Like Tree22Likes
Old 09-28-2010, 10:54 PM
  #1996
R-E-A-P-E-R-'s Avatar
The most important thing for a track like that is going to be tires.
R-E-A-P-E-R- is offline
Old 09-28-2010, 11:43 PM
  #1997
Trader Rating: 16 (100%+)
Default tyresss
Originally Posted by grapejuice
I just started with a set-up from one of the team drivers, and just had to make small tweaks here and there where I felt it was needed. No box stock set-up is going to work well for any car, which is the beauty of the internet...you can find set-up sheets pretty darn easy.
Biggest thing I would say is don't use the stock 2000 wt. diff oil front and rear, front must be heavier than the rear.
thanks grape juice,
yeah its kinda true that most car stil need minor adjustment out of the box, there is one brand which is mugen, i find that their stock setting work well.
of coz wit the right tyre compound to use as well..
thanks for sharing Grape juice.
rossii is offline
Old 09-29-2010, 06:31 AM
  #1998
rfleck's Avatar
Trader Rating: 58 (100%+)
1+, On a "not so tight" track, I went with 10k front and 5k rear and loved it. Once they changed the track a bit (much tighter and technical) 10k and 3k rear seems really good.
In some cases, you may use 2k in the rear, but I don't think I would ever put 2k in the front.
Grape, what are you running in the diffs?
rfleck is offline
Old 09-29-2010, 07:01 AM
  #1999
grapejuice's Avatar
Trader Rating: 154 (100%+)
Right now I'm using 15k front and 5k rear, I run on a small track (80'x40'), very high bite, run slicks there once the track gets grooved in.
grapejuice is offline
Old 09-29-2010, 07:03 AM
  #2000
grapejuice's Avatar
Originally Posted by C_Money
no durangos around here except for the one I plan to get... Any ideas of a set up for this track right here?
http://www.youtube.com/watch?v=T9DBTmcMOng
Look around on here for a set-up that fits your track, type of dirt, traction level....
http://www.petitrc.com/setup/durango...ngoDEX410.html
Old 09-29-2010, 07:37 AM
  #2001
dangerwr's Avatar
Originally Posted by mike881
did you guys leave the wing clear? I'm assuming if I paint it, I should paint the bottom and leave the top clear?
If you do paint it paint the top. If you paint the underside it will flake off and look like doo-doo. You do not want your Rango looking like doo-doo do you?
The old scotch-brite works good but is amatuer (no offense DLewis). I have a media blaster here at work and can frost that puppy for you if you like!
dangerwr is offline
Old 09-29-2010, 07:41 AM
  #2002
mike881's Avatar
Cool danger thanks.
When you lock the center diff in over the battery strap, the pin is having a lot of trouble going all the way through, any tips?
mike881 is offline
Old 09-29-2010, 07:48 AM
  #2003
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
File the ends so that they taper slightly.
t0p_sh0tta is offline
Old 09-29-2010, 07:49 AM
  #2004
grapejuice's Avatar
Scotch-brite amatuer .....not everyone has a media blaster, let alone one they can bring to the track
Cool danger thanks.
People have been tapering the ends to help guide it through.
Old 09-29-2010, 08:03 AM
  #2005
http://www.harborfreight.com/air-eraser-kit-99636.html
They are $20 bud. And portable
  #2006
dangerwr's Avatar
Cool danger thanks.
I had the same issue. I took a small drill bit in a pin vise and opened up a little. I forgot to mention that about the build but is a minor detail.
dangerwr is offline
Old 09-29-2010, 08:15 AM
  #2007
dangerwr's Avatar
I know! I was just being a clown. I do not own the media blaster but is at my work. I am sure somebody paid at least $500 for that thing and I am the only one to use it. I can frost you a wing too if you like. I want my wing to be black actually. Can you dye lexan?
dangerwr is offline
Old 09-29-2010, 08:23 AM
  #2008
No you can not fool
Old 09-29-2010, 08:28 AM
  #2009
dangerwr's Avatar
Originally Posted by R-E-A-P-E-R-
No you can not fool
Dang! I wish someone would make a molded wing for these for me to try. It it was fairly thin and flexible would be sweet. Anyone want to give me money to have a mold built? I need like $30k probably . . .
dangerwr is offline
Old 09-29-2010, 08:47 AM
  #2010
You mean like these
http://os.3racing.hk/products.php?products_key=2726
or black
http://os.3racing.hk/products.php?products_key=2725
