.
jmackani is offline
Old 01-06-2012, 03:48 PM
  #8978
jmackani's Avatar
Are you running the emulsion shocks without bladders? They work off of the air from my understanding.
jmackani is offline
Old 01-06-2012, 04:06 PM
  #8979
dangerwr's Avatar
Yes I would agree that emulsion shocks use the aerated fluid to dampen the shock. I have asked numerous times and have been told that these shocks are not emulsion. I manage to keep air out of the shocks but once in a while one shock will aerate so I change fluid often.
Thanks for the help on the rear hubs BTW. Cheers!
dangerwr is offline
Old 01-06-2012, 04:08 PM
  #8980
dangerwr's Avatar
All the way better.
dangerwr is offline
Old 01-06-2012, 04:42 PM
  #8981
Team Tekin
Randy_Pike's Avatar
Guys if you run a shock without bladders in them it's an emulsion shock. You simply cannot have a non bladder shock without ANY air in them and have them compress. You cannot compress shock oil on it's own. Some air must be mixed to allow for shock travel. Bladders allow the air and oil to be separate from each other. This also allows for setting rebound.
For most 1/10 offroad wise emulsion shocks are better. Don't get me wrong I've seen bladder shocks work well for some so to each his own.
I believe the hubs are still labeled to where they must be backward.
Randy_Pike is offline
Old 01-06-2012, 04:52 PM
  #8982
dangerwr's Avatar
Thanks for the input and always value your knowledge. I was always under the belief that it had to be an emulsion shock. Understanding that oil is essentially an incompressible fluid and that if you were trying to compress the fluid the shock would not budge. But what I believe is that you are passing the oil through the holes in the piston. Please correct me if I am wrong.
And how can I be certain if the hubs need to be opposte from convention? I will look again on the TD website and see if they make any mention of the error. Cheers!
dangerwr is offline
Old 01-06-2012, 05:21 PM
  #8983
the toe angle will easily be noticable if they are on backwards.
Old 01-06-2012, 05:35 PM
  #8984
Team Tekin
Randy_Pike's Avatar
No worries. On the shocks what you're saying is true since there are holes. But the speed at which you could compress the shock with the little holes is SUPER slow. You can try it on a shock to see my point. Fill it up to the top, dome it on the body try not to spill, Screw on the cap. Now compress the shock all the way and you sill see that the shaft will not go all the way in. .It will hydro-lock near the top. This is what I've seen cause a lot of rear bulkhead issues in regard to breaking them. This also leads to premature leakage and a bouncy car.
If you put a hinge pint into the hub and set the face of the hub onto a flat surface like a setup board you can see which side of the hinge pin is lower. This "lower" side should face to the rear looking at the hubs from the top. Kinda confusing but give it a go.
Old 01-06-2012, 05:55 PM
  #8985
jmackani's Avatar
My V3 1 degree hubs appear to be labeled correctly in my mind. The label is on the backside of the hub. So looking from the rear of the car to the front, the left one marked left is on the left and the right is on the right. I measured and it's 4 degrees. Now I also noticed the kit also came with the older hubs that will not work with the new larger bearings anyway.
jmackani is offline
