Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-27-2010 | 09:02 PM
  #3856
TommyBlazin's Avatar
iceman, phat scheemz paint, deans a good friend of mine, lives 20 min away, are you near nj, or bx area? as i might be interested in a pipe to experiment :^)
TommyBlazin is offline
Old 08-27-2010 | 09:18 PM
  #3857
im from jamaica, queens as well right now i live in mass.
icemandolmite is offline
Old 08-27-2010 | 09:20 PM
  #3858
my boy gary h. is from there, he runs 1/8 onroad.
Old 08-28-2010 | 08:17 AM
  #3859
houston's Avatar
Tech Prophet
those engines that icemandolmite are selling are in great shape , they just came out of my shop , not sure if he ran them after they got back
houston is offline
Old 08-28-2010 | 08:20 AM
  #3860
houston do u do onroad as well, ,my mrx5 is about to drop<thankgod>lol been a LONG wait,gonna be sweet racing on AND offroaD..
Old 08-28-2010 | 08:37 AM
  #3861
houston's Avatar
Tech Prophet
do i do onroad engines or do i race onroad?
you gotta be a paid member to post links in your text i believe
houston is offline
Old 08-28-2010 | 10:36 AM
  #3862
do, as in modify, btw wife leaves in ten min, i need you to hook it up!!!!!ill text u when ready for a wicked sig,..,.
Old 08-28-2010 | 04:31 PM
  #3863
houston's Avatar
Tech Prophet
Fms engines still on special
houston is offline
Old 08-28-2010 | 06:49 PM
  #3864
kgombe's Avatar
and they are BAD@SS
kgombe is online now
Old 08-28-2010 | 07:10 PM
  #3865
houston's Avatar
Tech Prophet
Originally Posted by kgombe
and they are BAD@SS
I second that
houston is offline
Old 08-28-2010 | 10:24 PM
  #3866
merdith6's Avatar
Default yep
I second that
I third that motion. that FMS is outa order, this whole courtroom is outa order........
merdith6 is offline
Old 08-29-2010 | 10:32 AM
  #3867
houston's Avatar
Tech Prophet
(Judge smacks gavel down) "order in the court!! , order in the court!" R
The verdict on the fms is in !! Its one bad MOFO !
houston is offline
Old 08-30-2010 | 01:06 AM
  #3868
Lonestar's Avatar
BAck from Racing the N21R + 086hs with the boys.
Day started well, I TQ'ed and broke the track record. There's something about a "smoother" engine that really helps tighten the lines and not overdrive the car... in qualifiers at least, when you're racing the clocks and not the other guys. At club racing level, this really helps be consistent and smooth and is exactly what I was looking for by going to smaller-HP mills.
Mains were a different story - I had brought a buddy, smart but completely inexperienced to Nitro as he's coming from EP to be my pit guy for the day, so he got trained "on the job" during qualifiers, and he learnt the ropes quick or so I thought.
We run a weird mains format around here, 3x15mns mains.
The first one, he didn't understand the 10s rule and started refueling at 3s so when the horn blew the car was still in his hands with the tank open started all the way from the back to finish 2nd. The guy who won by half a lap on me got the track record again, he was the original record holder so he had to regain it haha
The second one, I stalled during the warming laps. He couldn't restart it for like 30s, with like 3 people helping him with the usual (plugging the pipe, trying another glow heater, ...). Race was blown, so I came down from the stand, put new plug on, we tried everything for like 5mns until I asked him "you did refuel didn't you??".... Long silence then you get the rest. I start for like 3mns checking if everything was fine, but the mill was cutting like crazy for no reason, came back to the pits, the pressure line had been ripped off during the initial chaos. That's the first time I both DNS and DNF a main
Third one, finally, everything's fine, but this time as I knew I could still claim victory, I completely blew it and ended up 4th. can only blame myself.
The mill was super consistent all day, no overheating (except when no pressure line of course), top line good to very good, mid-range much more than OK, low-range so-so but enough to clear jumps when needed as long as the car was lined up properly. However, during the 3rd main, when canning it and losing focus on my throttle finger, I could barely hit 8mns. It stalled once at some point during the day, no one understood why, but new exhaust seals (one was partly chunked) seem to have cured it.
Overall a good little mill for sure, it took me a while but it seems to be rock solid now. Still a bit short on low-rpm power, so during close wheel-to-wheel racing it's easy to lose focus on the lines and mash the throttle helplessly and start overdriving the car itself out of shape, but then again for $150 you can't ask too much.
Thanks all for the help,
Paul
Lonestar is offline
Old 08-30-2010 | 01:32 AM
  #3869
KWT-NITRO's Avatar
Hey Monty,
Payment sent
KWT-NITRO is offline
Old 08-30-2010 | 06:02 AM
  #3870
teamlosi906's Avatar
Default fms
Question I tried the fms this past weekend in my truggy, Its fully broken in,running 30% byrons, stock head shims,oddonell 97t and the new nova #6 plug 6.5mm restrictor. tried a 9901ss 021 header, 053, thunder tiger 2035, losi re 10, sirio 2013 pipe,new tank and fuel lines also. One min it runs perfect on the bottom end snappy,then 10 seconds later has a slight bog,then snappy again?? Cant get it right.New clutch asm also 2 alu with gold 2 comp green springs. My plus 4 runs perfect. So its not anything with the truck.No matter how i tune it, rich bottom, lean bottom, Tune temps in the 220 to 270 range, No leaks on the motor,new bearings also.
teamlosi906 is offline
