Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 01-26-2007, 09:35 PM
  #121
Mike Haynes's Avatar
I hard wire so i use the switch, and as long as your trigger is at neutral when you turn on there should not be a problem.
Mike Haynes is offline
Old 01-27-2007, 06:35 AM
  #122
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally Posted by yyhayyim
Brake:50%
Reverse:20%
Punch/Traction: Lowest
Drag: 20%
Start power: medium
Cutoff: Auto-lipo
motor timing: lowest
Throttle curve: set to curve setting, and dragged curve line at 50 mark downwards a bit.
Any help or advise would defenitely help fellas....thanks
Go back to the factory default settings and start there. Then let us know if that helps.
Later,
CRASH is offline
Old 01-27-2007, 06:42 AM
  #123
CRASH's Avatar
Originally Posted by Aaron P
Is this anytime you use the switch, or mainly in instances as described in the tuning guide, where say...you've adjusted the drag brake with the radio, and if you used the switch, it wouldn't see the throttle as being in a neutral position and so you have to set the trim back to zero before you turn it off? Or is it something that you would have to potentially completely re-calibrate each time?
Our you referring to the Mamba Max or Mamba 25?
Later,
CRASH is offline
Old 01-27-2007, 07:36 AM
  #124
adamge's Avatar
Here's a question. The ESC knows time, and it knows the motor's rotational speed. Why don't you just add an adjustable rev limiter to the ESC's programming? This would allow people to run 3s lipo on the 7700kV motor without it blowing apart. Admittedly, the release of the 6900kV motor will render this feature less important.
adamge is offline
Old 01-27-2007, 08:44 AM
  #125
CRASH's Avatar
The 6900kv is still only rated at 2s max.
As far as a rev limiter that would be completly up to the eingineers.
Later,
CRASH is offline
Old 01-27-2007, 09:06 AM
  #126
J C F D's Avatar
I am buying the mamba maxx 7700 package , I want to run the orion platnuim Is this a problem ? ANd what pinion should I run? I will be useing a Lazer ZX-5 .
J C F D is offline
Old 01-27-2007, 09:09 AM
  #127
CRASH's Avatar
No the Orion Platnium will not be a problem, it is a 2s li-po.
As for gearing will you be racing or playing? If racing what size track and what kind of traction does the track have? Also are you sing the stock spur gear?
Later,
CRASH is offline
Old 01-27-2007, 09:22 AM
  #128
J C F D's Avatar
OOps sorry to leave that info out, I will be mostly just playing , but might do a race or 2. Yes in the beginning I will be useing the stock spur. Unless you suggest I get a different one. I want the most out of the mamba package. ANd the track is a loose traction track. I havnt been to it yet but will be when the weather permits.
J C F D is offline
Old 01-27-2007, 12:34 PM
  #129
CRASH's Avatar
I would recommend starting with a 16 or 17 tooth pinion and go from there.
Later,
CRASH is offline
Old 01-27-2007, 04:01 PM
  #130
veecee's Avatar
Trader Rating: 34 (100%+)
Hi CRASH. Any further info on the 6900? I take it this is not the IFMAR legal motor?
veecee is offline
Old 01-27-2007, 04:24 PM
  #131
CRASH's Avatar
Info on the 6900kv
Not sure if any of our motors are IFMAR legal I now they are not ROAR legal, so I presume they are not IFMAR.
Later,
CRASH is offline
Old 01-27-2007, 06:07 PM
  #132
Trader Rating: 76 (100%+)
Hi Crash
I have an Esc that want power up??
It will power and receive info with the pc link but no led's etc etc when this is removed> tested the on/off switch but still nothing.
Any thoughts
Tony
addicted is offline
Old 01-27-2007, 06:13 PM
  #133
veecee's Avatar
Sounds good Crash. My time for brushless has come!
veecee is offline
Old 01-28-2007, 06:05 AM
  #134
J C F D's Avatar
Later,
Thanx
J C F D is offline
Old 01-28-2007, 08:53 AM
  #135
yyhayyim's Avatar
Angry Error Messages
I have had the Mamba Max 7700 system now for 3 weeks. I am very happy with the system overall, and still to fine tune to find the right speed Im looking for to compete with Novak 3.5R systems. However, two out of the 3 weeks, I have had serius problem with the MMX system suddenly being 'unable to write packet to ESC' mesages, and I cannot update or change anything on my settings. The software just seems to get messed up, and I have tried to uninstall/re-install software, and then plug the USB to ESC and PC to begin anew, but the ESC seems to always keep the old settings, and then flashes the red and greed LED lights simultaniusly and continiusly. If make any changes to my settings and try to send info to ESC, then I get the same stinking error message: "Unable to communicate with device. Cannot write packet to controller, unplug and reconnect USB device". I hate and fear this message as it tells me the ESC program is screwed up and there is no way to fix it by simply re-installing the program, or somehow resetting it; if you try to re-install, then when you plug in the USB to ESC, it somehow still retains the previous settings and bugs, and remembers them, and doesnt allow you to change anything because if you do, you get that anoying message! The first time this happened, I called Joe Ford, and once I told him what the message was, he immediately proceeded to replace the ESC for me, which was really nice...but 2 weeks later, here we go again...there must be some immediate fix to this problem. There must be a way to erase previus corrupt sofware or settings/bugs from the ESC and be allowed to re-install the software/firmware without like getting and brand new ESC and set to default settings. Now I am forced to miss out on another week of racing due to this frustrating issue....please help me. There must be something that can be done with having to go through the hastle of disconnecting the ESC and waiting for a new one to arrive 3-4 days later, reconnecting wires and setting up, and then having the fear that it will get screwed up again...there must be a fix/cure for this ASAP . Anyways, Mr. Ford, here is my info:
Yohan Hayyim
2750 N. 34th Ave, Unit 9H
Hollywood, FL 33021
954-643-0209
[email protected]
yyhayyim is offline
