Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#271
Tech Legend
Trader Rating: 51 (100%+)
CRASH do you think if I hat one of those Palm Pilot things I could download my Castle Link into one of those and use that at the track to setup the speedo as needed? That would really be trick and take up no space.
#272
Unfortunatley that is a big no and at this time their is no plans to address this request either. We have this requested alot.
Later,
#273
Hey Crash
HAVE YOU GUYS HAD ANY PROBLEMs with the new Microsoft Vista??
Had the Mamba disc install ok But then you could do nothing with the programme?? Brand new PC and software. Loaded the software on an old laptop with XP and no troubles??
If you could let me now or ask Joe to email me
Tony
Tony
#274
Tech Legend
Later,
Later,
#275
I was looking at getting a GTB 5.5 setup for my ZX5 which I run on a large indoor track. A friend suggested I take a look at the Mamba Max setups.
I searched through the thread, but could not find an specifications regarding each Mamba Motor and what brushed turn it is equivalent to. I tyipcally run a 9 or 10 turn brushed setup.
Thanks,
Jimmy
Thanks,
Jimmy
#276
Thanks,
Jimmy
Thanks,
Jimmy
If you between a 9 and 10 turn then you will want to go with either our 5700 or 6900 series.
I am currently running a 6900 in my XXX4-G+ and it has plenty of power.
I would say our 5700 is equal to the Novak 5.5 and that are 6900 is equal to their 4.5.
Hope this helps.
#277
Originally Posted by addicted
Hey Crash
Tony
Tony
Info passed onto Joe.
Thanks,
#279
Tech Legend
CRASH get that mini 18T ready.
#280
Lower your timing to lowest. This seems to help alot with the Trinity motor.
Later,
Later,
I have tried resetting the speedo and transmitter and re setting it up again but it still does the same - any ideas?
#282
I've got a Mamba in an RC18 and when the battery bumps into the voltage cutoff (I think), the Mamba ESC quits responding. It just continues to run at about 50% power with no response to input. The BEC is still working providing power to the servo. I have to unplug the ESC to get it to work again. I can duplicate the issue over and over.
6 Cell NiMH and voltage cutoff at 4.2 V
#283
When the speedo hits the cutoff voltage it cuts back power to the system to protect the battery. This is mainly for li-po.
I would set it for nut off for 6 cell nimh, should be fine and good to go.
Later,
#284
Originally Posted by stuartb
Hi CRASH, I have tried that but it still seems to be having the problem. its getting really frustrating as sometimes it actually goes slightly in reverse
Let me do some research and get back to you. Hopefully in a couple days, things are crazy around here.
Later,
#285
Tech Legend
Pics of my touring car setup with Mamba Max setup for brushed high power setup. I could of jumped the three wires going to the negative but I didn't do that just because if I go brushless I have all my wires ready to just solder to the motor. Lazy I guess.
