Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
Which pivot ball do I need to use in the upper shock cap to mount onto these metal shock mounts for my dex410v4? The stock plastic mounts ball are too small ID.
Thanks for the info. I think these may be what I need. The shaft diameter of the metal shock post are 3.5mm
Just found what I need according to the team-durango.com site. The info was in the description.
http://www.team-durango.com/part-inf...artNo=TD330031
http://www.team-durango.com/part-inf...artNo=TD330036
These have an ID of 3.5mm.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDXAJ&P=Z
Thanks EKT.
Isn't the r10 and the hobbywing v3.1 the same size? I'm having a terrible time trying to fiqure out how to get my r10 in the car with the external capicitor and my spektrum 3520 rx. I looked on petitrc at some pics but I can't get it right to my liking. Care to post a pic of how you put the hobbywing in?
I actually thought about taking out the plastic radio plate as well. Looks like I'm using the same spektrum 3520 as you. I can get it fitting nicely but what screws me is the r10's external capicitor. I have another esc. It's a viper vtx10, and its much smaller than the r10.But I don't think it's rated to run a 6.5 in a 4wd buggy
Can you extend the capacitor wires so you can mount it somewhere else? Maybe a different cap? The speed passion 4X cap is a pretty easy fit I think. It will fit in the side pod.
I get my car back soon all set up track test soon I need a lipo pack got one on layaway
its fantom sq pack
its fantom sq pack
If you use the MTX transponders they are a little bit smaller than the AMB stuff. The 410 is kinda tight but it can work.
Another idea for capacitor might be to use the SMC EX cap: http://www.smc-racing.net/index.php?...product_id=239
Looks to be pretty small. Square mounting means it could be under something. On the alum chassis would be best for cooling anyway.
