Like Tree6Likes
Old 08-05-2010, 04:31 AM   #5581
musti72's Avatar
Originally Posted by Riketsu View Post
I just wanted everyone to be extra careful with the Capricorn Composite. I already broke one during a qualifier, so I'll just stick with steel ones. The oil in the case was new.
I still can not understand how could they break... Im running them hard for 12liters(3 gallons) and they are still like new.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 08-05-2010, 04:31 AM   #5582
thanks for letting us know, i also run them in my diffs.
did you check there was enough oil in there? let it sit for a while so all oil can sink around the gears (because they are small) or drill it, open it back up and re-fill?
maybe try running 2 steel gears (instead of 4), so see how it would hold up? it would end up weighing the same.
only prob is though, you would need to double to wt of the oil to achieve the weight you would normally use.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-05-2010, 05:35 AM   #5583
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Sorry guys, I was not specific enough.
The teeth of the composite gears look new. They all still look new. One of the big gears (the one at the outdrives end), broke on the opposite side of the teeth. The outdrive pin just chewed on that end.
I had been running mine for a few races. Just don't know exactly how many.
When I opened the diffs, it had all the oil there. So they were filled enough and were not leaking.
I prefer being 20 grams heavier than not finishing a race.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-05-2010, 06:00 AM   #5584
Thanks Riketsu, Mr. Hudy also spoke of this issue in their last Xray Column where 3 drivers broke in the final.
http://www.teamxray.com/teamxray/new...ec2997d488f64f
jelayne is offline   Reply With Quote
Old 08-05-2010, 06:30 AM   #5585
Pedro_Speedy's Avatar
Estoy de acuerdo !
I agree !
Pedro
The New Roc 360 V 2.0
Sponsored by.RC America-Xray-Hudy- Hot Race Tyres- GQ Racing Tires- Sweep Racing tires- Fantom racing- SpeedMerchant- Boca Bearings- TQ Wires- Maxy's Pro Racing Fuel - Maxy's Modified Engine-Larcher Paintworks- Brooklyn Hobby.
Pedro_Speedy is offline   Reply With Quote
Old 08-05-2010, 09:00 AM   #5586
Drew Ellis's Avatar
Guys we have been running them since the pre-worlds and have no problem, but I do know some of the team did have problems. I am not sure how they built them.
When I build Ralph's diff I always use new parts. You do not just want to change out the gears. The pin that is ripping up the back of the big gear needs to be new when using the lightweight gears. The pin gets alot of wear on it from the steel gear.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 08-05-2010, 09:18 AM   #5587
Speyederjedi's Avatar
Originally Posted by Drew Ellis View Post
Daniel
The extra weight we needed was in the engine mount and the Nimh 1600. So with the weight there I was able to lighten up the car in the drive train and balance the car. We also run the plastic receiver box. Ralph's car weighed 27 grams over the limit with main tires. With just the capricorn wheels with no rubber Ralph's car was 2 grams over the limit.
The pulleys we ran were just the outside. Everything else was stock plastic. Xray will offer all the pulleys in alum.
Thanks Drew
Drew,
Thanks for the info. I'll be looking for some of those new parts which will be rolling out soon.
Regards,
Daniel
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 08-07-2010, 07:04 PM   #5588
Drew do you all use brake springs between your brake pads ? The picture of Ralph's car is not that clear in that area.
thanks
Old 08-07-2010, 11:37 PM   #5589
Drew Ellis's Avatar
thanks
Yes we use springs..
Thanks Drew
Old 08-08-2010, 01:01 AM   #5590
Riketsu's Avatar
Thanks Drew
Hey Drew,
can you please explain how the steering servo is mounted? What servo arm is used? Is it a low profile steering servo? I can't see from the pictures how the pivot ball can be mounted facing the pipe instead of an opposite direction.
Thanks.
Old 08-08-2010, 01:46 AM   #5591
gfilos's Avatar
guys, do you know what is the effects of using 2 bevel gears instead of of 4 in the diff? is it all about weight?
Is the durability an issue? I think i read about some serpent guys using it in their cars during wc.
Also, what type of oil should be used when using 2 gears instead of 4? I suppose harder silikone should
be used, but how much harder?
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-08-2010, 05:31 AM   #5592
kickass's Avatar
Default composite gears
We here in down under also experienced mixed success with the composite, 1 driver running 4-5 meetings with no probs and myself the gears lasting 2 litres same pin issue, back to the steel for me!
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 08-08-2010, 08:54 AM   #5593
Drew Ellis's Avatar
Hey Drew,
Thanks.
The servo is mounted stock. The arm is the new alum. hudy arm for the 808. The servo is a 2367 kopropo. With this arm it has to be mounted on the front of it. We were braking the plastic one so we went with the alum. and have had no problems.
Thanks Drew
Old 08-08-2010, 09:01 AM   #5594
Osiris 75's Avatar
Trader Rating: 17 (100%+)
The servo is mounted stock. The arm is the new alum. hudy arm for the 808. The servo is a 2667 kopropo. With this arm it has to be mounted on the front of it. We were braking the plastic one so we went with the alum. and have had no problems.
Thanks Drew
2367 KO?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-08-2010, 12:37 PM   #5595
Drew Ellis's Avatar
Originally Posted by Osiris 75 View Post
2367 KO?
Yes, sorry. Typing to early in the morning not good.
Thanks Drew
