Mugen MTX-3
Re: Lola Body
Originally posted by no4hitter
What is the best Lola body to fit the mtx-3? And where can I get it. Thanks
depending on the style, you may have to dremel the front shock tower. As long as you don't mount your shocks on the top hole, you will be OK.
help
hello guys!
im new and i want your help.i have found 2 rc cars.a ford focus tamiya xbg and a kyosho fw05s.im not thinking about races or modify.wich car seems faster and without lots of engine problems?
iil apreciate your help
Originally posted by ROBBIE C
I just checked and found out Kawahara Japan is out of stock so these belts are on back order I'll keep Atomic in form and let Tony no when they come in..........sorry
Re: Re: Lola Body
Originally posted by rcabj
do we need any changes or special front bumper to accomodate the lola body shell??
Anybody else know where to buy from....the place listed above is out of stock on all versions...thanks
Front Diff
Can someone please give me a detailed parts list of everything needed to assemble the front diff?
BB
BB
Re: Front Diff
BB
BB
it's in the instruction manual or just copy the rear diff. You need rear gear diff set, o-rings, gasket and countersink screws (3x8mm).
Before you do, let me inform you that your car will enter corner slower than cars with one way, but you get front braking and more stable at tight corners.
Re: Re: Front Diff
try mugenracing.com.....there's online manual somewhere
Mugen Diff. Pulley for MTX-3
[MU-T0220]
Mugen Diff. Gear (W/O-RING) for MTX-3
[MU-C0228]
Mugen Diff. Gasket for MTX-3
[MU-T0207]
Mugen Diff. Cup Joint for MTX-3
[MU-T0202]
Mugen O-Ring Set for MTX-3
[MU-T0210]
Mugen Roller Pin Set for MTX-3
[MU-T0802]
Square Button Head Hex Screw 3x8 15pc
[SQ-NSR-308]
I have forgotten anything?
BB
Bearing Oil
I wonder, what is the best bearing oil to use
Do you know the weight of your mtx 3 race ready ?? ( servos, receiver, battery, and empty tank ).
Standard MTX-3 with a Prospec chassis- no eye candy on the car.
Originally posted by ][)EMON][)
Bearing Oil
Bearing Oil
MOBIL 5-30 for nitro application. Stay away from the other oils they use for electric racing since our cars see alot more dirt.
