Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#9152
Quick question. I finished building the diff, and the joints/axles that come out of them.
I noticed that in the diagram there is a round plastic "cap" (part # 310039") that is supposed to pressure fit over the axle where the pin fits through. I am guessing that its in case the grub screw comes lose, the pin doesnt fall out.
I cant seem to get the cap on. Is this really necessary to have? It seems as long as you use loctite, it wont be an issue. I dont want to skip this if you reccomend doing it as per the manual.
#9156
2 quick questions.
1) When assembling the slipper, the only guide I found was the 410SC which looks similar, but has different parts.
My question is with adjusting it. What is strange is that the part that comes on after the spring (with the grub screw) looks like it needs to be set b/4 you actually install the slipper. If so, how do you adjust the slipper on the fly (or can you?). If not, how do you get it fitting correctly, b/c it seems like it would take alot of finger pressure to get it tight enough to be correctly set, when you finally screwed it down.
(On my old car the Cat SXII, you just tightened a nut down, that applied additional pressure to the spring, once it was already installed.)
2) when shimming, I have no slop on the left/right outdrives at all, but.. the middle outdrive leading to the slipper does wiggle slightly. I made sure it wasnt the joint, but the piece directly attached to the gearbox. I just dont see how making more of a pressure fit b/w the gear will alleviate this correctly w/o making the gears mesh too tightly.. Unless I am messing something and I am supposed to shim that actual shaft in addition to the sides..
Is alittle bit of slop ok? or am I asking for trouble b/4 I even get it out on the track?
thanks for any advice.
#9157
2 quick questions.
#9159
When shimming don't be concerned so much about slop. Assemble the upper and lower gear box halves with the ring and pinion inside. Rotate the center cvd to feel the mesh. If you feel any high spot or notch, then add a shim on the side opposite the ring gear until you no longer feel the notch. If you have any notch feeling in it, it will tear out the teeth.
