Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-05-2009 | 05:19 AM
  #1216
elkman's Avatar
Default Purple O'donnell plugs?
Hey Monty,
What's the verdict on the Purple O'Donnell plug you grabbed from me. Did you like it?
elkman is offline
Old 08-05-2009 | 07:13 AM
  #1217
Lonestar's Avatar
Re slotted screws, especially the cooling head one, I picked up a Profi-Tool by Hudy a few years back which is purpose-design for Nova head screws. It shouldn't cost more than $10, it's a 5.8mm tip that falls RIGHT IN the Nova's screw heads. Insert it in the whole, turn gently, TICK, there you go. One of the smartest ideas from Juraj, really (this and the spring pulling tool )
Hi Monty,
I have a question about sleeve pinching - what this essentially does is squeeze matter to reduce the inner sleeve diameter, right? But this matter has to be coming from somewhere... namely the outer side. Hence my question: once the pinching is done, the fit of the sleeve in the case can't be as perfect as before, which means the sleeve will be able to move (radially, at least) around (even if a tiny bit) or at least vibrate (as it should be kept in place axially by the plug insert), how much risk does this represent for an engine revving at 30Krpm?
Regards,
Paul (still learning the ropes of IC engines... )
Lonestar is online now
Old 08-05-2009 | 06:24 PM
  #1218
houston's Avatar
Tech Prophet
Originally Posted by elkman
Hey Monty,
haven't been doing much running lately
i will try it soon boss
houston is offline
Old 08-06-2009 | 02:21 PM
  #1219
houston's Avatar
Tech Prophet
lonestar ; in testing the sleeves resized by rayaracing (they were done very well) i did not notice any leakage in the area around the sleeve and the fit in the block . some even had a better fit after they were done by ray
houston is offline
Old 08-07-2009 | 04:32 AM
  #1220
Lonestar's Avatar
Monty
ok - interesting - thanks
Paul
Old 08-07-2009 | 06:59 AM
  #1221
My speed is getting loose and i'll probably send my P/s to Rayaracing. change out the rod.
HOUSTON, not sure if you said it already but any news on DLC coating?
devilchrist is offline
Old 08-07-2009 | 08:03 AM
  #1222
houston's Avatar
Tech Prophet
Originally Posted by Lonestar
Monty
Paul
i thought the same thing before i had sent a few items to ray for a test resize .
houston is offline
Old 08-07-2009 | 08:06 AM
  #1223
houston's Avatar
Tech Prophet
the news is that the guy who is doing it is slow like molasses apparently
he has two cranks of mine to do .
houston is offline
Old 08-07-2009 | 08:12 AM
  #1224
Hi, whats the best pipe for a N21Bf running in buggy ? I already have an 086,2027,2035 and Jp4 i have only tried the 2027 and it didn't rev out much.
thanks
damo666 is offline
Old 08-07-2009 | 08:25 AM
  #1225
houston's Avatar
Tech Prophet
thanks
upon testing the dynamite 086hs performed the best on the bf limited
by a lot
houston is offline
Old 08-07-2009 | 08:31 AM
  #1226
reggie l.'s Avatar
i hear it works good but the rdl pipe gives it more top...but im goin to try the assotiated 2035 on it since that thing works on a lot of motors
reggie l. is offline
Old 08-07-2009 | 09:15 AM
  #1227
rpm1968's Avatar
easy now.
good things take time. sometimes long time "joe".
Rev
rpm1968 is offline
Old 08-07-2009 | 09:20 AM
  #1228
unsp0ken's Avatar
monty, just wondering... what's new with the P5XL compared to the old P5's?
unsp0ken is offline
Old 08-07-2009 | 09:56 AM
  #1229
want to get my Odonnell SS21 crank coated. let me know when you start taking orders.
Old 08-08-2009 | 09:40 AM
  #1230
jonw's Avatar
Houstons Engine Service Novarossi Plus 4 takes 12yr old Cade Whitenton to the TQ and 1st place win in Intermediate 1/8th Buggy and TQ and 1st Place win in Intermediate Arena Truck at the Region 9 ROAR Offroad Fuel Championships August 1st.
Thanks for the Plus 4 in the buggy Monty. The motor is off the hook and still not broke in yet. That is two in a row with SMOOTH NOVAROSSI POWER!!!!!
Jon
jonw is offline
