Like Tree22Likes
Old 11-08-2014, 04:55 AM
  #17161
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by thefan
Another bad day at the track I broke the front bulkheads and worse all the online shops are out of stock till early December and I had a major race this month
Sorry to hear about the breakage...We have 4 in stock
tobamiester is offline
Old 11-08-2014, 05:52 AM
  #17162
evostyle's Avatar
Trader Rating: 103 (98%+)
How did it happen? Did it break just in front of the screw hole that the upper brace mounts to?
I'm on my 3rd set of bulkheads and I have two more sets coming via eBay. This is really a poor design as the whole load of the front end / shocks are transferred to the small part of the bulkhead. I was hoping to find an aluminum set of bulkheads online. No such luck.
evostyle is offline
Old 11-08-2014, 11:14 AM
  #17163
Yep right where the screw hole is snapped them both off, I think I need to brace them some how like the d413 or try boiling them
thefan is offline
Old 11-08-2014, 08:40 PM
  #17164
The front bulkhead has to be the weakest part on our buggies. If anybody has any good mods or fixes I would love to hear them
Sodakota is offline
Old 11-08-2014, 08:46 PM
  #17165
evostyle's Avatar
What's another ball cup option that works with the stock ball studs?
evostyle is offline
Old 11-08-2014, 09:18 PM
  #17166
Dino_D's Avatar
The Dimex cups work great. What seems to be the issue with the cups? If you are talking about the HD V3 cups, once they pop off once you need to replace them or they will keep popping. Another thing with the V3 HD cups are the threads are pretty tight so its easy to pop them off when adjusting so you need to work the treads many times into the cups so it can be adjusted easily without popping the cups. The Kyosho ball cups work as well. (sorry I can't remember the part number) but it is a direct fit.
Dino_D is offline
Old 11-08-2014, 10:07 PM
  #17167
platgof's Avatar
The Dimecs are a lot better and so easy to install. I only had one pop off tonight, and then my servo went out on me, stripped gears. I had an absolute blast driving this thing tonight. I can't wait to install the moulded gears on it, and get the diffs squared away. I was having a lot of steering issues and it never occurred to me the servo was going out.
platgof is offline
Old 11-09-2014, 12:30 AM
  #17168
Another update on my experience so far with the V4, 4 packs ran through it and 3 broken parts, rear arm, front tower and front bulkhead all occured seperately, so i'm pretty annoyed so far, anyway here is my solution to the issues this buggy has.
Firstly the arms can break on any buggy so i decided to boil all arms hubs etc..(will do bulkheads eventually too)
Second the shock towers holes are too close to the edge and will eventually break no matter how good a driver you think you are, my solution is to mount a spare touring car tower to the back of the dex410 tower to reinforce it. This one is frp and can be bought from 3racing for under $5 but carbon would be even better.
Next the front bulkhead, the screw hole that mounts the top brace to the bulkhead is a weak spot and pretty poor on Durango's engineers to think it wouldn't break there, i decided to make a brace similar to the D413 but using a turnbuckle and some ballstuds and cups, again spares from my TC, the body needs to be trimmed a little but overall i think it looks ok.
I will test and report back but i am waiting for a new bulkhead as the one pictured is the broken one that i glued back together, but i will drive it on the weekend like that if the new one doesn't show.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-p7160377.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-p7160378.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-p7160380.jpg
thefan is offline
Old 11-09-2014, 04:59 AM
  #17169
rcjunky1's Avatar
I run a 'defective' 5mm front tower and have never broken it and only cleaned off the bulkheads once in a big wreak. Someone here was working on manufacturing 5mm towers and those shouled fix the tower issue, and bulkheads are cheap compared tothe tower so I wouldn't be concerned there.
rcjunky1 is offline
Old 11-09-2014, 06:11 AM
  #17170
evostyle's Avatar
I'm using the Dimex cups that came with my v4 kit. So far I've had two front camber links get "pushed" in. The plastic doesn't seem to be all that stiff to me. The tie rods are really easy to thread in. As far as the Dimex cups popping off I had one of my steering rods come off last night in the main. After 3 mishaps with these Dimex cups I need another more reliable solution. I'll give the kyosho cups a look.
evostyle is offline
Old 11-09-2014, 07:29 AM
  #17171
I have had same issue, with pushing in on front camber links when I run on carpet. Also have rear pulling off.
turtle189mt is offline
Old 11-09-2014, 07:33 AM
  #17172
13Maschine's Avatar
I've broken my fair share of shock towers both front and rear. I'm currently using the HP Vorza shock tower protectors (Thanks Dino!) and that also seems to have helped.
I'm still breaking quite a few front arms. Always in between the hub and where the lower shock mount screws. Last time I rebuilt the car I used plastic spacers on the hinge pins to provide more flexibility and possibility some impact absorption. I'm not sure if this was effective. I'm still considering using plastic pivots instead of the steal pivots for the suspension as another way to provide a less rigid system. Also allowing for flexibility upon impact.
I've also considered using the 410R plastic towers as a way to reinforce the front and rear towers. I usually keep these as spares along with the CF since they are cheaper.
13Maschine is offline
Old 11-09-2014, 11:08 AM
  #17173
SamuraiJack's Avatar
Trader Rating: 41 (100%+)
I think the shock mount screws on the front arms are too long, so that hole is too deep. I've had two arms snap there.
Re: dimec cups. I have had the threads get pushed in or pulled out (but this was on a buggy i bought used) got all new ones and per Durango's blog threaded them carefully all the way in and back out with a tiny bit of grease. Hopefully that will give them stronger threads.
SamuraiJack is offline
Old 11-09-2014, 12:50 PM
  #17174
platgof's Avatar
Weird isn't it, they make the Dimec cups easier to install and over do it by making it to easy to strip, just like the original cups that the holes were to small and nearly impossible to get on. No middle ground here. I was surprised how well the Dimce cups stay on, not to bad, but the thread is too large to handle the force it is taking. Are the Kyoshos a direct fit? What number?
platgof is offline
Old 11-10-2014, 08:48 PM
  #17175
platgof's Avatar
I never thought I would enjoy driving a 4wd buggy so much, this thing is a blast. I replaced the Align 615 servo with a Savox 1258. I stripped the big gear, so it is toast. I will start rebuilding the diffs soon. I really like the 2 and 3 hole pistons, really nice. They rebound faster somehow, I guess it is the "pack." When my Align servo was messing up, I had very high motor temps?
platgof is offline
