SC10 4x4 Thread
#7066
You know, I wasn't expecting much when I bought the Sidewinder/1410 combo (I bought it primarily for the motor) but I'll tell you...the thing's been bulletproof and so quick...best $100 I've spent in awhile!
Cheers,
Mike
#7067
Don't have my kit yet (out of stock - Amain) but would like to know what would be the best diff and shock set-up...have no plans of racing.....kit would be a project with my daughter. My ECS/BL motor combo would be the SP SA Ver2 with SA Ver2 5.5R (550 motor) and 5000mah 3S1P 11.1V 40C hard case Lipo battery (which I know may have to modify the kit for it to fit).
Thanks for the quick response.
#7068
#7069
Lol I ust realized who you were. I wont be to LSR until maybe next Thursday. To many things going on. We can battle with your buddy in the black truck.
#7070
#7071
#7073
The stock tires will be just fine to mess around with if your not racing, and just make sure to refill the front/rear diff's and shocks as well with whatever weight you like......... Also go easy on the throttle and braking for the first 10 packs or so because you may snap the belt very easily since it needs time for break-in...........
#7074
Tires (depending on track you race at)
Clutch Basket
Hi-torque slipper pads
Diff/shock oil
Shock springs (can buy the set or just the ones you want to run individually to save on money)
Trackstar o-rings
Factory team wheel hex's
And a very good servo that will lost a long time so you don't have to tear down the front just to change it out..........
#7075
Front/rear swaybars
Clutch Basket
Diff/shock oil
Trackstar o-rings
Clutch Basket
Diff/shock oil
Trackstar o-rings
and what are the diffrance in the track star orings?
and why the wheel hexs?
#7076
The trackstar orings help to prevent leakage from the shocks, and the Factory team wheel hexes are just better then the stock and will help to prevent any binding issues.....
#7077
The clutch basket helps to prevent the slipper from slipping to match and helps the slipper pads to last much longer, pm mactheknife on here he sells them........
pm him.
#7078
mine has been great too other then the cheap fan crappin out on me but castle waranteed it for me no questions asked . i like castle and most of there products the only thing i dislike is the switches they use are garbage and i dont like the idea of soldering the wires together . my mamba has been bullet proof in my truggy and i beat the crap out of it . cudos to cc
#7079
Better yet, just go to my website, and click a button. http://gearrings.weebly.com/rc-racing-stuff.html
5Likes
