Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
[QUOTE=ekt;13587193]DE Racing make some, available in multiple colors http://www.deracing.net/store/index....ategory_id=213
Thank you
Thank you
Rear Avid 12mm and also the JConcepts and Proline 12mm hexes for B4 will work, you'll also want some spacers here. I think I am using the Kyosho axle spacers.
Way back in the thread you will find additional discussion on this and more pictures if you do a search. Let us know if you can't find the info you need...
Biggest issue I have so far with the build is why can't durango make it visible to see the markings on the shock pistons. I can't make them out.
I have some 12mm hexs that are made for Durango. We use them on the shortcourse truck.
Front Shumacher K1 12mm front hexes will fit but you will need a few spacer washers to get the same width as the stock 14mm. Then you can use TLR 22-4 front wheels. Also AKA 12mm for the 22-4 so you can run EVO.
all done my racer friend is mouting the rx and esc and wires tiddy up some ill post some pics up soon.
Thinking of trying some 3500 mah shortys for my DEX410. Think I'll get 8 mins with a 6.5t non boosted setup?
I run 4200mah batterys and after a 5min race with 2 warmups laps it only uses 1100ma this is with a 8.5 no boost 1750g weight
We decided not to go with a grub screw to hold the pin in. Thinking of trying a cotter pin to be honest with you. At the moment I haven't lost any pins in the set I am using.
I noticed something strange with the V4 build, no diff gaskets, do they seriously not leak without a gasket? I've built many rc cars over the years and all of them had gaskets to seal the diffs apart from the ball diffs of course.
@ the fan, since they replaced the x ring seals in the diffs they don't leak without gaskets if you build them properly and put some green slime or grease around the rim of the diff case when building.
http://www.team-durango.com/in-the-p...rticle_id=3193
Follow the tech tip for completing the diff build:
http://www.team-durango.com/in-the-p...rticle_id=2584
