Like Tree22Likes
Old 09-23-2014, 04:40 PM
  #16846
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by TeamIntegy
Hi guys, quick question... I'm running a 5.5 Orca with the stock 87t spur... But I am having troubles with heat... I am just wondering what I should be running for a pinion? Right now I'm 21/87. And about 5 minutes into a race I'm having heat issues. Maybe go down to a 17/18 type deal?
Thanks in advance.
5.5 is alot of motor, you need that much ?
Running a 7.5 with a 21 and it gets pretty damn toasty. Fast as balls.
One thing I'm going to do is open up the vent holes on the body.
Also Acer are doing a 25% off all bearings w/ free shipping. Ordered a full set for $67/shipped.
I previously ran their full ceramic kits on my v2/v3 and it helped free up the drivetrain immensely. Folks couldn't believe how quiet my car was. Helped with temps too.
tobamiester is offline
Old 09-23-2014, 05:15 PM
  #16847
Pittster's Avatar
I ran a 8.5 on the weekend with 24/87 and temps were 60c/140f. 8.5 is more than enough for me but our track was fairly loose
Pittster is offline
Old 09-23-2014, 07:57 PM
  #16848
ekt
ekt's Avatar
Originally Posted by SamuraiJack
Why does the front wheel axle (TD310112) have two different thicknesses when both bearings are 5mm inside?
The step down is where the hex sits.
Thanks in advance.
I'd say that 21 is a bit tall, unless you are on a big track, I would recommend a starting with a 19. Venting the body helps keep the temperatures down too, if you haven't already.
ekt is offline
Old 09-24-2014, 08:13 AM
  #16849
13Maschine's Avatar
Smile
FULL CERAMICS FROM ACER!!! I have them in both of my cars. 410 and 210. Awesome stuff. Everything is much quieter and smoother. The stock Durango bearings don't seem all that great. Low tolerance.
13Maschine is offline
Old 09-24-2014, 08:55 AM
  #16850
Trader Rating: 17 (100%+)
thx Dino D, not sure how I missed this hop up, but I will grab a pair.
diamonddawg21 is offline
Old 09-24-2014, 09:25 AM
  #16851
Originally Posted by Dino_D
I don't know the temps in F , only in Celsius .
DEX410
Temps:
28C - 2x1.6 F 42wt / 2x1.7 R 32wt
22C - 2x1.6 F 40wt / 2x1.7 R 30wt
16C - 2x1.6 F 37wt / 2x1.7 R 37wt
DEX210
Temps:
28C - 3x1.6 F 37wt / 3x1.6 R 32wt
22C - 3x1.6 F 35wt / 3x1.6 R 30wt
16C - 3x1.6 F 32wt / 3x1.6 R 27wt
Great thanks we use celsius here in the uk anyway we rarely see 28C haha or not even 20 at this time of year lol its closer to 10 - 15
av4625 is offline
Old 09-24-2014, 09:27 AM
  #16852
vito's Avatar
love my kit so far need a esc and lipo pack and set up next
vito is offline
Old 09-24-2014, 10:44 AM
  #16853
Dino_D's Avatar
If the temp is around 10C then you need to drop down another wt accordingly or even lower, try like 25wt in the rear or even 22.5wt I have used as low as 20wt in the rear in 10C weather. It really depends on grip.
Dino_D is offline
Old 09-24-2014, 10:45 AM
  #16854
Dino_D's Avatar
Originally Posted by vito
what are the stock pistons in the v 4 kit shocks
Type B pistons
2x1.6
2x1.7
3x1.6
3x1.7
2x blanks
Dino_D is offline
Old 09-24-2014, 07:17 PM
  #16855
FastPete's Avatar
Trader Rating: 44 (100%+)
Hi,
I have a V3 coming. Can all the V4 part differences be installed on the V3?
FastPete is offline
Old 09-24-2014, 07:52 PM
  #16856
Pittster's Avatar
Originally Posted by FastPete
Hi,
Yep best thing about the 410 platform, I have a v4 that began life as a v3. Only v3 parts left are ball cups, ball studs, slipper and castor blocks. Gotta save some more dollars for those
Pittster is offline
Old 09-24-2014, 08:25 PM
  #16857
13Maschine's Avatar
@fastPete: Do you have a 70mm mid rear shaft? or 68mm? if 68mm be careful how you upgrade, some things should be upgraded together. Such as the mid rear drive shaft and the dual slipper setup. I've run into this with my V3 because I have a 68mm mid rear drive shaft. Running the dual slipper doesn't allow for the drive shaft to reach as far as the regular slipper and this means it can slip out if you happen to case a jump too hard. Some of the guys here and I discussed it a while back and it seems some of the V3 units have longer mid rear shafts of 70mm which should work better. If you run the UJoints and the Dual slipper it's should be all good. (I don't have them yet!)
Old 09-25-2014, 01:59 PM
  #16858
vito's Avatar
vito is offline
Old 09-25-2014, 02:27 PM
  #16859
KBRacing's Avatar
This is my, Team Durango Dex410v3.5
with Penguin Body and wing, Skyrc Toro Ts120A, Trackstar 6.5T, Savox servo, and Nano-tech shorty lipo.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410v3.5.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410v3.5_2.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410v3.5_1.jpg
KBRacing is offline
Old 09-25-2014, 08:25 PM
  #16860
FastPete's Avatar
Thanks, Might have more questions when I get it in my hands.
FastPete is offline
