Like Tree7Likes
Old 07-30-2012, 12:17 PM   #6346
RC MARKET's Avatar
XRAY Released NT1 PRO Ver.
RC MARKET is offline   Reply With Quote
Old 07-30-2012, 08:56 PM   #6347
Go softer on the clutch and lighter on the front diff oil. Such a heavy oil pulls the front like crazy on power.
Try something like 100 front and 60 rear to start and tune from there.
[QUOTE=JamesHealey;11032526]Ran the NT1 yesteday, struggled with an on power over steer on corner exit.
Couldn't apply the throttle leaving the corner all day.
Wachsmann64 is offline   Reply With Quote
Old 07-30-2012, 09:29 PM   #6348
azeroth's Avatar
Trader Rating: 20 (100%+)
I had same issue 2 weeks ago softer clutch rear upper link #2 no shims outer and went up 1 spring rate as well
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 07-31-2012, 07:35 AM   #6349
esckalayd's Avatar
New Progressive Springs:
http://www.redrc.net/2012/07/xray-nt...ssive-springs/
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 07-31-2012, 03:59 PM   #6350
why and where would you use progressive springs ?
jelayne is offline   Reply With Quote
Old 07-31-2012, 05:21 PM   #6351
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I'm going to try the rear on my setup and see how I like them. I can't say "where" I will use them so I"m going to do some testing. Not sure I'll use the front because I don't currently use any springs in that range.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 08-01-2012, 09:49 AM   #6352
RC MARKET's Avatar
Xray Releasd la !!
Xray NT1-xr-338182.jpg   Xray NT1-xr-338281.jpg   Xray NT1-xr-338502.jpg   Xray NT1-xr-334131.jpg
Old 08-02-2012, 04:55 PM   #6353
Trader Rating: 13 (93%+)
Default conical spring washers
Is anyone using the conical spring washers in the High dynamic clutch ?
i set mine up as per the booklet with the 5 x big washers in first then followed by the 5 thin washers and setting the adj nut to 1mm. i started with a .6 gap and the clutch was slipping pretty bad.
what are peoples thoughts on the washers and what setup are you using?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 08-02-2012, 06:10 PM   #6354
ToysRUsKid's Avatar
i've never tried it myself but others have and said you shouldn't run any gap.
Old 08-02-2012, 09:10 PM   #6355
I'm running .5 gap and about the same .5 on the adjusting nut. Lots of punch out of turns. Start at about .4-.5 on the nut and tighten if needed.
Old 08-02-2012, 09:39 PM   #6356
Thanks for that how do you find it compare to stock spring?
Old 08-02-2012, 10:53 PM   #6357
HHH
HHH's Avatar
I am running .6 gap and .7 nut with all the washers on the HD Clutch with a yellow shoe and I am a big fan. I find the response is much quicker, similar to an EP feel.
HHH is offline   Reply With Quote
Old 08-03-2012, 10:02 AM   #6358
ToysRUsKid's Avatar
Are you running it with the flat flywheel or the HD flywheel?
Old 08-03-2012, 12:00 PM   #6359
lil-bump's Avatar
Trader Rating: 83 (100%+)
I'm not sure if this applies. I ran the conical washers in a Serpent clutch (sedan) with a red shoe which is a softer shoe and it was beautiful. I would run a small gap maybe .3mm -.5mm. I would believe the conical washers do not have as much throw as a spring setup.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-03-2012, 12:03 PM   #6360
ToysRUsKid's Avatar
Pass you soon...
Go back to your Serpent thread Elliot, there's nothing for you here.
