Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 02-07-2010 | 12:38 PM
  #2356
dcracing's Avatar
lol, I havent discovered pit strategy yet. thanks for everything.
dcracing is offline
Old 02-07-2010 | 02:24 PM
  #2357
houston's Avatar
7.5 pretty much standard for 15 min. Or 30 min mains
9 min. If you can make it for 45min or 11:30 if you can stretch it cuts out a pit
For 30 min. Mains 10 min. Is becoming fairly doable
houston is offline
Old 02-08-2010 | 10:55 AM
  #2358
houston's Avatar
Nitro challenge coming very soon !!
If any body needs anything lmk , I am going to be packing light this time with only two boxes .
houston is offline
Old 02-08-2010 | 10:59 AM
  #2359
porkchop's Avatar
your phone should be ringing tonight after 9 my time lol
porkchop is offline
Old 02-08-2010 | 12:02 PM
  #2360
Lille-bror's Avatar
Hi.
I will not disagree with you, Monty. Personal I do the pitstop a little different:
Find out how long your car can run a tank of fuel in the qualifications. Let’s say it is 9,15. Now, you can't make pitstops at 9 min. Depending the track size, a 8,30 pitstop strategy will be save. If you then run a 30 min. final, I would pit at 8,30 of 3 reasons:
1: You won't get into much traffic in the pitlane.
2: The final stop should be at around 26 min. Your mechanic can make an even quicker stop, because the tank doesn't have to be filled up to the very top of the tank.
3: If you get into trouble in the final, you perhaps can drop the last pitstop and gain approximate 10-15 sec in the final result.
Cheers
Lille-bror is offline
Old 02-08-2010 | 12:57 PM
  #2361
houston's Avatar
Originally Posted by Lille-bror
Hi.
Cheers
i will agree with that
houston is offline
Old 02-08-2010 | 01:38 PM
  #2362
merdith6's Avatar
Default hey Monty
I rebuilt a friends buggy and he's got a p5 turbo plug engine. I put an odonnell 97t plug in it with 25 percent byrons. It starts fine, but anytime I give it throttle it dies. I am stumped. I never had a problem like that. It's tuned fairly well I don't think that's the problem. He had sealed the carb, shoult I take the carb off and reseal it just to be sure. The plug is fine but he had an os plug in it and could it have caused it to not seal properly even though the odonnell plug fits it better. I really don't like turbo plugs. Any advise would help. One thing Is I don't have these problems with engines, but I didn't break in or use this engine so I don't know what shape it's in other than it still has plenty of compression. It's probably something simple, but eludes me at the moment......When I rev it it just dies. It idles ok, but won't take fuel when reved.
merdith6 is offline
Old 02-08-2010 | 01:49 PM
  #2363
KWT-NITRO's Avatar
Hello there,
Monty will surely have the exact answer for your question but ill just give you my 2 cents, OS plugs dont have the same taper as the Nova, that doesnt mean you cant run an OS plug on the Nova, i run an OS plug on my plus 4 but when you start using OS plugs on a nova engine, you shouldnt change back to Nova or to Odonell plugs because when the pressure rises inside the chamber, sometimes it will leak and it will flame out.
cheers
Ali
KWT-NITRO is offline
Old 02-08-2010 | 02:02 PM
  #2364
merdith6's Avatar
Default ahhhhh
I was wondring what the heck was going on. Dang os stuff. Oh well Makes sense. Thanks for the reply. I appriciate it....
merdith6 is offline
Old 02-08-2010 | 02:45 PM
  #2365
losiracer78's Avatar
Monty let me tell you about this new fuel gun i got. Wow that all that i heard sat that fuel gun is fast and clean where did you get it.... I told a few people i got it in the mail.
losiracer78 is offline
Old 02-08-2010 | 03:41 PM
  #2366
r1harper's Avatar
dont forget the short pit strategy either...it has won us a lot of races
r1harper is offline
Old 02-08-2010 | 06:40 PM
  #2367
houston's Avatar
i take it you like it ?
i have one more here
i will see if more are available
houston is offline
Old 02-08-2010 | 06:41 PM
  #2368
houston's Avatar
i will also agree with that
hows that 5 port Wes ?
i want your feedback Mr.!!
houston is offline
Old 02-08-2010 | 06:45 PM
  #2369
houston's Avatar
one of two things , something is stuck in the hsn assembly of the carb or there is not enough fuel pressure and the engine is starving for fuel .
i would have to hear it to tell you if it is as a rich flameout or lean flameout .
could possibly be improper shimming
i have had 5 ports that really did not like turbo combustion chamber no matter what i did . try a standard
houston is offline
Old 02-08-2010 | 07:17 PM
  #2370
merdith6's Avatar
Default Sure
I was thinking that too. I always recommend a standard head button. I help my friend at his hobby shop and I tell guys to just get the nova with a standard buton. Just easier.
merdith6 is offline
