Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 02-20-2007, 05:08 AM
  #271
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
CRASH do you think if I hat one of those Palm Pilot things I could download my Castle Link into one of those and use that at the track to setup the speedo as needed? That would really be trick and take up no space.
wyd is offline
Old 02-20-2007, 05:30 AM
  #272
CRASH's Avatar
Trader Rating: 26 (100%+)
Unfortunatley that is a big no and at this time their is no plans to address this request either. We have this requested alot.
Later,
CRASH is offline
Old 02-20-2007, 05:36 AM
  #273
Trader Rating: 76 (100%+)
Hey Crash
HAVE YOU GUYS HAD ANY PROBLEMs with the new Microsoft Vista??
Had the Mamba disc install ok But then you could do nothing with the programme?? Brand new PC and software. Loaded the software on an old laptop with XP and no troubles??
If you could let me now or ask Joe to email me
Tony
addicted is offline
Old 02-20-2007, 11:01 AM
  #274
wyd
wyd's Avatar
Later,
Oh well just a thought. I guess I will just bring the laptop with me incase I need it. I don't think in brushed mode I will be changing my setups too much but when and if I get to run some brushless stuff I'm sure I will be changing all kinds of things.
wyd is offline
Old 02-20-2007, 11:09 AM
  #275
g12314's Avatar
I was looking at getting a GTB 5.5 setup for my ZX5 which I run on a large indoor track. A friend suggested I take a look at the Mamba Max setups.
I searched through the thread, but could not find an specifications regarding each Mamba Motor and what brushed turn it is equivalent to. I tyipcally run a 9 or 10 turn brushed setup.
Thanks,
Jimmy
g12314 is offline
Old 02-20-2007, 11:16 AM
  #276
CRASH's Avatar
Thanks,
Jimmy
Jimmy,
If you between a 9 and 10 turn then you will want to go with either our 5700 or 6900 series.
I am currently running a 6900 in my XXX4-G+ and it has plenty of power.
I would say our 5700 is equal to the Novak 5.5 and that are 6900 is equal to their 4.5.
Hope this helps.
CRASH is offline
Old 02-20-2007, 11:17 AM
  #277
CRASH's Avatar
Originally Posted by addicted
Hey Crash
Tony
Tony,
Info passed onto Joe.
Thanks,
CRASH is offline
Old 02-20-2007, 12:34 PM
  #278
g12314's Avatar
Thanks for the quick response. Torn between the right amount of power and having a little extra .
Jimmy
g12314 is offline
Old 02-20-2007, 07:33 PM
  #279
wyd
wyd's Avatar
CRASH get that mini 18T ready.
wyd is offline
Old 02-22-2007, 05:53 AM
  #280
Lower your timing to lowest. This seems to help alot with the Trinity motor.
Later,
Hi CRASH, I have tried that but it still seems to be having the problem. its getting really frustrating as sometimes it actually goes slightly in reverse
I have tried resetting the speedo and transmitter and re setting it up again but it still does the same - any ideas?
stuartb is offline
Old 02-23-2007, 04:59 PM
  #281
adamge's Avatar
There has been a small problem. But it is coming and coming really soon and I mean really soon.
Later,
^Message.Date = Feb 10
adamge is offline
Old 02-23-2007, 08:09 PM
  #282
I've got a Mamba in an RC18 and when the battery bumps into the voltage cutoff (I think), the Mamba ESC quits responding. It just continues to run at about 50% power with no response to input. The BEC is still working providing power to the servo. I have to unplug the ESC to get it to work again. I can duplicate the issue over and over.
6 Cell NiMH and voltage cutoff at 4.2 V
kaye7877 is offline
Old 02-27-2007, 08:25 AM
  #283
CRASH's Avatar
When the speedo hits the cutoff voltage it cuts back power to the system to protect the battery. This is mainly for li-po.
I would set it for nut off for 6 cell nimh, should be fine and good to go.
Later,
CRASH is offline
Old 02-27-2007, 08:33 AM
  #284
CRASH's Avatar
Let me do some research and get back to you. Hopefully in a couple days, things are crazy around here.
Later,
CRASH is offline
Old 02-27-2007, 08:35 AM
  #285
wyd
wyd's Avatar
Pics of my touring car setup with Mamba Max setup for brushed high power setup. I could of jumped the three wires going to the negative but I didn't do that just because if I go brushless I have all my wires ready to just solder to the motor. Lazy I guess.
Attached Thumbnails Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-mambamaxspeedo.jpg   Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-mambamaxbrushed.jpg
wyd is offline
