Like Tree6Likes
Old 04-29-2009, 02:53 PM   #4111
Hello from France,
the Ins-Box is the new RB especially designed for 1/10th.
The RB T9RC is awesome!!!
romuald31 is offline   Reply With Quote
Old 04-29-2009, 03:04 PM   #4112
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Originally Posted by romuald31 View Post
Hello from France,
Thanks will look into finding one in the states.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-01-2009, 01:42 PM   #4113
fastrcracer's Avatar
With the 2009 spec kit, is there anything outside of what comes in the kit that is needed ?
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 05-01-2009, 02:17 PM   #4114
DS Motorsport's Avatar
What do you mean, to get it race ready?.
The only thing i would change is the wheel hexes. Stock they still supply the car with the plastic versions which are completely unusable. Everytime you remove the wheel the hex comes with it and you lose the pin.
So change the hexes for the alu one's (-0.75) and you're ready to race.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-04-2009, 05:27 PM   #4115
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by etgdpu View Post
I understand your point and I agree with your calculations. The only problem is that by doing so, I brake the 9.2mm rule. In that case it would be 9.4mm, which I do not know if it is right to have.
i found the paperwork the new numbers are 9.2-9.3mm for engine setup
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 05-05-2009, 04:01 PM   #4116
qcrc's Avatar
does the mugen clutch/ pinion tool work for the nt-1?
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 05-05-2009, 04:25 PM   #4117
D-nicest's Avatar
I'm not sure about the piece that goes inside the clutch bell, I'd go with the Hudy personally, but maybe someone else has tried the mugen and was successful...
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 05-05-2009, 05:21 PM   #4118
nitrobeast's Avatar
Trader Rating: 41 (100%+)
The hudy tool didnt work with the mugen pinions so if i had to guess i would say no
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 05-06-2009, 01:12 AM   #4119
freestyles's Avatar
Trader Rating: 14 (100%+)
I just bought the 08 kit and there are a few things i want to change straight up. Does anyone have part numbers for -0.75 hex's? Do they have to be that off set?
Alloy shock bodies, alloy front anti roll bar mounts and the optional battery to lower the CG even more?
Any help would be great.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 05-06-2009, 01:26 AM   #4120
etgdpu's Avatar
That piece does not catch the bell correctly. The other part that unscrews the pinions is OK.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 05-11-2009, 06:29 PM   #4121
freestyles's Avatar
I'm putting my nt1 08 together and i've come accross a few things that i'm not sure about. Has anyone else had these issues?
1. The rear diff seems to be floating around a bit so i had to put a .1mm shim on one side (that helped align the belt properly to).
2. Front cvd's and rear axles had to be shimmed to loose excess play (even with wheels on it was sloppy) so i had to put a .1mm shim
3. Side belt comes in contact with the button head screw on tension adjustment.
After hearing how easily these kits go together i'm a little confused as to why i'm having these issues. Everything else seems top notch though, the drive train is the smoothest i've seen and the suspension is so free it's not funny. The plastics look strong aswell.
Old 05-12-2009, 03:06 AM   #4122
Send a message via ICQ to _cyclops_
Is that fully assembled? I have the same, dont' feel its that important as long as the cap isn't too big. As you did, shimming it out is perfect.
Same here. It became even more with different bearings.
That's weird.
Yep, that totally rocks
But the things you point out are minor issues. The play is sometimes even needed for heating up or different conditions....
_cyclops_ is offline   Reply With Quote
Old 05-12-2009, 05:10 AM   #4123
aizenbelle's Avatar
Shims are life savers!!!!
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 05-12-2009, 08:17 AM   #4124
Shouldn't worry about the play on the diff and front and rear axle's.
I shimmed it out once but when the car became very hot in a race, one of the rear end bearings locked up. So like cyclops said, you need a bit of play to account for expanding of the various part during hard conditions.
Don't know about the button head screw which hits the belt, i use the wider belt on the car and have about a 1.5mm gap between the screw and the belt.
P1-RC.com
Old 05-13-2009, 01:25 AM   #4125
freestyles's Avatar
I've come across anther thing The aluminium piece that holds the exhaust pipe stay to the upper deck does not fit in without a bit of dremmel work. I've checked and checked and double checked the manual and i'm not doing anything wrong, it actually looks different than the manual's. Has anyone else had this problem or did i get a dud kit?
