SC10 4x4 Thread
#7816
So I got the kit, Savox servo, MMP esc, and a Tekin 4.5 motor. Is there any other parts that are needed that either break or wear out faster than normal. I like to have the spares on hand and would rather make one order. Sp far I have:
front/rear sway bars
aka grid iron tires
de racing wheels
flanged serrated wheel nuts
yellow front/rear springs
shock o-rings (forgot the name but they are the smoother ones)
rear hubs
steering/castor block
14 tooth 32p pinion
ht slipper pads
factory team wheels hexes
62/60 spur 32p
cva rebuild kit
st racing front a arm mount
st racing rear a arm mount "3-2"
factory team cvs pin retainer
st racing motor mount plate
factory team shock pivot ball set
ofna aluminum servo horn 25t spline
novak 550 heatsink
differential o-ring set
Anything else anyone can think of before I complete this order. Not into major racing so the light weight parts are not needed.
Terry
aka grid iron tires
de racing wheels
rear hubs
14 tooth 32p pinion
ht slipper pads
62/60 spur 32p
cva rebuild kit
novak 550 heatsink
Terry
#7818
I have a SpeedPassion V2.0 5.5R motor with 5mm shaft and I need to know if this motor is a 540 or 550. The motor had a product insert and had it as 540L motor which I have no clue what the L stands for. I've been away from electric RCs for the past 2-3 years and been doing nitro during that time, so I have no clue of the recent advancements of BL motors nowadays.
If I understand correctly, AE suggests to use 32P spur/pinion gears for 550 motors and 48P for 540. My problem is that I already purchased a 13T pinion for my kit and now I'm not sure if the motor I have is a 550 or 540. If my motor is in fact a 540, do I have to buy 48P pinion gear that can fit a 5mm shaft or can I still use the 32P spur/pinion gear set-up?
Thanks in advance for the help and pardon me for asking silly questions.
#7819
#7820
Tekins Pro4 are 540 cans and have 5mm shafts, as well as the newer versions of castles 1410 540 motors will come with 5mm shafts as well...........
#7822
32p, I don't think there are any pinions (if so they are hard to find or I haven't seen any) in order to run a 5mm pinion with a 48p spur..........Now on the older castle versions that have the 3mm rotors you can run pinions without the adaptor to run a 32p spur...........
#7823
I just rebuilt the front end of my truck and boy are the front arms sagging like the rears did. RPM will have the new arms out next week for the truck. I will get some of those.
I think it has been talked about before in here , My rear transmission shaft has developed a good bit of play, I think it may be from before I got the clutch basket and the slipper was slipping and heated up the shaft which will start to melt the case if it gets bad enough I guess. I guess the question will be who is going to make an aluminum case for the truck?
#7824
#7826
#7828
Rick Howart posted he flipped the steering rack around to change the ackerman in order to make the truck easier to drive, but had to grind the s### out of it to make it work.
Has anyone tried it yet?
#7829
#7830
I talked to him about it. and the very next day i saw the truck at the showdown. it had a custom carbon piece that was straight instead of the stock one flipped... got one in the works hope to soon see. I Also pinned my front drive so the truck is totally different. the reason we are not seeing these trucks in every race in the world is because they (AE) are still obviously testing.
5Likes
