Like Tree9Likes
Old 08-07-2012, 06:29 AM
  #38086
TRyan's Avatar
Originally Posted by eddomak
Hi, just 2 n00b questions from me as I await my delivery:
1) With the TLR carbon fibre shock towers, is it necessary to superglue the edges to keep it from delaminating/fraying?
2) What is a 1-piece shock standoff? I am looking at the pictures and also at the explosion diagrams and can't quite know for certain - is it the part that attaches to the shock tower that the shock cap then goes around?
Thanks!
I don't glue mine and I haven't had a problem, but it can't hurt. The stock shock stand off is two piece(screw and nut) where the one piece is, well, one piece!
TRyan is offline
Old 08-07-2012, 06:51 AM
  #38087
HighLife420's Avatar
Trader Rating: 49 (100%+)
Thanks!
1) I did 1 quick brush on to make sure, i do it with all my carbon pieces.
2) Stand off is the piece that physically goes into the shock tower. Right now its 3 pieces, the 1 piece is actually 2 pieces with the nut on the end. However, the rest of it is all 1 piece.
HighLife420 is offline
Old 08-07-2012, 07:22 AM
  #38088
Originally Posted by BmainStar
Its popping at the set screw side? Hmmmm Make sure one of the two bearings is not going bad and really never seen em pop there!Any one else on this guys???
Man I feel the same way,Over a year now and still leave the track with a big grin everytime I love My truck!Some times I just stare at it like a kid trying to imagine being shrunk down so I can ride in it!Love it!!!P.S. cant wait for the 1/10th 4x4 buggy to come out so I have another 4-wheel drive to run and for those diff cups with the molded inserts we are all wishing for RYAN????By the congrats on your WIN Ryan~~~
Yes, the shaft has come completely out on two occasions and the set screw is still in place. I'm not sure what could be causing this other than the set screw came loose or the little slop in the ring and pinion gears. I was thinking of shimming the pinion to achieve a better mesh. I never had this issue with the stock shaft.
Stevemopa is offline
Old 08-07-2012, 08:13 AM
  #38089
DanielHolloway's Avatar
bro, is there any way for you to post a photo of this? I was having the issue of throwing the pin, happened a few times, but since the setscrew came out, it's been fixed. Kinda wondering how this happens.
DanielHolloway is offline
Old 08-07-2012, 08:27 AM
  #38090
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Casper
Ok blame the euro durango guys. Jorn has been running spoilers on the Durango 4X4 for a while and did again at shootout and cactus so Ryan tried it out then. Until someone puts there foot down it is going to continue I think.
Very disappointing that they're getting away with it at bigger races that should know better.
MarkA is offline
Old 08-07-2012, 08:50 AM
  #38091
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Whats funny too me is THEY (Team Durango) are seasoned racers and they probably know that the wing is not legal to race with but are doing it anyways ? Thats basically cheating IMO .....
BashemSmashem is offline
  #38092
duplicate post !
Old 08-07-2012, 08:58 AM
  #38093
Briguy's Avatar
Trader Rating: 125 (100%+)
The only way it is not legal is at a ROAR event .
Briguy is offline
Old 08-07-2012, 09:55 AM
  #38094
goehm's Avatar
Trader Rating: 45 (100%+)
Not true. Any track can follow ROAR rules, or implement their own, or if hosting a sanctioned event defer to that organization's rulebook. Any of which can make that wing (spoiler) illegal.
Is it done? Clearly not all the time. But there are plenty of non-ROAR races that don't allow wings.
Unfortunately, if an organized race has no rules to govern wing wing legality, then there are probably no rules governing body (probably only rules regarding electronics and such) and can thus you can run anything on a SCT dimsensioned platform that you want. Why not just use a baja bug body and a wing.
Now all that said, does IFMAR even address SCT?
And to make it more confusing, I understand that at lower level/local ROAR events a lot of the rules are discretionary - so even at ROAR events you could run a wing. But not much much at the nationals. How many are DQ'd for not having headlights?
Anyway, they just look stupid. Case closed. =)
goehm is offline
Old 08-07-2012, 11:19 AM
  #38095
Not really much a pic would show, just the driveshaft thrown out. This is not a stock shaft it is a Tekno. I switched to Tekno after throwing a couple of CVD pins in the stock front shaft, problem solved on front. My issue is in the rear after switching the stock shaft to Tekno. I haven't thrown any pins with the new shafts, just lost the entire rear shaft a couple of times. Guess I should crank that setscrew a little harder, but I still wonder about the mesh in the ring gear.
Steve
Old 08-07-2012, 11:38 AM
  #38096
Casper's Avatar
Trader Rating: 34 (100%+)
Thanks!
You can seal them but most do not and I have not heard of any problems. Being the towers don't see direct impact as they are protected by the body and the sides like a chassis do not get pulled seems to not be an issue.
The one piece shock standoffs are for the upper shock mount. They elminiate the long screw with the lock nut to a once piece design that is easier to move the shock position.
Casper is offline
Old 08-07-2012, 12:08 PM
  #38097
TCCustoms's Avatar
No issue here with the TLR rear hubs...other than I dropped 1 of the plastic spacer/shims between the hub and arm so had to improvise on that! But new chassis and deal bearing mount from KH will be here tomorrow....WOOT WOOT!
TCCustoms is offline
Old 08-07-2012, 01:48 PM
  #38098
Default traction roll
my scte is traction rolling on hi grip surface like our indoor clay track. im at 27.5wt shock oil front and rear with the losi gold springs. i have the ride height pretty dang low and put some more camber in it, feels like the camber helps but starts to effect my steering a bit. any ideas??
empire39 is offline
Old 08-07-2012, 01:54 PM
  #38099
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Some may disagree, but limiting front droop and having the correct tires are my go to methods of stopping traction roll.
SEF is offline
Old 08-07-2012, 01:56 PM
  #38100
i actualy raised the front ride height a bit, it sits a lil higher in the front. im just above level with the drivelines in front and sitting a lil below level in the rear. im using barcodes on clay.
empire39 is offline
