Like Tree5Likes
SC10 4x4 Thread
Old 09-23-2011 | 10:33 PM
  #7696
xDIEGOx's Avatar
^ Stick with regular wheels. The only good thing about beadlocks, is they look cool. They add unnecessary weight/stress on the drivetrain and dirt gets in the tires pretty easy.
xDIEGOx is offline
Old 09-24-2011 | 12:03 AM
  #7697
MiDGet's Avatar
running the clutch basket setup....
Love it love it love it love it! But DAMN... on tar, i can make it stand on the rear wheels anywhere in the throttle range... its rediculous. its impossible to give it the full beans... i love it! but i am going to need to pull the power back.. but how?
the nut on the clutch is flush.
i have no timing advance on the motor and esc. im running a little 12T pinion.
not complaining. just wanting a little 'less'.
MiDGet is offline
Old 09-24-2011 | 06:23 AM
  #7698
Ummm no it doesn't. I've been running them on my 2wd sc and they r great. I dont get
dirt in my tires, I can swap tires at will at the track in like 5 minutes. I reuse my foams
when I change tires. I have yet to see down side to them. They have saved me a
tremendous amount of money because all I buy is tires. As far as weight, yes they are
heavier, but with a 10.5 I haven't noticed a difference in performance.
Mark K is offline
Old 09-24-2011 | 06:42 AM
  #7699
Mac The Knife's Avatar
R/C Tech Elite Member
Are you running the HD pads in the basket? if so, put two of the standard pads in there. Less surface area=more slippage.
Mac The Knife is offline
Old 09-24-2011 | 07:04 AM
  #7700
Jerm13's Avatar
Hey guys, I finally got my beast fully assembled ( according to the kit instructions and tips on the first page of this post) but its been raining here for like 2 weeks straight and I have yet to drive it on a track. I have dumped 2 packs on the street just to make sure everything works and to adjust steering trim and minor stuff. I need a good starting set-up. I pretty much have the book set-up. The tracks I run range from loose to black groove and tight, technical to wide oper hammer down. Here is what I have now:
20t drive pullies both F and R
Camber -1 all around
Shock Oil 30 F and 25 R, 1.2mm pistons F and R
5k in both Diffs
Ride Hight 26mm F and 28mm R
Tekin RX8 with 4.5 550 motor
Gearing 13/62 (32P) Also have 12 and 14. Temps at 140-150 after about 8 minutes of street running ( mostly full speed with body on)
I got 3 full sets of tires JC Subcultures and DD's, and PL Calibers all on stock wheels.
I am running everything stock ( ie. no hop ups or option parts)
Sway bars are on order and will be added soon.
Anybody have any sugestions. Diffs or shock oils, ride hights, what ever?
I cant wait to run this thing on a track!
Jerm13 is offline
Old 09-24-2011 | 07:37 AM
  #7701
Chad Smith's Avatar
5k in both Diffs
The truck is a blast to drive! I would run it the way you have it, and see how you like it. Im running almost stock setup and love it.
Chad Smith is offline
Old 09-24-2011 | 07:50 AM
  #7702
i found that the emulsion shocks felt better than the bladder style.
captaindemo17 is offline
Old 09-24-2011 | 07:53 AM
  #7703
symmetricon's Avatar
+1 to that. the bladder style seem to pack to easily, causing the truck to bounce all over in the rough stuff.
symmetricon is offline
Old 09-24-2011 | 08:00 AM
  #7704
The stock bladders are way too stiff and only get worse with age. I ended up using the bladders from another 13 mm shock and it feels so much better.
Krio is offline
Old 09-24-2011 | 08:04 AM
  #7705
What or which bladders?
Old 09-24-2011 | 08:05 AM
  #7706
my bladders were crap from the get go. i had to replace them before even running the truck. The bladder shocks were good but the track i run on didnt favor that type of shock. It was a night and day difference just by changing from bladder to emulsion. Over all the truck is good but i am going to try another brand as this thing isnt a gem to work on
Old 09-24-2011 | 08:14 AM
  #7707
Most 8th scale buggy shocks use to be about 13 mm bore before everyone went to 15-16 mm big bore shocks. I grabbed some Caster 'high efficiency' bladders since I had easy access to them.
Krio is offline
Old 09-24-2011 | 08:17 AM
  #7708
TocSin's Avatar
Originally Posted by CoyoteSlash
That makes me laugh a little. .10 is mooooooore than fast enough.
I said it should be perfect .10 is right in the middle of my personal steering servo 'range' and acceptable doesn't = bad. I wouldn't run slower than a .13 for steering in anything, and I usually aim for .08 on most of my 1/10 scale rigs.
I don't understand the 'too fast' argument. If it's twitchy on the straight, add a bit of expo, but I want reaction as fast as possible to recover if the rear end is loose or to fly it if you're pitched from a bad or in turn launch. You're in the air for ~ .5 seconds at a time in the rhythm sections and on the ground even less in them.
TocSin is offline
Old 09-24-2011 | 08:22 AM
  #7709
CraigMBA's Avatar
Try running a 4.5 and get back to us.
Seriously, with the softer compound tires, I see guys in 17.5 2w having problems unbeading tires, not where they fall completely off, but where they have to work on tires every round remounting them on beadlocks.
I am curious what tires/compounds you are running with success at your local track. I think you could run the kit tires with beadlocks no sweat.
It is pretty easy to reuse CA style wheels if you trim the tire down to the beads first, and then cook them at a heavy boil for about 15 minutes. Let them cool, and then spear the remaining bead with a fork. Peals right off, the remaining CA flakes off with minimal effort.
CraigMBA is offline
Old 09-24-2011 | 08:25 AM
  #7710
CraigMBA's Avatar
I have used servos that "claimed" to be in the .08 range. My XP1015 is way faster than those ever were, even though the rated speed is slower. Might be the torque.
CraigMBA is offline
