Like Tree22Likes
Old 10-14-2014, 02:07 PM
  #17026
tony montana's Avatar
Trader Rating: 76 (100%+)
I have the r10 in there now. But one of the motor wires is like you said papers width from hitting the spur. I will post a pic later on. Just worried if the chassis flexes at all the spur is gonna hit the wire
tony montana is offline
Old 10-14-2014, 07:13 PM
  #17027
platgof's Avatar
You can bend servo arms for offset as they are usually soft. I wouldn't go a lot, but I bent mine twice for offset. Pittster, that is tight.
platgof is offline
Old 10-14-2014, 09:18 PM
  #17028
Hey guys, I need some help. I have a DEX410R V1. A few months back I got some aluminum suspension hangers for the front. I finally went to put it back together, and the holes in the aluminum hangers are considerably larger than the old plastic ones. Do the V2/3/4's have larger pins and different a arms?
Thanks for the help!
Ben
benjamin27 is offline
Old 10-14-2014, 10:33 PM
  #17029
Ben
Hi Ben,
For the aluminum suspension hangers, you need the pivot-balls, they have the parts #TD330037!
The pins are the same.
micholix is offline
Old 10-15-2014, 01:31 PM
  #17030
vito's Avatar
vito is offline
Old 10-15-2014, 03:28 PM
  #17031
jreeves's Avatar
Now your cookin Vito! Time to get 'er dirty!
jreeves is offline
Old 10-15-2014, 03:34 PM
  #17032
vito's Avatar
pay day iam going to the track and get my battery
vito is offline
Old 10-15-2014, 05:05 PM
  #17033
KBRacing's Avatar
Hi All,
Does anyone know what this RF Low Roll Centre (Rear Front) (Part #: TD330308) is designed to do on a Dex410 ..... ???
Link.: http://www.team-durango.com/part-inf...artNo=TD330308
Thanks in advance
KBRacing is offline
Old 10-15-2014, 05:21 PM
  #17034
Thanks Micholix, I just ordered some!
Do you know what I need to do a hex conversion to run newer style wheels?
Old 10-15-2014, 06:40 PM
  #17035
Dino_D's Avatar
Originally Posted by KBRacing
Hi All,
Thanks in advance
Those are optional RF blocks for the older 410 kits. The v3 and v4 have a reversible block. One side says -2 the other +2 to change the roll center of the car. -2 LRC give more roll, and the +2 HRC side gives you less roll. You shouldn't really need this older part unless yours is a v1 or v2 kit.
Dino_D is offline
Old 10-15-2014, 07:57 PM
  #17036
ekt
ekt's Avatar
That part actually lowers the arms more than the -2 block, if the v4 setup sheets are anything to go by.
ekt is offline
Old 10-15-2014, 08:01 PM
  #17037
vito's Avatar
Originally Posted by vito
all done got it all in there
vito is offline
Old 10-16-2014, 01:06 AM
  #17038
You are wellcome ben!
The axels outer diameter from the TD cars should be all the same, by ~5 mm, i dont know exactly at the moment!?
For a hex conversion, to the original TD 14mm hexes, you should need two sets of the #TD310226 alu hexes and one set of the #TD310135 roll pins.
Best you get some 5x7x0.1mm distance shims as well, these have the parts #TD709070!
There are some after market hexes, but for them i dont have part#.
I hope this helps.
Mike
micholix is offline
Old 10-16-2014, 02:33 AM
  #17039
After seeing the above pics do you guys run your aerials inside the body or not
thefan is offline
Old 10-16-2014, 02:42 AM
  #17040
ekt
ekt's Avatar
I run mine outside
ekt is offline
