Like Tree7Likes
Old 11-21-2010, 11:59 AM   #5761
djiewie's Avatar
guys you are forgetting the one thing that cost me several gears in one race, that is the clutch bell housing. The bearings will eventually create room in the clutchbell. Then when you pull at the clutch bell the gap will increase. First i had a little play side ways in the clutchbell but when
I put bearing locktite in the clutch the play was gone and the gears were good, No more gear stripping. In 2 years that was the only problem i got with the NT1. Used the clutch bell also 2 years so it is inevitably i suppose.
But now even the old clutch bell is good.
Hope this helps you.
Greetz JW
djiewie is offline   Reply With Quote
Old 11-21-2010, 03:29 PM   #5762
bluer322's Avatar
Greetz JW
Were can I find bearing lock tite. Do I put in around the outer race of the bearings.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 11-21-2010, 08:28 PM   #5763
asw7576's Avatar
Isnt that too risky to put a locktite around the outer race of the bearing ?
Old 11-22-2010, 12:11 AM   #5764
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
if your clutch bell somehow wore out, replace it with a new one. Simply adding green lock will eliminate the play but it won't ensure that there is no axial runout. Meaning you could end up with poor contact with the clutch shoe. And if your wearing out clutch bells that tells me your running your clutch bearings way to long.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 11-22-2010, 06:43 AM   #5765
bluer322's Avatar
Well That can't be the case, I only had the car for a mouth and this is only the 2nd time i'v run it, and it just stared this weekend. I'll check all the other things. Thanks.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 11-22-2010, 08:51 AM   #5766
DS Motorsport's Avatar
Get this one:
http://www.henkelna.com/cps/rde/xchg...UID=0000000HZN
It only needs a drop, work precisely when applying it and you shouldn't experience any problems.
I advise to use this on all bearings which are secured into metal( except engine bearings off course) from the start, it enhances bearing life and takes out any play.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-22-2010, 10:19 AM   #5767
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by DS Motorsport View Post
Get this one:
How hard is it to remove the worn bearings? Once you use the locktite.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-22-2010, 10:28 AM   #5768
YBSLOW's Avatar
Default WC
Just finished building the WC version of the NT1 and for those of you out there that have already built an xray kit you already now how awesome and easy everything goes together.
After building other brands of kits all I can say is I cannot wait to get this car on the track............ not to mention how easy and professional Rc America handles everything.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 11-22-2010, 10:57 AM   #5769
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Congratz on the new car!! You're gonna love it!
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 11-22-2010, 11:06 AM   #5770
Pass you soon...
It's pretty easy, a small tap with an appropriate socket will do.
As you can read in the link this type is for assemblies which need disassembly.
Strength wise you can compare it with the blue locktite for fasteners.
P1-RC.com
Old 11-22-2010, 02:41 PM   #5771
Thanks I had one of the team the team drivers from xray Paul L. set the mesh after the frist time and I have new gears on there. I'll check the other things you said. Thanks.
Is there any side to side play in the 2 speed shaft?
I had gear stripping issues resolved by placing a 0.2mm shim between the 2 speed pin and the bulkhead bearing.
Also, what engine mount are you running?
Could be an worth considering the monoblock engine mount (338713) or the new brass mount.
Cheers
Andrew
Lycan is offline   Reply With Quote
Old 11-22-2010, 03:29 PM   #5772
bluer322's Avatar
mono block
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 11-22-2010, 04:25 PM   #5773
mono block
Since I got the mono block I have continually stripped gears, I still cannot understand why but what I also noticed the front of the block will suddenly develop a crack. After going back to the original engine mount the gear stripping stopped.
jelayne is offline   Reply With Quote
Old 12-07-2010, 12:54 PM   #5774
RC MARKET's Avatar
Do you have check your 2 speed shaft , Engine , Clutch bearing ?
RC MARKET is offline   Reply With Quote
Old 12-07-2010, 12:57 PM   #5775
Any news of the NT1 2011 ?
kerb is offline   Reply With Quote
