Houstons Engine Service H.E.S.
#3826
Hurray!!! My N21R outputs the expected low and top-end performance, now it's shimmed at 0.7mm (for 25%). It's still a bit lower than I'd really wish on torque, but top rpm is in the upper quintile I'd say (086HS pipe). Initially I tried to make it work with a #6 Nova, but I just couldn't get it right, it would still overheat, then I went to Odo77 and suddenly it woke up and started being consistent. No flameouts, despite a slightly rich LSN to protect temps.
Now if I could only go past 8:30 runtime I'd feel even better ( I don't think the LSN can add more than say half a minute). If I have time I'll try to put the 9901+41030 back on it to see if runtime picks up.
Thanks all for the help - Sunday is raceday, nothing feels better than beating $450 mills with a $150 one, I'll let you know how it goes
Paul
Paul
9901ss/41005 would be better in the buggy if you are going to use the 9901ss pipe . the 086hs pipe is awesome but does not promote great runtime , great power , a lil violent powerband and crazy top , works awesome on the n21r limited
#3827
They work...but they're super hard. I've chipped more than one Hudy on tight head screws...it was a tuning tool, after all.
Can't beat a good fitting Crapsman for head screws...find one with the perfect blade thickness...then remove the girth for a perfect fit in your heads counter bore...
#3828
Monty, have a question, are the head screws on the FMS 3.5mm 0.6 x 18mm long? I want to put on some allen head screws, I'm not too fond of flat heads,know what I mean! I already replaced the ones on the back plate.
the FMS is running good, just under 1 gal thru it now, thanks man.
#3829
#3830
thats my first question , tonys screwz is the screw company that offers replacements i believe . i am pretty sure they are 3.5mm but for some reason i am thinking they 3.75mmi have had a hudy driver for the heads and have torqued and untorqued 1,000's and 1,000's of those flat head screws with no issues
#3831
I unfortunately don't have 41005... and i'm not planning to buy more bits to make this baby work
I have a 41052 in my boxes though but I think that might promote top-end a bit too much (And a pallet of 41021 and 41030). I run an mbx-6, so not everything fits without physically touching the body/tank/sideskirts... Are the 9901ss's internals different from the 9901's?
Thanks for all the info - I'll dedicate you my victory sunday
Paul
#3832
Fair enough, still a sport mill after all
Paul
Paul
41052?
9901ss/41005 pipeset works on almost all novamills
#3833
41052 isn't a nova ref, sorry - it's a JP Racing (not Jammin Product) rebadgeing of an original nova pipe whose ref I can't find - here's a pic:
I bought it last year like a week before nova released the 41030 as I didn't want to melt a second tank with the "stock" 41021
41005 - the one with both 90deg angles???
thanks for all the help
Paul
#3834
Thanks again!
#3835
#3836
funny, i also bought like 12 novarossi plugs, was very stubborn to get them to work, if ii LISTENED to monty from the beginning, i would of saved 120.00 and some hair from my head...monty please text me when u can thanx...
#3837
#3838
really??? same geometry, working differently? Materials vibrate differently to acoustic waves, maybe?
thickness of the wall on an exhaust plays a large part of the way it works yes, the new pipe is probably a touch less volume but it definitely runs better handsdown
tried that style of header before and for some reason it just never felt right , just felt wrong
that header works killer on the buggy with the 9901ss
Paul
Paul
#3839
why do you feel that you need to disassemble the engine
I'm doing it mostly for inspection purposes. my calipers measured the screws at 3.4 and change so 3.5 has to be it. yeap I just checked @ tony's screws
3.5mm , the kit to do the complete engine is $5.
#3840
Monty, it's just a personal thing against flat heads, I'm an auto tech and disassembly and reassembly is in my blood
22Likes
