Like Tree20Likes
Old 09-03-2010, 11:27 AM
  #1501
Glowster21's Avatar
Trader Rating: 136 (100%+)
Originally Posted by grapejuice View Post
I only have a 0.1 shim(gold one) on the case side of the diff. Read a post on oople from team driver Adam S. and he is running either the 0.2 or 0.1 only on the case side, just have to play with it since not everyone is going to be the exact same.
Make sure your bearings are seated all the way down onto the shim. I had to polish one of the outdrives to get the bearing all the way down. Solved my problem immediately.
Glowster21 is offline
Old 09-03-2010, 12:04 PM
  #1502
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Slim18 View Post
i got them so that they feel smooth but they still make some noise. im just gonna run it slow for a pack or 2 to break in the gears.
IS YOUR DIFF CLICKING? if so check the ring gear teeth
bigBoyBigToy is offline
Old 09-03-2010, 12:26 PM
  #1503
grapejuice's Avatar
Trader Rating: 151 (100%+)
Yeah, I did that to the case side on mine too so the bearing fit all the way.
grapejuice is offline
Old 09-03-2010, 01:17 PM
  #1504
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Got my aluminum front toe block and rear carbon brace installed.... now i nee to get the rest of the aluminum braces.
That rear brace looks trick... wish someone made a matching chassis...
Dlewis4 is offline
Old 09-03-2010, 02:34 PM
  #1505
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
http://www.rctech.net/forum/7889611-post11221.html
p.s. I still can't get the spurgear retaing clip to slide all the way through... =/
t0p_sh0tta is offline
Old 09-03-2010, 03:44 PM
  #1506
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Read the article about "8-Racing". The guy made a CF chassis for the DEX 410
http://www.oople.com/rc/photos/euros2010/day4/
Jmuck69 is offline
Old 09-03-2010, 03:47 PM
  #1507
Matt Howard's Avatar
I had the same problem with the spur gear retaining clip. I took a dremel to the ends of it to give it rounded ends so it would slide in easier, no problems now.
Matt Howard is offline
Old 09-03-2010, 04:23 PM
  #1508
t0p_sh0tta's Avatar
Have to find my Dremel... thanks for the idea.
Old 09-03-2010, 06:08 PM
  #1509
mdowney's Avatar
Trader Rating: 21 (100%+)
A coarse nail file also works. That's what I used because I was afraid I'd over-do it with the Dremel.
mdowney is offline
Old 09-03-2010, 08:02 PM
  #1510
took them apart and re shimmed them butter smooth now thanks for the help
Slim18 is offline
Old 09-04-2010, 03:35 AM
  #1511
Dlewis4's Avatar
First race night with the rango went great. Full report later on when I wake up
Dlewis4 is offline
Old 09-04-2010, 12:05 PM
  #1512
Dlewis4's Avatar
Can you not order the TDR310007 gear box inserts in plastic....?
I dont want to spend 40 bux on them... but i broke one last night
Dlewis4 is offline
Old 09-04-2010, 01:45 PM
  #1513
Dlewis4's Avatar
Alright, found the part i needed.
So, as for last night. My setup is in my signiture, geared with a 27/87.
The track is a BIG 8th scale track, so i wasnt geared perfect for it, but I held my own. Ran with the 8th scale electrics, ended up Qualifying 4th out of 7, and took 3rd overall. The car was incredible. I could put it wherever I wanted, and didnt even have to think about it. Super fast out of the corners, steering was superb.
I was running a 13.5- and was easily able to keep up with everyone in the infield, but was plenty fast on the 150 foot straight as well. I Think i could have gone up a tooth or two and been better.
Took a LOT of hard hits, from running with the 8th scales, and the thing just kept on going. Lots of people thought the car was going to break (myself included). At the end of the night during the last 30 seconds of the main, i got ran over going down the straight and broke the left rear gearbox insert. That was the ONLY problem of the night.
Temps were great, about 135 on the motor when I came off, and 140 on the speedo.
I cannot WAIT to get this on the indoor track, and get a decent setup on it.
Dlewis4 is offline
Old 09-05-2010, 08:10 AM
  #1514
Glowster21's Avatar
I almost scrapped the entire car because of this. Such a stupid little thing and I think I spent more time on that than the rest of the build. Had to drill larger holes in the plastic cover, finally worked after the 3rd time.
Old 09-06-2010, 08:24 AM
  #1515
tonyv2382's Avatar
Trader Rating: 67 (100%+)
For the retaining clip issue..All you guys have to do is angle the top spur cover correctly as u put in the clip. As soon as you get it to go in those holes properly just a nice strong puch and ur good. You dont want it to be too easy as it can..and will..come off if its not secure enough.
tonyv2382 is offline
