Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-30-2010 | 07:53 AM
  #3871
houston's Avatar
Originally Posted by teamlosi906
Question I tried the fms this past weekend in my truggy, Its fully broken in,running 30% byrons, stock head shims,oddonell 97t and the new nova #6 plug 6.5mm restrictor. tried a 9901ss 021 header, 053, thunder tiger 2035, losi re 10, sirio 2013 pipe,new tank and fuel lines also. One min it runs perfect on the bottom end snappy,then 10 seconds later has a slight bog,then snappy again?? Cant get it right.New clutch asm also 2 alu with gold 2 comp green springs. My plus 4 runs perfect. So its not anything with the truck.No matter how i tune it, rich bottom, lean bottom, Tune temps in the 220 to 270 range, No leaks on the motor,new bearings also.
Possibly a piece. Of. Gunk in the high speed assembly jerry , try a different carb
houston is offline
Old 08-30-2010 | 08:07 AM
  #3872
teamlosi906's Avatar
Will do thanks Monty
teamlosi906 is offline
Old 08-30-2010 | 08:09 AM
  #3873
houston's Avatar
Originally Posted by Lonestar
BAck from Racing the N21R + 086hs with the boys.
Day started well, I TQ'ed and broke the track record. There's something about a "smoother" engine that really helps tighten the lines and not overdrive the car... in qualifiers at least, when you're racing the clocks and not the other guys. At club racing level, this really helps be consistent and smooth and is exactly what I was looking for by going to smaller-HP mills.
Mains were a different story - I had brought a buddy, smart but completely inexperienced to Nitro as he's coming from EP to be my pit guy for the day, so he got trained "on the job" during qualifiers, and he learnt the ropes quick or so I thought.
We run a weird mains format around here, 3x15mns mains.
The first one, he didn't understand the 10s rule and started refueling at 3s so when the horn blew the car was still in his hands with the tank open started all the way from the back to finish 2nd. The guy who won by half a lap on me got the track record again, he was the original record holder so he had to regain it haha
The second one, I stalled during the warming laps. He couldn't restart it for like 30s, with like 3 people helping him with the usual (plugging the pipe, trying another glow heater, ...). Race was blown, so I came down from the stand, put new plug on, we tried everything for like 5mns until I asked him "you did refuel didn't you??".... Long silence then you get the rest. I start for like 3mns checking if everything was fine, but the mill was cutting like crazy for no reason, came back to the pits, the pressure line had been ripped off during the initial chaos. That's the first time I both DNS and DNF a main
Third one, finally, everything's fine, but this time as I knew I could still claim victory, I completely blew it and ended up 4th. can only blame myself.
The mill was super consistent all day, no overheating (except when no pressure line of course), top line good to very good, mid-range much more than OK, low-range so-so but enough to clear jumps when needed as long as the car was lined up properly. However, during the 3rd main, when canning it and losing focus on my throttle finger, I could barely hit 8mns. It stalled once at some point during the day, no one understood why, but new exhaust seals (one was partly chunked) seem to have cured it.
Overall a good little mill for sure, it took me a while but it seems to be rock solid now. Still a bit short on low-rpm power, so during close wheel-to-wheel racing it's easy to lose focus on the lines and mash the throttle helplessly and start overdriving the car itself out of shape, but then again for $150 you can't ask too much.
Thanks all for the help,
Paul
That's awesome and not so awesome at the same time Paul.
I'm glad to hear you found happiness in the n21r limited , I think the lack of instantaneous low end throttle response you are feeling is more caused by the pipe as the dyn086hs has a different feel on the bottom then most other pipesets. Kinda soft only for an instant then it kicks in the power and never stops. .
Sorry about your luck on the inexp. Pit help maybe next time he'll be better
houston is offline
Old 08-30-2010 | 08:33 AM
  #3874
Lonestar's Avatar
Exactly what I experienced indeed... feels like a old-school turbo engine, nothing below 2500rpm then woooooooooOOOOOOOOOOSH
I haven't given up on toying around with the 9901 yet
Paul
Lonestar is offline
Old 08-30-2010 | 05:44 PM
  #3875
KWT-NITRO's Avatar
Hey Monty,
is it ok if i send you a check for the 38 dollars just kidding, rest of payment sent bro.
dont forget my H.E.S white stickers and why not few free plugs, you know i run the OD 97T
cheers
Ali
KWT-NITRO is offline
Old 08-30-2010 | 06:18 PM
  #3876
rotarynut's Avatar
Questions?? stickers
Hey Monty speaking about stickers,I wanna get some more from you, do you have diff sizes? tell me how much & I'll send you some O'bama stimulus money no for real I'll send you ca$h.
rotarynut is offline
Old 08-30-2010 | 08:56 PM
  #3877
manson98's Avatar
Monty have you ever seen a wrist pin clip break off and go through a dam near new motor?
manson98 is offline
Old 08-30-2010 | 08:58 PM
  #3878
houston's Avatar
Paul
9901ss/41005 or 41029 (in your case) if you feel you need more punch
houston is offline
Old 08-30-2010 | 08:59 PM
  #3879
houston's Avatar
Originally Posted by KWT-NITRO
Hey Monty,
cheers
Ali
ya ya , you got it
might even have the newer 87t by the time i send them
houston is offline
  #3880
houston's Avatar
all one size , white orange and flourescent yellow no moey required for customers
houston is offline
Old 08-30-2010 | 09:02 PM
  #3881
houston's Avatar
thats the secind new one i have seen lately , i will address novarossi with the problem if it is indeed a factory problem
usually happens if you take the wrist pin clip out and dont quite get it seated
i am checking them all before i send them out now , peace of mind
houston is offline
Old 08-30-2010 | 09:09 PM
  #3882
manson98's Avatar
ya I bought this one last month from a main I only pulled the head off to make sure shimming was right so I never even took the piston out. I email Nova usa today as is a real bummer to have this high dollar of a motor ruined in one race day over a factory defect. Hope they get back to me.
manson98 is offline
Old 08-30-2010 | 09:17 PM
  #3883
merdith6's Avatar
Default hey
Let us know what they say or do to help you...
merdith6 is offline
Old 08-30-2010 | 09:26 PM
  #3884
houston's Avatar
remember when dealing with warranty it is of upmost importance to maintain your composure and not be demanding
just FYI , novarossi usa is in no way obligated to to do any warranty/repair work and Jim does so only as a convenience so you guys dont have to send stuff back to novarossi italy and have it take 3 months Jim is a very awesome/honest individual and will help you out to the best of his ability as long as you handle the situation properly
what engine is it? i will see what i can do about it , but just so you guys know something it is verrrryyyy hard to offer warranty on any nitro micromotor , especially if they have been disassembled in anyway
houston is offline
Old 08-30-2010 | 09:35 PM
  #3885
manson98's Avatar
Ya Monty I know they are not obligated to do anything but man I love these motors and don't really want to switch and I won't be demanding I have 2 more plus 4s right now but this was on my new Team plus 4. So really hate to think I may have a 500 dollar plus 4. Because I need this motor and i paid 330 for it and mightcost me another 200 to get it fixed. Thanks will let you know if I hear anything.
manson98 is offline
