Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 07-06-2009 | 03:30 AM
  #976
GoJohnnyGo's Avatar
Originally Posted by houston
a little smoother on the trigger bro
LOL.....You still awake....YOU have PM
GoJohnnyGo is offline
Old 07-06-2009 | 07:44 AM
  #977
Trevor Williams's Avatar
Monty,
engine looks sweet, thanks for the hook bro..........hey man, pm me total for the modded mill and pipe(headed your way today).........then in August when I see ya I will have you service the plus4(I'll just bring it with me) I will have 3 days to hang out wit' ya and drive ya batty' LMFAO!
Trevor Williams is offline
Old 07-06-2009 | 09:13 AM
  #978
houston's Avatar
Tech Prophet
Originally Posted by Trevor Williams
Monty,
no prob bro
pm sent
i think you will be surprised by the 3 port
houston is offline
Old 07-06-2009 | 01:35 PM
  #979
I am stoked to try it on the tight technical layout @ dirtburners, my plus4 from you has been outstanding......Houstons Engine Service is the shizzle people!! If you have'nt got Monty's service yet, you dont know what engine service is about.......period.......thanks again Homie
Old 07-06-2009 | 08:46 PM
  #980
speedy G's Avatar
Was just needing some pipe recommendations for a Novarossi Plus 21-5K, any knowlege sharing is greatly appreciated.
speedy G is offline
Old 07-06-2009 | 10:49 PM
  #981
houston's Avatar
Tech Prophet
i found the ofna 063 pipeset very complimentary to the 21-5k design
this engine is one novarossi engine that i found the dynamite 086hs to not be the bast on
houston is offline
Old 07-06-2009 | 10:58 PM
  #982
air8's Avatar
Monty,
Any idea when you'll have Plus-4's back in stock to sell?
Thanx
chris
air8 is offline
Old 07-06-2009 | 11:01 PM
  #983
houston's Avatar
Tech Prophet
Originally Posted by air8
Monty,
Thanx
chris
should be this week
i will have to check up on it with jim tomorrow
check the site or pm me
i am leaving the thread to questions pertaining to tech. questions
the mods ya know
houston is offline
Old 07-06-2009 | 11:03 PM
  #984
GoJohnnyGo's Avatar
Old 07-06-2009 | 11:08 PM
  #985
houston's Avatar
Tech Prophet
Originally Posted by GoJohnnyGo
luv ya too big fatty
i will ship your rod and a 25.4mm bearing in the morning
houston is offline
Old 07-06-2009 | 11:23 PM
  #986
GoJohnnyGo's Avatar
Whats Cracka Lackin there Big FATTY?????? Yep thats it....any luck on a good used piston?
Yep thats the Addy
Old 07-06-2009 | 11:25 PM
  #987
air8's Avatar
Ah I see. Thanx.
air8 is offline
Old 07-06-2009 | 11:27 PM
  #988
houston's Avatar
Tech Prophet
Ah I see. Thanx.
ya know
houston is offline
Old 07-06-2009 | 11:28 PM
  #989
houston's Avatar
Tech Prophet
Yep thats the Addy
i need the sleeve to match the size johnny
dont get much better than a rematch
houston is offline
Old 07-08-2009 | 01:30 AM
  #990
houston's Avatar
Tech Prophet
Originally Posted by gtsum
Yes, if you richen the LSN, you will likely have to increase the idle accordingly. What I do (YMMV) is get the car up to temp and make high speed runs once the chassis is heat soaked...make sure your idle gap is around 1mm to start...get the hsn close, but not too lean..you want a good stream of smoke all the way to the top...when I bring it in to a stop, I listen to the idle....if it idles high and then drops to a lower idle within a few seconds (or a 2 stage idle drop), I lean the LSN....I do another high speed pass and repeat...once the idle remains constant (it might be high at this point), I am good...I will then adjust the idle speed to lower it down a bit. You might have to richen the hsn a bit after doing this. If your engine gets hotter the longer you run it, your lsn is likely too lean...this method works for me, but i will defer to Monty...lets see what he says!
pretty good gtsum
every single engine is always a little different too
but that is pretty close to how to race tune a novarossi engine
houston is offline
