Like Tree18Likes
Xray NT1
Old 08-18-2010, 05:22 PM
  #5626
Drew Ellis's Avatar
Originally Posted by RayJ
Hey Drew, Thanks for the info on the arms. I have to place an order soon and am still running my 08 version of the NT1.
Couple of things I want to upgrade on the car.
1) High Dynamic Clutch: Should I be running the yellow shoe with the hard spring or medium spring? It will be for Toledo.
2) Capricorn Tires for Toledo. for qualifying 37 fronts and 40 rears? or something else?
3) On the Capricorn Tires what would be decent for mains? 45 rears? and 40 fronts?
RayJ
Ray
Yellow shoe with the hard spring or a orion spring. I like the orion spring the best.
Tires for Qly's 32, 35 or 37 fronts we run the 32 or 35. Rear 35 to 37 maybe a 40. For the main 37 lf 35 rf 45rr 40 lr is a good combo. But 40 front and 45 rear and good and safe. In the main at the worlds we ran 35 lf 32rf 37 lr 35 rr it made 30 min no problem.
Thanks Drew
Drew Ellis is offline
Old 08-18-2010, 05:24 PM
  #5627
Drew Ellis's Avatar
Originally Posted by Riketsu
DLS system in the NT1... Has anyone brainstormed on this??My only problem is how to mount it to the rear arm. The rest is the same as the other cars.I wouldn't like to use a MTX-4R rear arms.
In the works we will see how it goes at the GLC. And I will post some pics here. It is something I came up with and it will work with the parts you have just some modding..
Thanks Drew
Old 08-18-2010, 05:35 PM
  #5628
Riketsu's Avatar
Trader Rating: 34 (100%+)
Thanks Drew
Awesome Drew. Please let us know if its works and pics would be awesome for us to test it over here too!
Good Luck over there!
Riketsu is offline
Old 08-18-2010, 06:35 PM
  #5629
Default Jajajajaja
Shu you only need Serpent 733 with DLS jjajajaja no hagas otro clon
Geovannie is offline
Old 08-18-2010, 07:14 PM
  #5630
Riketsu's Avatar
I learned it from you. Weren't you the one that always said that we needed to keep looking to improve our car with whatever parts available??
Like the 720 with the Kyosho rear arms?
Riketsu is offline
Old 08-19-2010, 08:25 AM
  #5631
Thanks Drew
lol, looks like everyone is coming up with a DLS.
serpent,
then someone fitted it onto a mugen
now xray.
and iv already started designing one for my kyosho.
LiL_JaSoN is offline
Old 08-19-2010, 09:53 AM
  #5632
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
serpent,
now xray.
what exactly is the DLS supposed to do?
ToysRUsKid is offline
Old 08-19-2010, 09:54 AM
  #5633
Speyederjedi's Avatar
Thanks Drew
Drew,
Cool!!! Looking forward to the pics on the DLS set-up.
Regards,
Daniel
Speyederjedi is offline
Old 08-19-2010, 12:12 PM
  #5634
musti72's Avatar
It eliminates the camber gain at all times, so you adjust your static camber at nearly zero, and you have maximum contact patch to the ground.
musti72 is offline
Old 08-19-2010, 12:53 PM
  #5635
djiewie's Avatar
Default DLS NT1
hi there, i have already made dls for the NT1 , and posted some movies on you tube. First an movie with my first attemp and then an movie with the dls working with the hudy stands. In the netherlands it started with Roelof and friends wich showd it to Salven Check out modelbouwforum.nl the post Dax, it is in dutch but you can find several movies there.
Already tested it on the track.
Greetz JW
djiewie is offline
Old 08-19-2010, 01:53 PM
  #5636
DS Motorsport's Avatar
Someone ever replaced the little brace between the 2speed bulkhead and the radiosupport with a tierod?
Wischinski has this in his car as seen in the image below.
The standard plastic brace can cause tweak sometimes because the fit isn't 100% think this is the reason.
Also more rear wing/ body supports as seen at the WC:
The youtube clip of the dax djiewie mentioned:
+ YouTube Video
Btw just something I was wondering, I just finished building my T3, and this has a lot smaller ballends and ballcups. The ballends are made out of one piece of aluminum and have the thread incorparated.
Why not use the same size on the NT1?
Would shed some weight, don't think you need the bigger ballends for strength.
DS Motorsport is offline
Old 08-19-2010, 02:41 PM
  #5637
The brake pulley bulkhead brace is different too.
Interesting.
Lycan is offline
Old 08-19-2010, 05:27 PM
  #5638
Riketsu's Avatar
Hey DS,
Please post some pics of the DLS hookup.
Riketsu is offline
Old 08-19-2010, 06:29 PM
  #5639
Trader Rating: 15 (94%+)
Interesting tie rod on Dirks car, how would you adjust tweak with that?
mrgsr is offline
Old 08-20-2010, 07:06 AM
  #5640
NikoRacing's Avatar
I also noticed the brace adopted by Dirk on the Xray..but I thought he used it due to the bad weather. In that conditions the car has to be the most flexible.
I think it's too much for a high grip condition... but.. we will see in the next days
NikoRacing is offline
