Like Tree5Likes
SC10 4x4 Thread
Old 08-14-2011 | 08:36 AM
  #6196
Originally Posted by BlueGlowBoy
I cannot believe these words. He didn't say "ThunderbirdJunkie thinks you need to learn....."
looks like someone got to him a little bit.....
evilllempire is offline
Old 08-14-2011 | 08:44 AM
  #6197
kromesoldier's Avatar
Originally Posted by northkona
another one to try is the wheel nuts off an HPI Blitz , they are serrated as well . Come to think of it, the ONLY useful part on a Blitz !
If I don't recall I installed the wheel nuts from the slash 4x4 on my sons sc10 4x4. They are serrated on the back as well. But I only did it because it was mentioned in here. Lot of good stuff on this thread. It's a good idea to read this thread before you build your truck.
kromesoldier is offline
Old 08-14-2011 | 08:53 AM
  #6198
nmdesertracer's Avatar
Originally Posted by RC10Nick
I ran my truck for the first time yesterday, and was not very impressed with the stock setup. I felt the car was too unpredictable (I think this is because of too much body roll and front/rear weight transfer), and despite it's very responsive and massive (ie, too much) steering, had a very hard push in tight corner.
I run on your generic med traction smooth clay outdoor track with a very tight and technical layout. The truck is completely stock. I have a set of sways on the way as well as a set of aka enduros.
I think what I want to do is; take away some high speed steering, either add low speed steering or make it possible to break the back end loose to get it around tight turns, and reduce roll and weight transfer. What are some things I should look at to accomplish this? The sways will help the roll, but is there a way to reduce roll without sways? I'm thinking about going to stiffer springs to reduce the weight transfer. It sounds like running a thicker front diff fluid will help take away some steering. Will that help or hurt my low speed steering? If I make it easier to break the back end loose, I worry I'll reduce the overall stability of the truck.
Am I on the right track with my thinking? Help would be appreciated. I have seen what this truck is capable of doing and can't wait to get it dialed!
I would wait for the swaybars to come in they help out a lot. AE should have put the swaybars in the kit. If your in a pinch I would try heavier shock oil or small dia. hole in the shock piston all around till the swaybars come in. Then get the spring kit to set it up proper. I run 7 in the front 4 in the rear on the diff fluid but our track is real loose.
nmdesertracer is offline
Old 08-14-2011 | 08:56 AM
  #6199
Lowes hardware store carries the wheel nuts. Just get the nuts and the washers come in a bag of 8 for under 200 pennies..
Old 08-14-2011 | 09:22 AM
  #6200
Vegatron75's Avatar
Ran outdoors last night. Big, fairly blown out track. Sc104 did well. I ran enduros and my indoor set-up/gearing.
Ran 10min main, used 4200mah, with MMP/3800.
Truck felt great, better than my RC8 that's for sure, and was really easy to drive. I did put in about 25% expo on the throttle, for the blown out conditions, actuallly they watered some near the end and it was much better.
Had about 8 trucks or so in the main, mostly sc104's and a couple losi and a slash I think.
Poduim was all AE!!!! So much for the AE indoors and LOsi outdoors theory.hahahahahaaaaaaaa
Oh yeah, I forgot to mention I won... Would've won the gas buggy class but I went 'tard mode around the 15min mark, and broke it. 20 min mains ain't no joke..... hard for Vegatron to keep his head in the game fo that long....
Vegatron75 is offline
Old 08-14-2011 | 10:20 AM
  #6201
CraigMBA's Avatar
This. At a minimum users should memorize CraigV's sticky first post, but the whole thread is really gold because you can learn all the problems people have as they beat their trucks like rented mules.
CraigMBA is offline
Old 08-14-2011 | 11:04 AM
  #6202
Artikbot's Avatar
Guys, what ya think about running a Savox 1251 on this truck?
I can get one BNIB for real cheap (30% off retail price), the new ones with camo sprayed heatsink.
I'm not rough by any means, but the servo will work pretty hard, as the track has continuous subsequent turns.
I burnt down a Bluebird after 15 packs; I want this one to last at least a season (that is around a hundred packs).
I know it's made for touring, but will it work?
Thanks!
Artikbot is offline
Old 08-14-2011 | 11:10 AM
  #6203
Jstall7543's Avatar
The ROAR Electirc 1/10th Nats are also taking place this weekend at No-Cal Hobbies in CA, Jason, Rich and John are out trackside, helping the team and*covering it all.*For JConcepts, Ryan Maifield* TQ’d the first three rounds of Modified Short Course guaranteeing him an overall TQ for the class.
It's a good thing T-bird wasn't there. Lol!
Who makes American tires for RC's?
Who makes American RC cars?
Jstall7543 is offline
Old 08-14-2011 | 11:45 AM
  #6204
Jstall7543's Avatar
I just read proline makes their tires in the USA, there's one company. I think Panther maybe too.
Old 08-14-2011 | 12:21 PM
  #6205
Buckaroo's Avatar
What's the prefered method for deglazing slipper pads?
Buckaroo is offline
Old 08-14-2011 | 12:40 PM
  #6206
Artikbot's Avatar
Some sanding with fine paper, 500-600 grit. Just sand until you see there's no glazing. And only sand where there's glazing, of course
Any light on the servo?
Artikbot is offline
Old 08-14-2011 | 12:50 PM
  #6207
Matt Howard's Avatar
Maifield TQ'd 2wd shortcourse, Lutz TQ'd 4wd shortcourse
Matt Howard is offline
Old 08-14-2011 | 01:07 PM
  #6208
1Fastpede's Avatar
yes, but there argument was on Chinese tires and i think he was saying the Chinese tires tq'd that class.
1Fastpede is offline
Old 08-14-2011 | 01:16 PM
  #6209
CoyoteSlash's Avatar
I retort one time and what have I started?
CoyoteSlash is offline
Old 08-14-2011 | 01:20 PM
  #6210
Farmer_John's Avatar
I keep a green scotchbrite pad to scuff rims anyway, so I just use that.
Farmer_John is offline
