Like Tree9Likes
Old 07-07-2012, 07:41 PM
  #36601
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by SaladFork
XOXO
wholey toledo batman your back!
BlackStarRacing is offline
Old 07-07-2012, 07:46 PM
  #36602
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Originally Posted by vw addict
good to be back on topic eh?
i have never cried about the thread going off topic (unlike you), so i don't get your point.
RC*PHREAK is offline
Old 07-07-2012, 08:00 PM
  #36603
Trader Rating: 38 (100%+)
Originally Posted by RC*PHREAK
actually the thread had gotten back on track until you derailed it again.
this
vw addict is offline
Old 07-07-2012, 08:02 PM
  #36604
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Have any of you guys tried the proline crimefighters on any of your vehicles? What kind of handling characteristics do they have and what kind of track conditions do they work well with?
Rockthecatbox21 is offline
Old 07-07-2012, 08:06 PM
  #36605
RC*PHREAK's Avatar
Old 07-07-2012, 08:07 PM
  #36606
RC*PHREAK's Avatar
i have used crimefighters on my 1/8 buggy. they work decent on a hard packed track with a bit of loam.
Old 07-07-2012, 08:30 PM
  #36607
Okay, my mugen truggy came with them and i was pondering whether or not to buy some cityblocks. Think i'll stick with them for now and see how they do. I run cityblocks on my scte and they are an awesome tire.
Old 07-07-2012, 08:34 PM
  #36608
steelers82's Avatar
Default ...
hey everyone,thinking about getting a losi,but im just wondering if anyone can tell me if they still have diff issues,as in leaking,or diff pins getting flat spots in them ect....or have these issues been handeld with the newer kits?.....any advice or help would be greatly appreciated
steelers82 is offline
Old 07-07-2012, 08:37 PM
  #36609
RC*PHREAK's Avatar
the diff pin issue was resolved a long time ago. the new kits are solid. as for leaking diffs, well that depends on how you build them. if you glue in the inserts with either RTV or CA, and some have had success putting a light coating of RTV on both sides of the gasket. my diffs leak just a bit. next rebuild i'm going to try the RTV on the gasket trick.
  #36610
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
I assume you mean BowFighters as P/L doesnt make a Crimefighter for SC ?
If so I think the are great tires for hard packed dirt with a loamy/dusty top , wet or dry .
I would compare them too the Losi Eclipse tires but a little better side bite .
Regular buggy Crimefighters are awesome as well when the track starts getting chewed up .
BashemSmashem is offline
Old 07-07-2012, 09:02 PM
  #36611
HighLife420's Avatar
Trader Rating: 49 (100%+)
I've been using RTV for the last 2 builds. Works fantastically. I use a little on each side of the gasket and let dry. It hasn't leaked a drop since.
Pics coming of the MIP build. Just watching the UFC fight at a buddies house.
HighLife420 is offline
Old 07-07-2012, 09:03 PM
  #36612
RC*PHREAK's Avatar
Originally Posted by HighLife420
I've been using RTV for the last 2 builds. Works fantastic. I use a little on each side of the gasket and let dry. It hasn't leaked a drop since.
so you put the RTV on each side and let the gasket/rtv dry by itself before putting on the diff cup top?
Old 07-07-2012, 09:58 PM
  #36613
4skinz80's Avatar
Trader Rating: 15 (100%+)
Talk about a Chitty fight!!!
4skinz80 is offline
Old 07-07-2012, 10:10 PM
  #36614
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Default stop diff leaks
Building these diffs is an art. Here's what I've done to stop diff leaks and also get buttery smooth diff action.
  • CA the metal inset in place
  • lightly sand the high spots in the diff case
  • Apply a very thin layer of RTV between the diff case and gasket
  • Use Mugen o-rings (part # MUGT0244). They fit better and are a hair larger than stock.
  • I've built several SCTE diffs and the tolerances have all been different for each diff. I've had some that I couldn't screw down tight because it locked out the diff. You want to have different thickness shims to place between the outdrive and the pin that holds the larger diff gear. You want to shim correctly so that you can tighten all the diff screws and still have a smooth diff. The stock shims tend to be pretty thick. Some loosen the screws that hold the diff together, but this always caused leaking for me. Just use thinner shims.
As far as the diff internals being weak, this worry is a thing of the past and should be solved.
SEF is offline
Old 07-07-2012, 10:43 PM
  #36615
You not kidding...wow...
No, put it together wet and let it dry before putting it back in, i stood it up.
Here is pics of my MIP build, cant wait to try it tomorrow.
