Like Tree6Likes
Old 08-03-2012, 12:18 PM   #6361
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by ToysRUsKid View Post
Go back to your Serpent thread Elliot, there's nothing for you here.
Trust me... I'm leaving... it stinks over here anyway. But the conical washers are pretty nice if done right.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-04-2012, 06:44 AM   #6362
Are you running it with the flat flywheel or the HD flywheel?
Both in the reverse and the D clutches and works great. Just use smaller gap than with the regular spring and less preload.
Don't be afraid to start out with what seems to be ridiculously little preload. Those washers don't compress much.
Wachsmann64 is offline   Reply With Quote
Old 08-05-2012, 05:26 PM   #6363
Trader Rating: 13 (93%+)
I tested the conical washers with .7 on the nut and .6gap.
clutch felt really nice but after a few laps the adj nut would unwind itself.
i tried purple loctite and some other harder loctite but they both unwinded the nut.
what loctite are you guys using? i may have to buy a harder loctite..
I have a setup question...our track has a long fast straight with a right hand sweeper at the end. when i would enter the sweeper the car would feel nervous and looked to wobble as it went around. what could be the cause of this and how do i oversome it?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 08-05-2012, 05:51 PM   #6364
Send a message via AIM to barry Send a message via Skype™ to barry
add rear toe-in,thicker front diff oil,more caster.
barry is offline   Reply With Quote
Old 08-05-2012, 11:06 PM   #6365
HHH
HHH's Avatar
I use blue loctite, which I think is standard strength (is made by AE). Are you using enough loctite on the threads and waiting for it to bond/harden? Are both parts clean (of grease and dirt) before you apply the loctite?
HHH is offline   Reply With Quote
Old 08-05-2012, 11:32 PM   #6366
I used purple strength which is the lowest as its all i had.
i just bought blue and will put it on tonight and let it sit for 24 hrs before putting it all together.
Thanks for the tip HHH and Barry
Old 08-06-2012, 12:47 AM   #6367
Bundy_Bear's Avatar
I have had slipping clutch on my 2012 edition for last two meets. I noticed Xray didn't use locitite on the flywheel nut like other brands i have built in the past did from factory. Blis (Harry) got it right for me on Friday night and i managed to win my final. Hoping that is the end of it now, car is a dream to drive and i have cleaned it all up ready for next meet!
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-06-2012, 04:21 AM   #6368
blis's Avatar
John, I've seen lots of tourers do that through your sweeper. I think it's the difference in diff oil front to rear. My guess is front under-steers and then bites when the front diff loads up and slips.
Might have some footage somewhere of it happening.
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-13-2012, 01:41 PM   #6369
MikeCruz's Avatar
Default Excessive leaky Diffs
Hello to all,
Maybe someone can help me PLZ Thanks!
The problem I have been experiencing are that both front and rear, mainly tho front Diffs have been leaking right from the seams till dry after just couple of runs only, while using between 150-200k F & 60-80k R Fluids
Built them instruction spec, was careful with o rings every time, tighten them x pattern, and filled them just to above pins?
Curious if anyone are using gasket seal, different o rings, or maybe fabricating a gasket they cut to size?
Your help is greatly appreciated Thanks again! Mike...
MikeCruz is offline   Reply With Quote
Old 08-13-2012, 01:48 PM   #6370
Some people use the Xray aluminum pulleys? What are the advantages and disadvantages in using these?
GigiX is offline   Reply With Quote
Old 08-13-2012, 01:59 PM   #6371
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Originally Posted by MikeCruz View Post
Hello to all,
dont use the thin o-ring.
just the paper gasket.
dont overfill the diffs.
should be fine after that
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 08-13-2012, 02:46 PM   #6372
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Hello to all,
I use the o-ring and I've only had leaking when I blew it out during the diff build by over filling or not having it on the case right. Try putting it around the part of the case you add the diff oil to, only fill above the gears and then seal it. Before screwing it in, make sure the o-ring is not hanging out anyplace. Also, the o-ring can get out of shape so try to use a new one on every build.
What paper gasket? What did i miss?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 08-13-2012, 04:41 PM   #6373
MikeCruz's Avatar
Thanks fellas
I'll try again filling fluid to just the gear and c, hopfully have better luck. Thanks again!!
John,
Where u referring to the paper gaskets for the T3?
If not, when u have a chance if i can have part # for the one u mentioned or where to buy a paper gasket that I cut & make fit
Thanks again Guys for all your help!! Mike...
Old 08-14-2012, 03:26 AM   #6374
HHH
HHH's Avatar
The advantage is that you do not need to clean them so much. The holes in the sides and the material lets dirt and grime escape easily. Cleaner = smoother drivetrain.
The disadvantage is the cost and that in theory the teeth could wear and become sharp enough to damage the belts.
I have run the same set for two years and have had no problems. In fact, they make maintenance easier. I have not bought a pulley for two years.
Old 08-19-2012, 07:59 PM   #6375
Q-B0R0 B0MBER's Avatar
Default X-RAY!!!!!!!!!!!!!!!!!!!!!!STILL NUMBER 1
ANOTHER CHAMPIONSHIP WIN FOR THE X-RAY NT1 !!!!!!!!!!X-RAY TAKES THE 200MM EUROS IN ITALY!!!!!!!!!!!!
Q-BORO BOMBER AKA INFAMOUS FAME ONE
PASS YOU IN THE INFAMOUS X-RAY NT1
POWERED BY HEAVY MOTOR AND SKILLLZZZZ
SPONSORED BY MY MONEY!!
Q-B0R0 B0MBER is offline   Reply With Quote
