Like Tree22Likes
Old 02-16-2012, 05:01 PM
  #9481
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Jpm1
Yeah the v3 rear hubs have the larger bearing, I also have the bearings you need bud
ok cool. i have to pick some one up from the airport at 8.30
so will try and drop in before that if its ok
ozzy-crawl is offline
Old 02-16-2012, 05:28 PM
  #9482
ozzy-crawl's Avatar
Originally Posted by DBL15
and anything else you might need or might not need my bet is JPM1 will have it
i know i am dropping in tonight for another friday night tinkering session
bring it dowen Scotty i am sure between us we would have the parts you require to get it going
Do you have any spare driving skills in your tool box, been 12 months since i ran.
some driving ability would be handy if you have some spare
Old 02-16-2012, 05:34 PM
  #9483
DBL15's Avatar
will be fine normally in there around 7.30pm
ummm nup not for sale that item
DBL15 is offline
Old 02-16-2012, 06:51 PM
  #9484
ozzy-crawl's Avatar
Dam
Owell i reckon there is a fair chance i will still make the Amain by being in the top 10
Old 02-16-2012, 07:34 PM
  #9485
slow_jun's Avatar
Trader Rating: 14 (94%+)
Originally Posted by onekiwi
and I presume that it can't be fixed
if that were a RS Pro that would be $90 buks plus shipping and you get a BNIB RS Pro....and free if its still Under warranty
slow_jun is offline
Old 02-16-2012, 08:55 PM
  #9486
Originally Posted by jaker
Looking for some pointers from you guys having heat issues. I have an rs pro with a redline 6.5 with 87/21 in a medium sized indoor clay track. Motor would come off at 165F and esc was over 180F and I'd shut it down within 2-3min. Double checked my esc on the hotwire, no timing, no boost and no current limiter.
Finally went to a 87/20 and motor came off at 140F and esc thermalled and shut down after 3-4 mins. I want to go down one more tooth but the motor is all the way in on a 87t spur and I don't have anymore available at our store that are bigger. I have holes all over this body so air flow is not an issue. Doesn't appear to have any abnormal drag. What am I missing???
I figured out my heat problem today finally!.. After putting an associated 89t spur and 19t pinion I was still 135f motor temps and 185f esc temp after 4mins of run time. Used a speed passion donor dual capacitors and soldered it on my tekin to cut off 45f!!!!
It's a track with bigger jumps and lots of full throttle bursts which puts a lot of amps through the esc and with the stock cap it couldn't take the heat.
So in a nutshell, 89/19, 6.5 redline, rs pro (no timing or current limit) with bigger dual capacitors, and no binding in the drivetrain= 125f motor temps and 140f esc temps with a whole battery.
jaker is offline
Old 02-16-2012, 10:43 PM
  #9487
contact solara on here and he can give you more info on it being fixable or not
Anyone running a LRP TC spec in theirs? think it will go well?
Its either ther TC spec or a RS pro
As I took my speed passion esc apart to redo the heat sink as it kept getting hot and found this
cm.stites is offline
Old 02-17-2012, 01:54 AM
  #9488
jimkoimanis's Avatar
it can be fixed i had a ko do the same sent it in and they fixed it at a cost
what esc is it
jimkoimanis is offline
Old 02-17-2012, 01:56 AM
  #9489
Originally Posted by Raul Garcia
Do you have also the BB shocks?
td bbs
Old 02-17-2012, 02:03 AM
  #9490
onekiwi's Avatar
what esc is it
Its the speed passion GT 2.0 Pro
I sent a PM to Solara see if he replys.
onekiwi is offline
Old 02-17-2012, 10:03 AM
  #9491
Does this buggy require a 540 or 550 size can and whats a good general turn motor to run a medium sized track
T3tsaya is offline
Old 02-17-2012, 10:18 AM
  #9492
540 only. 6.5 to 10.5
jaker is offline
Old 02-17-2012, 12:11 PM
  #9493
Autocratic's Avatar
Trader Rating: 26 (100%+)
Any Durango drivers out at Motorama PA come hit me up in the Traxxas Booth. Far back corner of the speed room. Name is Alex. Looking to see some Durango up top all weekend.
Autocratic is offline
Old 02-18-2012, 09:09 AM
  #9494
onekiwi's Avatar
I have the rs pro and 2 second party caps.
Its in a durango 410 on a tightish/med carpet track running 0 timing 85 current limiter and rest as standard.
The esc is coming off at around 80-90C, nearly all lights blinking geared at 87/19 motor at about 60-70C
Losi 6.5T motor no timing
What am I doing wrong? How do I get the temps down?
onekiwi is offline
Old 02-18-2012, 09:19 AM
  #9495
have you vented the body at all? check the drive train for any binding without the motor connected. my rs needed alot of venting to stay cool.
