my scte is traction rolling on hi grip surface like our indoor clay track. im at 27.5wt shock oil front and rear with the losi gold springs. i have the ride height pretty dang low and put some more camber in it, feels like the camber helps but starts to effect my steering a bit. any ideas??
I need more mah than 6600 nanos , any suggestions and where to buy them? I was easy on the throttle but i limped in after a ten min main only to lose 2nd place by a half second and was 6 seconds behind 1st due to conserving lol
So.... I have had my SCTE sitting on the shelf for the last 6 mo. while focusing on other classes. But I am gonna break it out again this week and get her tuned up for some racing. What did I miss as far as hot tweeks and setups.
The last time I payed any attention the TLR tuning kit was just about to launch. and there was talk of what chassis was better. BCE, KH, bump or the tlr. lol. So... Which chassis won? . (doesn't matter I'm happy w my BCE)
What I am interested in is if there are any "new" must have options or setups.
I suppose I could go back and read a couple hundered pages but Ill never find the time to actually do that. Whatever happened to saladfork updating he first page of this thread??? I don't see anything new on there.
Thanks in advance.
Thanks in advance.
Tech Prophet
Thanks in advance.
Thanks in advance.
http://www.losi.com/ProdInfo/Files/L...ford-02_12.pdf
New diff gears were release. (same part number just updated).
Not much more then that.
Chassis--- Stick around we just got done arguing about screws so the great chassis debate is due for another go around!
promatch.com
New dunford std setup.
Seriuosly though. Are the gears just a durability upgrade? I wouldn't think a performance gain. I still have a few sets of the old gears NIP i hoarded back during the great gear shortage after the truck first launched and everyone was chewing them up because of the soft cross pins.
Yea. The stock screws are chitty. Just get a set of Tonys and forget about it.
Any and for a TLR version of this truck yet? I think it's about time. Make it come with all the goodies already installed
Xteme Carbon Chassis
I just got my new chassis, do I have to seal edges of chassis? Does anybody know.
Which motor and ESC are you running? Are you spinning the tires everywhere?
For reference I get about 400mA/minute with my Pro4/RX8.
Rx8 n 4600 with 13 tooth n yea i spin the wheels here n there , losing the habbit but cant help to drift around certain lines at my track lol running throttle profile 1 seems to generate more heat than 3 as i just tried 1 but will go back to 3
i have noticed i have gone thru few too many servo savers ... they work good for about 2 weekends and then start sticking ... they look good from what i can see ... but ive tighted and loosed it up and seems to stick .. now from what i can see the tube the saver goes around has some scratches on it , that would cause it to stick i would assume so i will need a new one ? i posted pic below ... i thought maybe too much torque from servo, im using a hitec 5996tg 180 oz @ .10 secs
Trader Rating: 171 (100%+)
My nephew and I just got back from the SC. Nats. @ rcmadness My nephew ran a Losi scte with Tekin RX8 Revtech 3800 revtech 65x65 batteries and geared 15/40. won his main and did the bump up I just changed the the battery he ran for a full 12mins. plus check in. Nothing happen to the RX8 and nothing happen to the motor. And was just as fast. we are very happy with the rx8 and rev tech set up
