Like Tree5Likes
SC10 4x4 Thread
Old 08-14-2011 | 01:12 AM
  #6181
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by CoyoteSlash
I wouldn't dream of telling Junkie to put what he doesn't want on his rig. Please... Not the lotion again...
PS: telling someone they're wrong about something that has been directly involved in winning more races than you or I ever will, is pretty laughable. Quality/USA or not.
Dude, you need to learn to recognize sarcasm and a jovial tone when you read it. Get over yourself. Seriously.
T-BirdJunkie is offline
Old 08-14-2011 | 01:44 AM
  #6182
CoyoteSlash's Avatar
Sarcasm, Heh. Okay.
Barry, Someone correct me if i'm wrong, but the timing on those is technically cheating. You shouldn't be increasing the timing at all. Unless you're bashing.
CoyoteSlash is offline
Old 08-14-2011 | 01:47 AM
  #6183
mrjeremyaaron's Avatar
Those FT Hex hubs really help that annoying bind issue when the plastic hexes are actually snapped onto the Pin. It wasn't a super issue for my kit, but these make it really nice.
Quick question for everyone out there regarding the FT hexes: will this stop my wheel nuts from undoing themselves every 5 laps?
This issue is really bunching my undies. I have tried new wheel nuts, tightened them right up, applied tyre glue, tried lock tight etc, but they still come undone. More so on the rear wheels than the fronts. I can't last a 5min race without getting wobbly rear wheels.
Anyone else have this problem?
mrjeremyaaron is offline
Old 08-14-2011 | 01:50 AM
  #6184
Default tyre gluing
Also, what size tyre mounting bands should I be getting for this truck - will 1/8th scale bands work???
Thanks in advance.
Old 08-14-2011 | 02:14 AM
  #6185
murky123's Avatar
Hey, ThunderbirdJunkie doesn't like their chintzy fake Chinese polycarbonate with bubbles, striations, and unmelted resin in it, or their fragile wheels, or their tires. If you want to argue about it, go start another thread. ThunderbirdJunkie will continue to like companies that make stuff here, in the US, that is higher quality....for the same price as the JC stuff. It's bad enough our SC10 4ws are made outside of this country and has QC issues, don't try to convince ThunderbirdJunkie to put more crap on it from outside this country.
Is this also sarcasm and a jovial tone ?
Or do you really mean that.
Are you that guy that thinks that made in the USA is always the best / superior ?
And everything else is bad?
So any issue with the sc10 4x4 is the cause of beeing produced outside the USA ?
murky123 is offline
Old 08-14-2011 | 02:27 AM
  #6186
Jstall7543's Avatar
JConcepts is a Florida-based R/C design and manufacturing company. Owner and president, Jason Ruona, has been involved with Radio Control cars since the 1980's. Early beginnings include building and driving such vehicles as the Tamiya Clod Buster, the Team Losi JRX-T and Associated RC10 and RC10T. The 1990's were spent as a Team Associated travel team driver racing at events all around the world. Now, decades later, Ruona is proudly selling quality kits, bodies, tires and accessories to R/C racers around the world.
Accolades for the company's products in both gas and electric include:
IFMAR World Champion
ROAR Modified National Champion
European Champion
Cactus Classic Champion
Hot Rod Shootout Champion
Losi Race Champion
ROAR Stock National Champion
Jstall7543 is offline
Old 08-14-2011 | 02:31 AM
  #6187
Jstall7543's Avatar
No its just you.
I like the ofna aluminum serrated nuts from NitroHouse, they stay tight!
look in the SC10 4x4 parts section. never had one of these back off!
Old 08-14-2011 | 03:13 AM
  #6188
Get the Traxxas Alum nut (4) - They cut into the wheel and are a bitch to get off, Which is a good thing.
(edit, those nitro house would work too, i'm sure)
Old 08-14-2011 | 03:43 AM
  #6189
northkona's Avatar
another one to try is the wheel nuts off an HPI Blitz , they are serrated as well . Come to think of it, the ONLY useful part on a Blitz !
northkona is offline
Old 08-14-2011 | 06:42 AM
  #6190
Just tried a new method (for me) to make venting holes in tires already mounted. Just take your beloved dremel out and put an engrave tool in it. Pinch the tire on its sides then you will not get any foam insert. Carefully drill a hole with the dremel. Extremely fast and easy, and the holes are nice and round. This will be my method from now on.
macke is offline
Old 08-14-2011 | 07:20 AM
  #6191
RC10Nick's Avatar
I ran my truck for the first time yesterday, and was not very impressed with the stock setup. I felt the car was too unpredictable (I think this is because of too much body roll and front/rear weight transfer), and despite it's very responsive and massive (ie, too much) steering, had a very hard push in tight corner.
I run on your generic med traction smooth clay outdoor track with a very tight and technical layout. The truck is completely stock. I have a set of sways on the way as well as a set of aka enduros.
I think what I want to do is; take away some high speed steering, either add low speed steering or make it possible to break the back end loose to get it around tight turns, and reduce roll and weight transfer. What are some things I should look at to accomplish this? The sways will help the roll, but is there a way to reduce roll without sways? I'm thinking about going to stiffer springs to reduce the weight transfer. It sounds like running a thicker front diff fluid will help take away some steering. Will that help or hurt my low speed steering? If I make it easier to break the back end loose, I worry I'll reduce the overall stability of the truck.
Am I on the right track with my thinking? Help would be appreciated. I have seen what this truck is capable of doing and can't wait to get it dialed!
RC10Nick is offline
Old 08-14-2011 | 07:25 AM
  #6192
mxracer458's Avatar
I just mounted a set of Aka rebars to some de wheels,i just noticed I have
No vent holes in thewheels,i run on wet med bite clay so I don't have to worry about dirt getting in,but as far as venting or no venting will it change the handling with holes or no holes?
mxracer458 is offline
Old 08-14-2011 | 07:44 AM
  #6193
lol.....oh please. EvilllEmpirE definitely knows T-BirdJunkie is just plain Ignorant now
evilllempire is offline
Old 08-14-2011 | 07:45 AM
  #6194
Artikbot's Avatar
With open cell foams it will change drastically. With closed cell foams, not much of a difference.
Must foams are closed cell nowadays, so it shouldn't really make that much of a difference.
I run with no holes at all, only inner side of the tyre glued to the rim, the outer side stays in by pressure.
Air kinda vents a lil' bit through there, I don't have any issues with the tyres coming out of the rims, and there's no dirt going inside.
Artikbot is offline
  #6195
BlueGlowBoy's Avatar
I cannot believe these words. He didn't say "ThunderbirdJunkie thinks you need to learn....."
BlueGlowBoy is offline
