Like Tree22Likes
Old 03-15-2015, 12:26 PM
  #17731
rcjunky1's Avatar
Sounds like the car is unloading, like it's bouncing. It's either too stiff or too soft and bottoming out. It sounds like you're on carpet, so try dropping your car from the height of the jump and see what it's doing. You could also go thicker on the diff oil to prevent it from difficult out and spinning when it's unloading.
rcjunky1 is offline
Old 03-15-2015, 09:16 PM
  #17732
vacajar's Avatar
Just bought a V3 with lots of upgrades from the V4. I do have a question on the ESC and Motor setup in the car currently. To me it seems overpowered but let me know what you guys think.
Motor is a Trinity 3.5 turn with a Tekin RS Pro ESC.
I have not received the car yet so im not sure what its geared at or what its temping. Thanks!
vacajar is offline
Old 03-15-2015, 10:53 PM
  #17733
Dino_D's Avatar
most pro use 5.5 or 6.5 3.5 is way too much
Dino_D is offline
Old 03-15-2015, 11:03 PM
  #17734
ekt
ekt's Avatar
A 3.5 is way too much motor I've found the RS Pro will struggle, temperature wise, with a 5.5 unless you have fans blowing over it.
ekt is offline
Old 03-16-2015, 08:09 AM
  #17735
vacajar's Avatar
Thanks guys i thought that seemed like too much motor. Do you think i would be fine to run an orion 7.5 with the Tekin RS Pro ESC. I have one sitting around. Thanks again!
vacajar is offline
Old 03-16-2015, 08:32 AM
  #17736
tobamiester's Avatar
Trader Rating: 360 (100%+)
Yes 7.5 is what i run. RS pro will work but keep an eye on the temps....I used to run that ESC but it always ran pretty hot...
tobamiester is offline
Old 03-16-2015, 09:44 AM
  #17737
vacajar's Avatar
what type of gearing are you using with you 7.5? temps? track type? my local track is an outdoor med grip clay/dirt mix.
vacajar is offline
Old 03-16-2015, 10:06 AM
  #17738
87/22. My motor runs pretty toasty so I have a fan mounted on it.
Primarily run it on a small Indoor/Clay track.
Old 03-16-2015, 02:52 PM
  #17739
Trader Rating: 26 (100%+)
I am finding even the 5.5 is a little much for the buggy. I run a 5.5 and nothing but heat issues. I'm at 21 I think but now it's turned down to 75% medium sized track. Doesn't matter where I gear it always comes off 180-190...that isn't the real issue though...it's the wear and tear LOL. second set of cvd rebuilds all around, blown out bearings, fun stuff. BUT IT DOES RIP!
tfrankito is offline
Old 03-16-2015, 06:09 PM
  #17740
platgof's Avatar
I put a 5 turn Tekin in mine for one race. It was stupid fast, and cleared jumps like superman. I put that away,lol, and now use a Tekin 7.5 also geared 87/22, but no heat issues with the RS Pro. I put an RSX in it, but have not raced it yet.
platgof is offline
Old 03-16-2015, 07:18 PM
  #17741
vacajar's Avatar
Good info guys thanks! I think the 7.5 will be going in it for sure. But i might have to try it once before i make the swap. 87/22 seems to be the general setup that i have seen.
vacajar is offline
Old 03-16-2015, 08:36 PM
  #17742
rcjunky1's Avatar
I was running 18/87 with a 6.5 and it still got hot thermalled near the end of the main Friday running carpet off road. I will be going to the v4 diff stuff in the carpet car so we'll see how that affects the motor temps. I'll be running 19/87 in the dirt car, with a 20t pinion on a sonic 6.5 in blinky it was at 170, 190 on the ESC slightly over geared I guess. I wouldn't recommend anything more then a 6.5 for sure, and wouldn't suggest an rs pro in this car either. I love mine in the 2wd car though
rcjunky1 is offline
Old 03-16-2015, 08:59 PM
  #17743
vacajar's Avatar
well maybe ill swap out my novak pulse ESC from my 2wd and see how that works. I have a few options as the RC hobby has me hooked BAD.
vacajar is offline
Old 03-16-2015, 10:13 PM
  #17744
rcjunky1's Avatar
I think that esc only goes down to a 7.5? Be very careful with temps
rcjunky1 is offline
Old 03-16-2015, 10:34 PM
  #17745
Careful novak does not like heat..at all.
