Like Tree22Likes
Old 09-29-2010, 08:53 AM
  #2011
dangerwr's Avatar
I like the black one. For $5 I might just buy and try one. Do you think they are jank? 3Racing is not bad, not great, but not bad stuff.
dangerwr is offline
Old 09-29-2010, 09:02 AM
  #2012
Trader Rating: 27 (100%+)
What motor do most people run in a 4wd buggy?
C_Money is offline
Old 09-29-2010, 09:03 AM
  #2013
R-E-A-P-E-R-'s Avatar
I ordered one already if you want to wait to see how it fits on mine
R-E-A-P-E-R- is offline
Old 09-29-2010, 09:05 AM
  #2014
dangerwr's Avatar
Seems like a lot of guys are running the 7.5. Some with a 6.5. I actually am going to run 8.5 and dive into that dynamic timing advance offered by the technologically superior Novak Kinetic if I need any more.
BOOM!
dangerwr is offline
Old 09-29-2010, 09:11 AM
  #2015
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
I run a 7.5 Tekin with no timing boost on the esc and 5ish degrees on the motor. Stock spur (87?) with a 22 pinion. Temps around 140 after 8 minutes, and 4 lights on the ESC. I do have a small high-velocity fan on it though.
t0p_sh0tta is offline
Old 09-29-2010, 10:06 AM
  #2016
dangerwr's Avatar
Originally Posted by R-E-A-P-E-R-
Yeah, MHOR should get one! All you need is some Arm & Hammer sodium bicarbonate and the air compressor. Says 50psi but bet you will want close to 100psi and some rubber gloves!
dangerwr is offline
Old 09-29-2010, 10:49 AM
  #2017
mike881's Avatar
can somebody verify what one of these braces is recommended, or should I get both?
Front inner:
http://www.amainhobbies.com/product_...pension-Holder
Front outer:
mike881 is offline
Old 09-29-2010, 11:01 AM
  #2018
dangerwr's Avatar
Front inner:
Front outer:
You got it! You will also need the pivot balls that go with these.
http://www.amainhobbies.com/product_...vot-Ball-Set-8
dangerwr is offline
Old 09-29-2010, 11:27 AM
  #2019
Trader Rating: 21 (100%+)
hi all crazy Rango owners! i'm about to order a tekin rc combo so i notice that it doesn't comes with any power cap wired to esc..what about you guys running this combo?! was running lrp sphere tc before and power cap was already bolt on it..so should i get one? my 410r is halway done..just still waiting for aluminum braces, boots, fiber carbon towers and ball cup to get it done..very happy with the kit so far!assembling and fitting is just awesome! my only pain is that pin holding the center diff...really hard to get it thru.. thx for any advice!
mccoy is offline
Old 09-29-2010, 11:31 AM
  #2020
dangerwr's Avatar
Are you talking abou that u-shaped pin? I had a little trouble at first because my diff was not seated all the way down. I forget why it would not settle in but believe my spur was caught up on something.
dangerwr is offline
  #2021
t0p_sh0tta's Avatar
Tekin includes a cap in the box. It's easily soldered in along with the power wires.
Old 09-29-2010, 11:34 AM
  #2022
Glowster21's Avatar
Trader Rating: 136 (100%+)
The RS comes with a small cap that needs to be soldered onto the esc. MUCH smaller than the LRP. Make sure you get the RS Pro as you may have overheating issues with the RS. Running a 7.5 you should start around a 22 Pinion, 8.5 should be 24 or so. Make sure you punch out some small cooling holes over the motor, and position the motor so the solder tabs are along the side of the chassis. Ran mine for the first time yesterday, KO VFS 1.5 esc, Full Throttle 7.5 Duo 2 Platinum Base, Orion Carbon Molecular 4500 Saddle, came off at around 130 degrees after about 10 minutes and was an absolute rocket! No other fans on the motor, just the fan on the top of the esc and 3 small cooling holes in the body vent near the motor.
Have Fun!!!
Glowster21 is offline
Old 09-29-2010, 03:23 PM
  #2023
thx guys for your help! Danger yes i was talking about the U shape pin!gotta use dremel !!anyway my big deal is to make my choice on the 7,5 or 6,5 motor..only running this car indoor on a small track..not really loocking for crazy speed maybe more torque for exiting sharp corners and for the starting grid!!
mccoy is offline
Old 09-29-2010, 03:55 PM
  #2024
t0p_sh0tta's Avatar
One of the fastest guys at my local track is running 17.5. Another with 10.5, and the rest with 6.5-8.5. They're all competitive.
Old 09-29-2010, 04:37 PM
  #2025
dangerwr's Avatar
I do not know if it makes sense to have to use a dremel. I bet a 7.5 is a good choice all around . . .
dangerwr is offline
