Like Tree7Likes
Old 11-03-2010, 06:35 PM   #5746
godzukihop's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Q-B0R0 B0MBER View Post
OK GUYS I HAVE A QUESTION ? HAS ANYONE BEEN STRIPPING GEARS?I CANT SEEM TO GET THE GEAR MESH RIGHT ON MY NT1,I KEEP STRIPING 2ND GEAR..ANY TRICKS OR ADVICE WOULD BE HELPFULL ..
THX
Check the travel on the servo. Make sure when under full throttle the motor is not being pulled.
godzukihop is offline   Reply With Quote
Old 11-04-2010, 06:45 AM   #5747
D-nicest's Avatar
THX
Feel your 2nd gear hub bearing and make sure it's still smooth, the only engine mounts screws you have to locktite are the the ones below the chassis and the screws that hold the upper piece of the mount to the main mount. Also if your pinion teeth are sharp or worn it's easier to strip gears. What gearing are you using?
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 11-04-2010, 06:55 AM   #5748
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
So, to sum up what everyone has said:
1) Make sure the EPA of the servo isn't pulling the motor.
2) Replace the bearing of the main shaft and the clutch.
3) Check the bearings of the 2 speed housing.
4) Check the rotational play in the 2 speed clutch shoe adapter. Should be close to none.
5) Remove the chassis completely, and place it on a flat surface and see if its bent (left-to-right or front-to-back or both).
6) Make sure you aren't using a big split in pinion/spur.
7) Replace the pinion gear if they are sharp or worn out.
8) If everything else fails, replace the bulkheads. Unless the bulkheads are old, then I'd suggest you replace the bulkheads anyways.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 11-04-2010, 07:31 AM   #5749
airband's Avatar
Default Stripping 2nd
Smear a fine film of CA around the 2 speed shaft bearings and encourage them into the housing. We did 4 sets one afternoon and found the bearing was moving allowing the mesh to wander. Replace the housings and glue the bearings in for a permanant fix. Not had a problem since, even using the original skinny 2nds.
PS RC
Still learning.
airband is offline   Reply With Quote
Old 11-04-2010, 07:41 AM   #5750
RC MARKET's Avatar
CSO 20T Brake Disc holder
RC MARKET is offline   Reply With Quote
Old 11-04-2010, 07:53 AM   #5751
Riketsu's Avatar
PS RC
CA near a bearing??? That's a no-no in my book.
Old 11-04-2010, 10:50 AM   #5752
DS Motorsport's Avatar
Use Loctite Bearing retainer instead:
http://www.henkelna.com/cps/rde/xchg...UID=0000000HZN
I use this on all my bearings besides the wheel and engine bearings.
If you place bearings into a metal part it's a must to use this, greatly increases bearing life.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-04-2010, 04:47 PM   #5753
Q-B0R0 B0MBER's Avatar
THX FOR ALL THE INFO GUYS . I TRULY APPRETIATE IT!!!!! I WILL START ON THIS LIST OVER THE WEEKEND ,SO I CAN HAVE MY RIDE READY FOR THE U.S. OPEN AT THE FAMOUS KRACEWAY IN KISS,FLORIDA......CANT BE HALF WAY THROUGH THE MAIN STRIPPING GEARS ..
THANKS TO ALL ONCE AGAIN ........................................
Q-B0R0 B0MBER is offline   Reply With Quote
Old 11-04-2010, 05:49 PM   #5754
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Not to be all in NT1 business, because I run a Shepherd, but I was having the same prob with the 2nd speed housing moving bck n forth because of the bearing, I glued it also "oops" but no prob since!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 11-20-2010, 06:05 PM   #5755
bluer322's Avatar
Default 2nd gear stripping
I stripped 3 second gears this weekend, 1 in pratice, 1 in a qual, and 1 in a 25 min main with 6min left to go in the race. The 1st two were 54 teeth, the second was a 55 teeth gear. Any suggestions would help, thanks.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 11-20-2010, 06:41 PM   #5756
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Check bearings in the two speed, check the place where the two speed shaft and the one way bearing touch on the shaft. ALSO make sure your not running a split over 5 for the pinions. If you start trying to run an 18 tooth pinion with a 21 tooth second gear you will strip them every time. I check gear mesh of second with first gear not installed. then slide on first (spur) and check first separately. They should be as tight as possible while still spinning free. Hope that makes sense. also make sure your tightening the engine mount screws and using blue loctite. After all that check to make sure your chassis is straight. If its bent that will change gear mesh max/min. Also check and make sure your chassis isn't bent, if it is bowed that could affect gear mesh also. If you used to much loctite and it built up on the engine mount screws then clean it off to get a large adjustment range.
I can say I have never stripped an NT1 spur gear. I ran one set of gears for about 4 hours before I changed them just because. Also if you have a worn pinion gear that will wear out your spur gears prematurely.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 11-20-2010, 07:06 PM   #5757
bluer322's Avatar
Thanks I had one of the team the team drivers from xray Paul L. set the mesh after the frist time and I have new gears on there. I'll check the other things you said. Thanks.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 11-20-2010, 08:23 PM   #5758
rx7ttlm's Avatar
Yeah, if paul set the mesh then you have something else going on. Change your clutch bell bearings too.
Old 11-20-2010, 08:35 PM   #5759
Riketsu's Avatar
Remove your chassis completely from the car... and lay upside-down on a flat surface... Make sure it isn't bent at any place...
Check your clutch gap...
Old 11-21-2010, 06:00 AM   #5760
bluer322's Avatar
ok thanks
T. Nicholson
Matrix Tires
Serpent, 748tq
