Like Tree22Likes
Old 03-18-2014, 09:09 PM
  #15481
Originally Posted by teeforb
Doesn't the big bores come on v3? Am I missing something here?
Not the version I got. Thanks, I have some washers in there already but I dont have the long mounts.
lee111m is offline
Old 03-20-2014, 02:17 PM
  #15482
Dino_D's Avatar
Not if you got the V3R.
If you look on petite RC, there are tons of setups for the small bores for all different conditions.
But its really not that much money to upgrade them. Its around $10/pair of shock bodies, then get a piston set approx $6-10 depending if you get type B or machines , and big bore plastic caps $10. If might be worth it if you run on tracks with lots of jumps and bumps. But on carpet, small bores give you quicker response.
Technically you should still have the big bore shock collars in your kit, as it comes with big and small bore collars and plastic wheel nuts.
Dino_D is offline
Old 03-20-2014, 03:10 PM
  #15483
Oh thats a good idea. At the time I didnt buy the bigbore version because I didnt know the difference. Changed to bb's on my b4...now I won't go back and regretting the 410 i picked HAHA.
lee111m is offline
Old 03-20-2014, 07:28 PM
  #15484
trick25's Avatar
Trader Rating: 28 (100%+)
i think the asnwer to this is yes they are but to clarify is the big bores or the dex210 the same as the 410.
trick25 is offline
Old 03-20-2014, 07:31 PM
  #15485
teeforb's Avatar
Trader Rating: 94 (100%+)
Can someone let me know exactly which 12mm hex works for both front and rear such that I can use kyosho wheels?
teeforb is offline
Old 03-20-2014, 08:02 PM
  #15486
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
http://www.petitrc.com/setup/durango...herWheels.html
thecman26 is offline
Old 03-20-2014, 08:08 PM
  #15487
teeforb's Avatar
Thanks but can't seem to find HB parts. They seem to be discontinued
teeforb is offline
Old 03-20-2014, 09:52 PM
  #15488
Dino_D's Avatar
The DEX210 and 210RTR have the same shocks as the v3 or v4. the v3R uses small bores
Dino_D is offline
Old 03-21-2014, 12:40 AM
  #15489
thecman26's Avatar
Bummer, I haven't had mine that long!
Amain is where I got mine.
Yup, no longer on their site.
Old 03-21-2014, 05:40 AM
  #15490
the incubus's Avatar
Trader Rating: 17 (100%+)
http://www.rcplanet.com/Hot_Bodies_F...p/hbs61499.htm
http://www.activepowersports.com/hot...FRQaOgodWTAAjQ
http://www.shop-rc-models.com/products/hpi-racing/61474
the incubus is offline
Old 03-21-2014, 09:24 PM
  #15491
teeforb's Avatar
Geez. Tower is taking for ever to get the v4 in stock? Do you guys know where I can get the v4 close the $340 shipped, besides tower?
teeforb is offline
Old 03-22-2014, 02:03 AM
  #15492
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me is the caster of the dex410 with the 19deg caster blocks actually 19deg in total including the chassis kickup? does anyone know what the chassis kickup angle is and what the caster block angle actually is?
LOSI123 is offline
Old 03-22-2014, 03:02 AM
  #15493
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
The chassis kickup is 12 degrees. The castor blocks come in 17,19 and 21. So I guess 31 total. Hope this helps.
Bman's 3XNT is offline
Old 03-22-2014, 05:48 AM
  #15494
LOSI123's Avatar
Ok the reason i ask is I come from a B4 buggy which there 30deg caster blocks only actaully have 5 deg in them and the chassis has 25deg. I thought this buggy may have been the same.
EDIT: Upon eye balling it alot closer I have a feeling it looks as if the 19 deg is including the chassis kickup and there may be only 7 deg in the hub itself.
Are you certain of there being 31 total?
LOSI123 is offline
Old 03-22-2014, 07:11 AM
  #15495
Am I certain, no. But I am certain the chassis is 12. It could be included I just don't know why Durango would market them like that then. But what your saying makes sense because when I ran Kyosho they had 7&10 blocks. I know it's a question but why such the interest?
