SC10 4x4 Thread
#6031
here is an old issue but looking to see if there is a new answer from more use on the vehicle.
What are people doing about the little glue holes on the stock rims? has it been common now to just fill them or, do people vent the actual tire like 1/8 tires so the dirt has somewhere to go?
#6033
On mine, I use one solid piece of electrical tape around the wheel to cover the two oversized holes on the inside and keep the wheel mostly in balance, then I cut two 1/8th" holes on opposite sides of the tire, right in the middle of the tread. Glue the inside bead to the rim, glue the sidewall to the rim, glue the outside bead to the rim, then put a small squirt of glue in each of the 30 odd little holes. Seems to work great for me!
#6036
#6037
Seriously though...I had 1 of my X-rings malformed...either because of abuse on my side (not likely as I noticed the issue before the truck hit any jump bigger than a piece of pegboard attached to a 2x4....) or because it came that way (manufacturing defect or assembly error by an 8-year-old in China....)
check that your X-rings are OK....if they are, get some Trackstar O-rings... if one or more are malformed, contact AE first....since I have rebuilt my shocks with all good o-rings, my shocks are pretty smooth....sooner or later I'm going to break down and get the trackstar o-rings just because I want to see the difference between them and a full set of properly formed X-rings....
#6038
Just a thought, and I'm sure someone else has thought of it as well, but has anyone tried the shorty packs in the truck yet? I've heard of the saddle pack setup, but I think if you mounted the shorty pack directly under the belt housing in front of the rear brace, installed the receiver on the left and esc on the right, the truck may be well balanced. I think I will give this a shot......
#6039
#6041
had a good day at the track today. I went to a 60t spur and 15t 5mm pinion with adapter. No issues with dogbones/spur gear/pinion/ or slipper. Truck ran great. There were 3 sc10 4x4s there. All running castle 1410s and mine was the fastest out there. I spent a lot of time driving my losi eight e 2.0 and have to say I love my SC10 4x4 more then my 1/8 scale buggy.
#6043
Ty Tessman's Nitro Stampede Setup is now posted.
5Likes
