Like Tree6Likes
Old 01-17-2014, 06:53 AM   #7111
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Originally Posted by snuvet75 View Post
It's O.S. XZ engine. Again I can't say 100% that it's having the same problem after I re built the engine yet cuz, as you mentioned, I only broke in the engine halfway in the garage last night and didn't involve running the car on the ground. Today, I'll lay down the car on the ground and try it to see the problem still exists.
Obviously last night, the engine was not even 160 degrees when I was breaking in. Another reason I can't say the problem still exists. I'll update you tonight.
I'll take a picture and post it here to see if you can notice any. I may not be a beginner but not an expert either so hopefully you guys can notice something that I don't see. I checked this and that so many times already that I don't even know if I want to keep this car LOL.
Yeah is is definitely an engine tuning issue. I usually break in by two tanks idling on the box, then two tanks in the track extremely heavy or thick on the Hs needle to the point where the car I s just barely able to get around, aka super slow, 3rd, 4th, and 5th tank on the track I start to lean out the engine ever so slightly to get it to 180, by my 6th and 7th tank I bump it up to 200 and by my 8th I am able to tune to full bore. Shifting should start occurring on the 7th and 8th tank.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 01-17-2014, 08:24 AM   #7112
djiewie's Avatar
If the engine is not tuned right it will not shift well. Don`t worrie.
Tune the low and high needle untill it sounds like a dog barking with shorts bursts on the throttle. Snappy on the throttle and quick revving. When your done running in that is.
djiewie is offline   Reply With Quote
Old 01-17-2014, 03:53 PM   #7113
blis's Avatar
My NT1 has very inconsistent gear shifting. Sometimes it doesn't even shift or it shift way too early no matter how tight the 2nd gear shoe is. I checked the one way bearing, clutch and got a new shoe for the 2 speed and still same problem exists. I just re built the car and in the process of re building the engine(O.S. XZ). I just couldn't finish it today because the crankshaft bearing is jacked a bit so I have to get a new one. What else should I check??
One way bearing maybe... Clean it thoroughly, clean lay shaft, add one drop of one-way lube, put on lay shaft, rotate and feel the grab.
If your oneway is over lubricated it can slip, it's engaged in 1st gear when revving up the two speed shoe, if slipping can cause changing shift or slip completely and risk a blown engine.
If 2speed shoes are asymmetric, the larger trailing mass should be greater in the direction of rotation.
If there's a silver sheen on shoe, shoe is slipping, contaminants perhaps or shoe setup.
If it's a new car then accept the entire transmission needs "running in" like an engine, chassis and bearings too, so ensure you're not binding on brakes too, anything to slow down the RPM of the two speed drum, not necssarily just the engine rpm, as your clutch can slip and the 2 Speed Drum slows down.
When stuck in 2nd gear things tend to go bad. We all cringe at a finicky 2 speed, so you're not alone.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-17-2014, 07:14 PM   #7114
snuvet75's Avatar
Trader Rating: 16 (94%+)
Thank you for you insight.
Does Silver sheen on the shoe always mean slipping shoe? I've seen it even when the car runs fine.
It's not a new car so breaking in the entire drive train seems unnecessary.
I'll test it again tomorrow and update you.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 01-17-2014, 07:22 PM   #7115
snuvet75's Avatar
Sorry I got you to misunderstand. The car was pretty fast on the track and was fast enough to shift. And the temp was around 210-220. It's just that the shifting was not consistent and sounded super weird.
I'll lean out HSN soon. 160 temperature was because I was in the process of breaking in the engine. I'll update you tomorrow.
Old 01-23-2014, 06:40 AM   #7116
rcmike's Avatar
Trader Rating: 40 (100%+)
Default 2014 nt1
Anyone know when the new car will be out ? Thx
See avatar, You have never Experienced FUN till you ride Motocross. Sponsors include Dunlop tires, FX graphics, Rad mfg and TH-R...
rcmike is offline   Reply With Quote
Old 01-23-2014, 11:27 AM   #7117
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Feb end I heard. Called up Speedworld at Roseville, they accept preorders.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-23-2014, 01:53 PM   #7118
bluer322's Avatar
Were there any changes to the 14
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 01-23-2014, 02:50 PM   #7119
Trader Rating: 13 (93%+)
Ive heard a revised front end
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-23-2014, 05:36 PM   #7120
GREGORY!'s Avatar
Anything more specific?
i have heard mtx5 like front end
we will see!
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 01-28-2014, 04:09 AM   #7121
MrHistory's Avatar
Hey Guys
what is the difference between 335660 and 335560 spur gears? i run the nt1 2013 and want to stock up on gears, and noticed on amain that there are two batches of various gears in the parts list
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 01-28-2014, 04:09 AM   #7122
MrHistory's Avatar
Hey Guys
what is the difference between 335660 and 335560 spur gears? i run the nt1 2013 and want to stock up on gears, and noticed on amain that there are two different sets of gears in the parts list...
http://www.amainhobbies.com/product_...d-Gear-60T-1St
http://www.amainhobbies.com/product_...d-1st-Gear-60T
Old 01-28-2014, 04:20 AM   #7123
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by MrHistory View Post
Hey Guys
You want the 3356** gears.
These are the new graphite gears (supposed to be lighter, stronger, truer, etc.)
I ran them for 1.5 days of racing, they still look brand new.
Michael_T is offline   Reply With Quote
Old 01-28-2014, 01:50 PM   #7124
MrHistory's Avatar
Thanks Michael!
Does anyone have gearing ideas for winternats? Want to order a variety of pinions and spurs. And want to know if I will use stock side pulleys. JI
Old 01-28-2014, 02:29 PM   #7125
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Thanks Michael!
Nice to see you picked up the right car.
For the most part, you'll need 16, 17, 22, 23 pinions. The 16 and 21 come in the kit so that will save you on one. I very rarely use a 21 and I don't think you'll need it at Winternats BUT, I've never been there.
For spurs...again I primarily use 54, 59, 60. Same as before, never been to Winternats but I think you'll be fine with the 4 pinions and 3 spurs. Maybe a 53 spur also just in case you like it.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
