Like Tree18Likes
Xray NT1
Old 08-13-2010 | 07:37 AM
  #5611
Drew Ellis's Avatar
Originally Posted by _cyclops_
I also agree that the non-adjustable pistons are better. In some time, the adjustables get a bit of wear and the holes aren't aligned properly anymore...
Do you do anything to the pistons when they come out of the package or is it all stock?
The pistons are stock. I just clean them up and thats it.
Thanks Drew
Drew Ellis is offline
Old 08-14-2010 | 04:20 AM
  #5612
RayJ's Avatar
Default Shortened front arms.
Hi Drew, The front arms that you are using are they an Xray shortened lower A-Arm? I didn't know if they made them. Also which ackermann setting are you using with the shortened front arms? Thanks RayJ
RayJ is offline
Old 08-14-2010 | 01:05 PM
  #5613
kmichael's Avatar
Default Alu layshaft holder
LOL, FYI when installing the new alu layshaft holder install the bearing holder with the open side outward to remove play in shaft,was in a hurry to put this pretty thing on and had to do it twice LOL
kmichael is offline
Old 08-14-2010 | 04:51 PM
  #5614
Q-B0R0 B0MBER's Avatar
KEEP BURNIN MIKE I USUALLY FORGET SOMETHINGS IN THE PROCESS OF SEEKIN HIGHER LEARNING ALSO
Q-B0R0 B0MBER is offline
Old 08-14-2010 | 07:00 PM
  #5615
Drew Ellis's Avatar
Ray those are the new 2010 front arms they are out now, and yes they are 2mm shorter. We are running the D block. Meaning looking at the car like you are the driver you should read D.
Thanks Drew
Old 08-15-2010 | 04:50 AM
  #5616
kmichael's Avatar
You know me well
kmichael is offline
Old 08-16-2010 | 12:42 PM
  #5617
Default Yellow dyed fuel tank
I've just finished a gallon of o'donnel fuel and it turned my NT1 fuel tank yellow colored.
I've tried several cleaning products but nothing seems to work to give the tank its natural color back.
Any suggestion ?
Thanks.
Cobra zz is offline
Old 08-16-2010 | 05:55 PM
  #5618
Osiris 75's Avatar
Any suggestion ?
Thanks.
Run different fuel!
Osiris 75 is offline
Old 08-16-2010 | 07:23 PM
  #5619
rocca30's Avatar
Any suggestion ?
Thanks.
order a new tank!!
rocca30 is offline
Old 08-17-2010 | 12:20 AM
  #5620
kmichael's Avatar
Originally Posted by rocca30
order a new tank!!
+1 don't think you will get true color back,with out damage to tank
kmichael is offline
Old 08-17-2010 | 04:45 AM
  #5621
I've just ordered a new tank and returned to Byron.
Seems that O'donnel have a different oil that dyes fuel lines and tank...
Thanks guys.
Cobra zz is offline
Old 08-17-2010 | 06:50 AM
  #5622
RayJ's Avatar
Hey Drew, Thanks for the info on the arms. I have to place an order soon and am still running my 08 version of the NT1.
Couple of things I want to upgrade on the car.
1) High Dynamic Clutch: Should I be running the yellow shoe with the hard spring or medium spring? It will be for Toledo.
2) Capricorn Tires for Toledo. for qualifying 37 fronts and 40 rears? or something else?
3) On the Capricorn Tires what would be decent for mains? 45 rears? and 40 fronts?
RayJ
RayJ is offline
Old 08-17-2010 | 11:38 AM
  #5623
nitrobeast's Avatar
Thanks guys.
I had the same thing with o'donnel fuel, drove me crazy, but i used up the gallon and then switch to EB Mods fuel. The tank still has a little yellow to it but not that bad.
nitrobeast is offline
Old 08-17-2010 | 12:22 PM
  #5624
kmichael's Avatar
Really like the Byrons fuel,leaves engine clean inside no gunk.
kmichael is offline
Old 08-18-2010 | 12:50 PM
  #5625
Riketsu's Avatar
DLS system in the NT1... Has anyone brainstormed on this??
My only problem is how to mount it to the rear arm. The rest is the same as the other cars.
I wouldn't like to use a MTX-4R rear arms.
Riketsu is offline
