Houstons Engine Service H.E.S.
#3676
idle setting at race tune will be around 3/4 turn out from just closed on the slide barrel
i dont remember the "specs" per se but if i remember correctly it was the short stroke big bore design that i am pretty sure the vspecs were designed after
( dont quote me but i am pretty sure) , it might have been the sbk? anyway good engine , use it until its done as they are not compatible parts wise with any engine out there today
holy smokes if youre happy with that clutch setup i would continue with using it , if not i would probably try three blue aluminum (losi) shoes with gold and one carbon (losi) with green and make sure you have the good clutch bell
#3677
Hey Monty, just got done setting up my clucth,3 alum w/gold,1 carbon w/green. the 3 alum are Kings heads 7075 if it makes any difference(it's all I have right now) would running 3 alum shoes cause an inbalance on the crank?just wondering.
#3678
yes the 7075 shoes do slip quite a bit which cause a lot of aluminum galling up inside the clutch bell . make sure everything is either fresh , new and scuffed in or used and cleaned very well
btw , i am not a losi clutch expert so you might wanna ask about a medium heavy clutch setup in the losi threads
#3683
here is a link to all of the losi clutch set ups, that you would find in your manual
http://www.losi.com/ProdInfo/Files/8ight2Manual.pdf
#3684
#3687
I need some good advice on the fuelline and exhaust tube.
My engine runs very rich, with a full tank, but when it reaches half or quarter-tank, it goes screaming.
I have a short length of fuelline but with a filter on and about 8 inch exhaust tube.
what can I do to reduce this problem?
#3688
#3689
There is no leak, I have tryed with 2 different tanks, and when I put a screw into the end of the fuelline, and put presure in the exhausttube it holds presure until it gets so high the fuel cap pops up and let presure out
#3690
22Likes
