Like Tree248Likes
Xray XB4 thread
Old 10-17-2018, 08:35 AM
  #12976
Originally Posted by LAGuy
Less anti-squat would help. When you move the rear pins to adjust, use the highest position for the pin (Raise roll center). If you need more, 3.5 rear toe as well. These adjustments will add rear traction.
-High Rear Pivot Pin
1* Anti-squat
3.5* rear toe
thanks
would the medium rear arms and medium chassis brace help as well?
rippen likes this.
snowninja is offline
Old 10-19-2018, 08:12 AM
  #12977
Originally Posted by snowninja
thanks
I've tried the medium plastics and anything other than extreme loose conditions, I don't think they are worth the effort. The medium front arms do offer a nice tuning option for the front, say indoor clay when you need a touch more steering.
LAGuy is offline
Old 10-25-2018, 02:46 PM
  #12978
Originally Posted by Jake S
Mines on order! Everyone is outta stock right now! It sucks..
WuNgUn is offline
Old 10-27-2018, 05:55 AM
  #12979
Trader Rating: 166 (100%+)
I've had mine for a week. haven't even opened it up yet
jpcopeland1 is offline
Old 10-27-2018, 11:11 AM
  #12980
Does anyone have a recommendation for a good machine shock piston for a 2018 xb4?
I love this car but I still can't seem to get my suspension dialled like on my b64.
Maraach is offline
Old 10-29-2018, 09:22 AM
  #12981
snwchris's Avatar
Try using the Avid or Schelle shock pistons.
I have the Schelle 2x1.6 hole pistons and then drilled (2) 1.1 holes as by-pass holes in them and using for my 16 XB4
Car is super stable and planted.
snwchris is offline
Old 10-29-2018, 02:57 PM
  #12982
I have a strange problem. I ran my XB4 for the first time on carpet this past weekend with a 6.0 mod motor. The car felt fine but the majority of my runs, at about 4 minutes in, one of the front wheel nuts would fly off along with my wheel. I am running the stock 4mm serrated nut, 1 slot hub, stock drive axle and premounted Schumacher wide stagger tires. Has anyone else experienced this issue? I am thinking of using blue loctite and seeing if that solves the problem if nothing else.
Kelseyrc is offline
Old 10-30-2018, 03:44 AM
  #12983
Trader Rating: 90 (100%+)
get these https://www.amainhobbies.com/yokomo-...-n4flt/p541494 the serrations are really aggressive. I doubt you would have one come loose again.
b121774 is offline
Old 10-30-2018, 08:02 AM
  #12984
This happened to me as well. It was the result of a damaged wheel, although the wheel seemed ok. Change the wheel and see if it goes away.
LAGuy is offline
Old 10-30-2018, 09:49 AM
  #12985
snwchris's Avatar
When you mount the Schumacher wheels onto hub, see if there's still a gap, you might be running out of thread engagement and need to use a washer against the wheel and serrated nut.
rippen likes this.
snwchris is offline
Old 10-30-2018, 10:19 AM
  #12986
Trader Rating: 17 (100%+)
Just picked up a used 18, does anyone know if my YZ4 SF body will fit? I know that someone slightly modified a xb4 body to put on the sf, just curious if the reverse is possible.
MrLean is offline
Old 10-30-2018, 10:48 AM
  #12987
Thanks! I'll try a set. It got so bad that I ran a 13.5 motor instead just so that I could finish a heat. With the milder motor I didn't have another wheel fly off so I'm thinking it has to do with wheel flex from the additional force of the mod motor and the nut serrations disengaging lap after lap until it finally completely unscrewed.
Kelseyrc is offline
Old 10-30-2018, 07:52 PM
  #12988
Pville Stig's Avatar
I had the same thing happen at the Reedy Race this year. It was mostly happening under braking. Once it happens typically the hex on the wheel is shot so you'll need to replace the wheel and definitely go with some other type of lug nut. Also get them on as tight as you can. I ended up going with a locknut.
Pville Stig is offline
Old 10-30-2018, 08:10 PM
  #12989
Team EAM
Trader Rating: 79 (100%+)
Ive had one sitting in my shop for almost two weeks! Sold one first day and 2nd is still there.
EA
EAMotorsports is offline
Old 10-31-2018, 07:06 PM
  #12990
Have a used 2018 being shipped to me as we speak. I am going to go through the car and freshen it up. Any Suggestions on which wear parts to replace? I’m going to start with the shocks, diffs and slipper. Can anyone confirm if a associated spur/pads and associated xrings will fit? Has anyone ever tried yokomo yz4 sf spurs or xrings? I’d like to support my LHS if possible and they don’t stock X-ray sadly
MrLean is offline
