Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 07-08-2009 | 06:23 AM
  #991
losi94's Avatar
Houston i just put a new carb on my 21-7.could you give me something close on a race tune,carb's off a new RX-21 P5XS,Thanks kenny
losi94 is offline
Old 07-08-2009 | 10:54 AM
  #992
houston's Avatar
http://www.rctech.net/forum/6040393-post1343.html
pull the slide barrel out , screw the lsn in until it bottoms out and then count in half turns while unscrewing (richening) until you reach the desired setting .
same basic adjustment for the hsn .
houston is offline
Old 07-08-2009 | 11:29 AM
  #993
I have a few novarossi engines. The one in question is a 21-5k. When measuring with calipers what is the tolerable size for the crank pin? Do you know that off the top of your head?
Thanks in advance!
AB
ABURTON is offline
Old 07-08-2009 | 11:33 AM
  #994
houston's Avatar
Thanks in advance!
AB
when the smallest measurement is 4.92 and/or more than .04mm out of round i will rerod one last time
houston is offline
Old 07-08-2009 | 11:41 AM
  #995
losi94's Avatar
Thanks again for all the help
losi94 is offline
Old 07-08-2009 | 01:07 PM
  #996
houston's Avatar
Originally Posted by RGraves
Houston, you need a website
its up
houston is offline
Old 07-08-2009 | 01:46 PM
  #997
jgtruggy's Avatar
What's the website?
jgtruggy is offline
Old 07-08-2009 | 01:50 PM
  #998
rcgeezer's Avatar
It's in his signature block at the bottom.
rcgeezer is offline
Old 07-08-2009 | 02:00 PM
  #999
Vary nice monty !!!
phoenix357 is offline
Old 07-08-2009 | 02:01 PM
  #1000
jgtruggy's Avatar
Originally Posted by jgtruggy
What's the website?
Oh duh............... At the bottom
jgtruggy is offline
Old 07-08-2009 | 02:04 PM
  #1001
rcgeezer's Avatar
Monty, are you going to add your engine "services" to the website? I'm guessing that it's still being built out? Nice looking by the way!
rcgeezer is offline
Old 07-08-2009 | 02:18 PM
  #1002
Frank L's Avatar
Thumbs up
+1 on the website. It looks good
Frank L is offline
Old 07-08-2009 | 04:00 PM
  #1003
Hi Monty
Going on what you said i got a 9901 with 41021 today for my p5 and put in the 8mm and all i can say is wow really brought it to life
one question on the tune though it seems great high speed and good smoke and low end is also great however mid range it isnt making the power it does at very bottom and very top its not to lean or rich on the top or bottom it doesnt hesitate or bog or anything like that it just drops power slightly should i play with the mid range needle its still factory as i have not touched this one any advice will be great
Thanks Ben
BenXB8ec is offline
Old 07-08-2009 | 04:46 PM
  #1004
Trevor Williams's Avatar
R/C Tech Elite Member
site looks good Monty...glad to see it man
Trevor Williams is offline
Old 07-08-2009 | 05:20 PM
  #1005
houston's Avatar
it is a work in progress as you can see . i have faith it will be just how i want it before too long
thanks to an rc bro named shane for talking me into it
houston is offline
