Mugen MTX-3
Old 03-08-2005, 01:33 PM
  #14761
Default front spool configuration
Hi,
I was running the front one way with a adjustable rear diff with stock pully. Changed over to front spool..the car have a sharper braking and also launches very fast out of corners...lap time was down 0.3 sec compared to a front one way. Rear diff oil is 10,000 wt (mugen), but i have i can tighten the rear diff to make more stiffer.
Found that the stiffer rear diff will help the car powers out of corner tighter. Last weekend ran the car in this configuration until the rear started sliding coz the rear tires have worn down to the rim !!!! I never true my tire...as long as the front is smaller than the rear !!!Nevertheless, the car handled perfectly.....try it !!!
Xtreme888
xtreme888 is offline
  #14762
cdelong's Avatar
Default Re: ROll Center
Originally posted by straightsixers
Guys, just need to clarify something and brotherman if you do see this, hope you can shed some light...
Doesn't HIGH RC = Less Roll (Because the RC point is at its highest and nearest the CG of the car) and therefore appropriate for high traction/bite conditions because we do not need added traction and need the car to be more aggressive. And LOW RC = More Roll, suited for low traction/bite conditions because we need the added weight transfer to add traction which also results in the car being a little lazy?
IN essence is it correct to assume with all other parameters equal;
HIGH RC suited more for HIGH TRACTION TRACK
LOW RC suited more for LOW TRACTION TRACK
Or vis-a-versa?
Or is there more that meets the eye??
Thanks in advance.
I think it's more than meets the eye....
The pro's only mention that the "A" block lower the RC, and not WHY they lower the roll center. The one thing we need to realize is that there is more than one thing drivers are trying to accomplish. I've been on the Mugen forum, and it seems that the "A" blocks (low roll center= more roll) are used when bite is high to add some laziness to the car and to prevent traction rolling. If the car will not roll on the suspension a little, it will just traction roll if the bite is high. Swauger mentioned that the blocks will also change the shock angle slightly (A= more laid down).
Just push the "I believe" button and do what the big dog's do= high bite = Low roll center.
cdelong is offline
Old 03-08-2005, 02:35 PM
  #14763
eddiethefish's Avatar
Default Re: where is everybody??
fish is around, just on and off, like going to the track, hehe
Originally posted by RClover
been away for quite some time.
where are my friends? eddiethefish, manticore...
eddiethefish is offline
Old 03-08-2005, 02:40 PM
  #14764
teammpp's Avatar
Default Re: solid front/ spool
guys,
anybody running the front spool configuration? if so, what's the rear diff oil? does it help on the medium size technical track? pros and cons?
cheers
I've tried it. Running 30K oil in rear diff. Going up to 100K this weekend. Diff is far too loose
teammpp is offline
Old 03-08-2005, 10:04 PM
  #14765
RClover's Avatar
Default Re: Re: where is everybody??
yea...the feeling is good when goin back the the track!
what's the powerful secret weapon now? rear adjustable diff on the 3?
RClover is offline
Old 03-08-2005, 10:06 PM
  #14766
RClover's Avatar
Default Re: Re: solid front/ spool
saw the fr one-way modification on other tread, is it reliable?
RClover is offline
Old 03-08-2005, 10:07 PM
  #14767
RClover's Avatar
Default Re: front spool configuration
Originally posted by xtreme888
Hi,
Xtreme888
did you modify the fr one-way to become a spool?
RClover is offline
Old 03-08-2005, 10:15 PM
  #14768
Trader Rating: 28 (100%+)
Originally posted by bigl
i am thinking about buying a MTX-3 Prospec and i am wondering if the car needs any other hop-ups other then the ones that come in the kit for example the kawahara belt conversion
I prefer the car without the belt conversion, but lightening the car is always a good idea, even when the car gets to be underweight.
Scott Fisher is offline
Old 03-09-2005, 02:36 AM
  #14769
teammpp's Avatar
Default Re: Re: Re: solid front/ spool
It is very reliable. There is another screw on the other side under the pulley too. We use a different method though. We swapped the outdrives with the Serpent ones and just drilled the hole through the one way axle. Then used the Serpent pins to lock the outdrives.
Got a guy making me a proper solid axle to specs to try. The only difference will be the weight. Will be a whole lot lighter then the oneway modded.
teammpp is offline
Old 03-09-2005, 02:00 PM
  #14770
Default Front one way
Hi,
Similar to what Campbell said about the modified serpent parts with pins through, but used a c clips to hold pin in coz i lost a pin before in the final !!!! NOt very good with three wheels
drive !!!!
Xtreme888
Old 03-09-2005, 06:53 PM
  #14771
bcquick's Avatar
Default Re: Weight
Originally posted by Slotmachine
At the Nats I had to add 37g. to my MTX-3 I have the RD Logics chassie.
is you mtx-3 a prospec or standard.
what ealse have you done to get the car so light!!!!
Details,Details,,
bcquick is offline
Old 03-10-2005, 06:16 PM
  #14772
Registered User
I got a use mtx3, what cases the front belt to snap.
hunt is offline
Old 03-10-2005, 07:22 PM
  #14773
The front belt will wear out the fastest of the three belts..
The gearing between the front and rear wheels is not exactly the same. This slight difference causes a little more stress on the front belt. Periodically inspect the belts. Look for teeth that are missing or wearing out and replace them when you can see this. Also I would inspect the pulleys as they will eventually wear as well. When worn, they will wear the belts faster.
Old 03-10-2005, 08:39 PM
  #14774
Slotmachine's Avatar
Default Re: Re: Weight
Details,Details,,
It`s the old car ! I really didnt do anything else to it. I will say we ran 57mm. tires at the Nats.
Slotmachine is offline
Old 03-11-2005, 08:46 PM
  #14775
rcabj's Avatar
Default rear diff oil
hi...about to try 50K oil in the rear with fr. 1 way...
anybody has tried this and how does it handles?? thanks
btw...i usually race on small/medium tracks...
rcabj is offline
