Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
None of their 1/10 scale diffs use gaskets. They wont leak.
I noticed the lack of gaskets and wondered myself. Now that I have had my car for a year or so I haven't had any trouble with leakage. They do have aftermarket gaskets, but again I don't notice any leakage without them. It would be nice to see a deeper tongue and groove on the gear though.
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Just ordered a new HW Xerun 3.1 for my DEX410! Along with the HW Xerun 6.5T motor! Should be balls!
Also picked up a set of Dirt Webs (finally, still a bit hard to get) - Who is running the larger tires like VTR or maybe EVO? I've run EVO (Typos) and they are pretty good. I think the smaller wheel is a little more forgiving and better in the bumps and on bigger jumps.
I grabbed a set of the HPI front shock protectors too. Thanks Dino!
I'm also planning to do a little customization to mount my SMC shorty pack down the center in the back. I have some ideas on how to make a strap as I will need to cut the center slipper mount to allow for the 96mm length of the SMC pack. I already have two of these packs and I'd rather not invest in another shorty pack just for the DEX410 yet. My plan is to use two of the chassis stay posts on either side of the shorty pack and then use CF battery strap across. I'll post pics when I'm done. Parts should be here on Wednesday from Amain!
happy happy man my cars a done now I just need a battery and test dive on the track now its way to fast with a 6 .5
PS, I finally have the new Center Ujoints so I can run my dual slipper without worry of popping drive shafts with my older 68mm rear mid CVD. Dual slipper is MO Betta!
I've run the Speed Passion 5.5T on the DEX410 and it was way too fast. I also ran the 6.5 from Speed Passion and it was just about right. I ran it with NO boost or timing. Everything stays really cool and I had power to spare.
I'd tell you my spur gear size but I just sold the thing...
sad to hear you don't have your DEX410! maybe you will get a V5
Isn't the r10 and the hobbywing v3.1 the same size? I'm having a terrible time trying to fiqure out how to get my r10 in the car with the external capicitor and my spektrum 3520 rx. I looked on petitrc at some pics but I can't get it right to my liking. Care to post a pic of how you put the hobbywing in?
haha this is a little bit of a tangent but I got a mamba max pro to fit in this thing!
The ESC was slid partially up under the driveshaft, up over the mud guard, against the servo horn, with just enough room for the sensor cable to fit between the motor and ESC. Then my Futaba R204GF-E rx barley fit between the battery, ESC, underneath my spur gear and on top of the mud guard again. I didn't have a voltage protector though...
EDIT: found a picture:
![](http://i101.photobucket.com/albums/m57/StevenTP/WP_20140630_17_31_53_Pro.jpg)
I had to modify my centre spur brace to get the shorty's to fit (run Nanotech 4200mah)
![](http://i294.photobucket.com/albums/mm109/Pittster83/ABCC675D-5DD1-4373-8C8C-D9831B14498F_zpsjkpoucey.jpg)
![](http://i294.photobucket.com/albums/mm109/Pittster83/E700CFCB-8B0B-4116-9D62-905DA8045928_zpszqtudztk.jpg)
![](http://i294.photobucket.com/albums/mm109/Pittster83/367B7BBE-FC10-42EE-BB74-839B8E96FA4C_zpscg7oqcbq.jpg)
![](http://i294.photobucket.com/albums/mm109/Pittster83/F7756267-F5A1-4895-8825-97B61F2FD91C_zpsuterjwnc.jpg)
Heres mine, still need to tidy up the wiring. And might move the transponder off the servo to the area next to the esc.
Is there a smaller receiver that will work with the airtronics MT-4?
The larger diameter rims offer better feel (less sidewall flex) on high bite tracks giving you better response. But on bumpy tracks a lower sidewall could be a little edgy.
If you use the conversion kit with the AKA evo adapters on standard rims it with EVO or VTR tires actually makes the whole tire slightly heavier due to the extra rubber rings you need to glue. The extra weight makes the tire less edgy and a bit more forgiving on bumpy tracks. Also if the track is low bite, the heavier tire gets you more traction and slows down your acceleration a bit to make it easier to drive. I tend to do this EVO conversion on some of my standard wheels with EVO or VTR tires to gain the added grip and traction. Electrons VTR or EVO Typos
