Xray NT1
#5596
Hey Drew is Xray making a worlds car? If so i just wait instead of getting one now
#5597
#5599
If there was a way to keep the large crown gears flat and not lift on one side as the geardiff rotates when going through a corner then the plastic gear idea would work really well and last a long time.
when Xray do a redesign i think we will see smaller diffs, this will eliminate the need to go looking for reducing rotating mass from such a crucial part. If i was a designer, i'd look at eliminating all rotating mass in the drivetrain, and go with a smaller clutch design, i'd then come up with various flyweight weights, clutch shoe hardness and clutch spring versions as a tuning option to play around with engagement style which is a big factor in ease of driving on different grip level tracks.
#5600
Hello all,
I read the winning wc setup and I see that the HD clutch is used with 0.6mm clutch gap and 0.7mm spring preload. Do the clutch weights contain the screws or not? If I use these settings without the screws (I have not tried with the screws installed yet), the clutch will severely slip. In order to avoid clutch slipping, I have the spring preload about 0.1 to 0.2mm maximum. Am I doing something wrong?
What was the temeperature on the air during the wc final?
Thanks in advance
Thanks in advance
#5601
Hello all,
Thanks in advance
Thanks in advance
You have to remember that we were using the new Xray red pad. With the yellow pad that setting will slip. With the yellow pad your gap should be .4 and the spring should be .5. But yes we used the screws and that is something you should try. It was hot like high 90's.
Thanks Drew
#5602
Thanks Drew
Thanks Drew
Can you explain why you choose not to run the Foam Inserts in the shocks? What is their effect on the car's handling and traction?
Also, what is the performance difference between adjustable pistons and non-adjustable pistons? Is having two hole with one the same as with the other?
Thanks.
#5603
".......foam used = more traction, more response
no foam used = less traction, slower response
I almost always use the foam. I only take out the foam on super high carpet traction tracks. In these conditions car can traction roll and removing the foam partially eliminates traction rolling....."
AFM
#5604
Thanks.
Thanks.
What Martin said in theory is right that is always what I thought about rebound more rebound more traction. less rebound less traction. But it can be tuned in alot of ways springs, oil, and pistons. We have almost ran every setting you can think of on this car and Ralph has been happiest with this setup.
I think the adj. piston are good and a quick tuning part of the car. But the fixed I feel that they are more consistent meaning they move through the oil better. One piston is soild and the other you put two peices together. Not that the fit is not good but there has to be a difference. Guess we would need a machine to tell us..LOL
Hope that made sense..
Thanks Drew
#5605
Well when you run no foam it just lets the bladder do more work "softer setting". With the foam its like using a stiffer bladder "harder setting". On Ralph's car we run no rebound with the softer setting on the bladder.
Thanks Drew
Thanks Drew
Hey Guys great effort at the worlds, nice to get some feed back here first hand. Just wondering if Ralph has had a chance to test other recent bodies and if so what were his findings.
Cheers
Alex.K
#5606
#5609
Thanks Drew
Thanks Drew
Do you do anything to the pistons when they come out of the package or is it all stock?
#5610
Thanks Drew
18Likes
