SC10 4x4 Thread
#7666
Should be perfect. 201 oz-in of torque is more than enough and .10 is acceptable. I'm running a 9100s in mine which is 180 and .06. It will lift the truck up fine when it's on its side.
#7671
yeah thats why I was asking. I think the speed is really fast as well. Works great in 1/8 buggy just thought it may be to fast in this truck. Still need to get a esc and motor and lipo yet. Should I go with a 540 motor or 550? Also what mah lipo and c rating
#7672
550 is a bigger can, so it will run cooler. But it also weighs more. 5000 mah is a good racing battery. Its nice to have 40C or more.
#7675
Havok sc pro 550 4.5 shuts down my receiver every lap or so for 1 to 3 seconds with 5400 25c lipo 2s. I changed to 5200 35c 2s and problem goes away. Go back to 25 c problem comes back. Any thoughts. Would esc timing have any effect. Just curious I now run a 5600 50c 2s w/o any issues. Seems like 135a would be sufficient but is not?
#7677
pack and see if you have that promblem again.
#7679
I would say the lipo. Since you ran a diffrent battery and the promblem went away. Then you go back to the other lipo and you still have the same promblem. It could be the C rating that made a diffrence, or the 25C pack could of been older and not working as well as the other pack you tried. The only way to tell if it was the C rating would be to try anothet 25C
5Likes
