Xray XB4 thread
I run mine in front of the diff and use a 3d printed holder to secure it in place. It keeps the wires out of the way and relatively short.
Do the 81mm ecs shafts work on the 23'? I know they show up as options in the manual but do you have to run arms narrower?
Curious if anyone has found a way to run a 26t pinion (or higher) with a 78t spur in a 13.5t 23' dirt car? When I tried it the motor mount ends up being in the removal position and could possibly move aft during a hard landing.
Guys, i own a 2019 XB4 and wanted to know if i can run 75/29 Gear Ratio with a 17,5T or what would be the recommended gear ratio?
Thanks.
Alex
Thanks.
Alex
Wheels
Hey,
Will these wheels work on the '23 x-ray xb4d?
Speedline Buggy Wheels for TLR 22X-4 / Tekno EB410 / Front / BLACK / 4Pcs
DER-SB4-L4B
Speedline Buggy Wheels for Associated B6.1 - B64 / TLR 22 - 22X-4 / Rear / BLACK / 4pcs
DER-SB4-ARB
DER-SB4-L4B
DER-SB4-ARB
Are there diff outdrives from other manufacturers/cars that fit the xb4? I bought a used 2014 and the outdrives are a little worn but replcements from xray are mega expensive.
You could try the kit breakers on eBay - they will often sell a complete diff for less then a pair of new outdrives from Xray
Would anyone be able to measure the distance between screw holes on a 2024 version wing mounts please? Hoping it's 29mm center to center for the wing button screws (the red line marked)
I get 29.6mm.
2024
